Old 01-22-2012, 11:08 AM   #1
wxmyjnsn
Member#: 307537
Question 2004 engine questions
Ok, I have a 2004 WRX with the 6 in the 6 spot of the VIN.
it is completely stock.
I am looking to replace the engine as it may cost just as much to replace it as to fix the head gaskets (does that sound right?) the mechanic said about 2K for a head gasket job, but that was off the top of his head and not an actual estimate.
I looked on Google for the compatibility of engines and such but no luck.
Can any of you tell me what will work in my car. I am not a speed freak but if an STI will work please list those as well.
thanks
wxmyjnsn is offline   Reply With Quote
Old 01-22-2012, 12:19 PM   #2
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Any WRX or STi shortblock will work, however you need 02-05 wrx heads.
I don't know that I would replace a motor rather than do head gaskets though. You never know what you're going to get...
elevenpoint7five is offline   Reply With Quote
Old 01-22-2012, 12:43 PM   #3
wxmyjnsn
Member#: 307537
I'm thinking long blocks only. I agree it's a crap shoot on the swap, but what about the cost/benefit versus the head gasket repair. My engine had 95K and I just had the timing belt kit done along with the plugs and fluids (trans too).
Old 01-22-2012, 12:46 PM   #4
Staxsubby
Member#: 292881
2016 WRX STI
Crystal Black
First how many miles are on the car? I'm guessing around 120k if you have a bad head gasket with over heating probs. If your going to be pulling the engine and u have no technical ability to do most the work yourself. The cheapest route is going to be for you to get the head gaskets done. The best route is to get the engine re worked if your not looking at big numbers. Hybrids engine are expensive to do. Trust me I'm in the process. And 2500 doesn't go far. Pistons, Rods, decent 2.5 bottom end and some engine work and your still not done. Gotta get head work done valve job. And look at your car being done for 6months plus.
Staxsubby is offline   Reply With Quote
Old 01-22-2012, 01:25 PM   #5
wxmyjnsn
Member#: 307537
I'm not following you.
My car has 95K on it, I had the timing belt kit done early. The car was driving fine for 16 miles then i slowed to make a turn and I started to accelerate and bunch of white smoke was coming out of the car. It was not getting hotter and it was running smooth (not chugging or hesitating).
I called my mechanic the one who did the timing belt and he said it may be the head gasket but he need to look at it, I had it towed to him.
So my question is which engines can I put in my car, or will it be more cost effective to replace the engine. I will not be doing any of the work myself.
I have found several places online that sell engines for reasonable just not sure how much the swap would cost.
Old 01-22-2012, 01:39 PM   #6
Staxsubby
Member#: 292881
2016 WRX STI
Crystal Black
I think you need to thoroughly diagnose the problem before you purchase another engine
Old 01-24-2012, 01:12 AM   #7
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
If it started acting up 16 miles after you had work done...I'd find a new shop.
But just fix the issues, don't replace the motor. If you're going to do a long block, you need to do 02-05wrx unless you want to do a wiring and ecu swap as well, in which case, just buy an STi.
What is the difference between an 2004 engine & drivetrain, and a 2002 Rex2Low Newbies & FAQs 1 03-27-2010 06:50 AM
Sti 2004 Engines JDM Maniac Newbies & FAQs 1 02-07-2009 09:10 PM
UT: FS 2004 engine wire harness jaredpack Engine/Power/Exhaust 5 09-26-2007 01:56 PM
Nj For Sale 2004 Engine + Transmission Complete Brabus Private 'For Sale' Classifieds 22 01-09-2006 04:35 PM
Scoobysport question & engine question SubaruImpreza_power Newbies & FAQs 0 05-19-2003 08:18 AM
