Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Alaskan Impreza Club
Old 01-22-2012, 03:54 PM   #1
zzang89
Member#: 246077
Default Light problem
Im having a headlight issue with my 07 sti. The passenger hid wasnt working, so tried different bulb, and wasnt working. And tried working ballast, and still isnt working. So when i turn the light on, the light flickers, but doesnt turn on.
What could be the problem??
zzang89 is offline   Reply With Quote
Old 01-22-2012, 03:56 PM   #2
dsmkid
Member#: 238941
2011 MAZDASPEED 3
Plasti-Dipped Mafia
Bad relay possibly?
dsmkid is offline   Reply With Quote
Old 01-22-2012, 04:05 PM   #3
khann23
Member#: 302662
I'm having a problem in my 06. Passenger side light goes in and out over bumps.
khann23 is offline   Reply With Quote
Old 01-22-2012, 10:14 PM   #4
zzang89
Member#: 246077
I think mine kinda did that. Then now it doesnt turn on...
Old 01-23-2012, 04:13 PM   #5
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Check and clean the ground(s). Clean the socket as well.
P3Auto is online now   Reply With Quote
Old 01-24-2012, 09:26 PM   #6
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Measure pin 2 on the connector going to the chassis from the ballast. Check for resistance between that connector and ground. It should look like a perfect short to ground if it is ok. The wire should be black that you are testing. Also check the connector to the ballast for signs of corrosion or pins not making good contact. Test for 12 volts on pin 6 with the low beams on. BE CAREFUL NOT TO MESS WITH THE HIGH VOLTAGE SIDE OF THE BALLAST WHEN ITS CONNECTED IT WILL HURT BAD, EVEN FATAL IF THE VOLTAGE HITS YOU.
**For testing the power to the ballast and the ground disconnect the ballast.
Old 04-04-2012, 10:00 AM   #7
Gilberator
Member#: 288405
2004 wrx
I see this thread is from a few months ago. I just dont wantt o start a new thread. I have had issues with my passenger HID since i bought the car in july. When I turn my lights on, 60% of the time my passenger light wont come on. I have to jiggle the black ground wire (I believe) and then it will come on and stay on. Maybe one time it has went off while driving. Anyways, last night I jiggled it and BAM! now its just flickering like crazy. Also noticed my high beam flashed on real quick and dimmed back off. Just trying to see if i can narrow it down. checked the fuses, switched them still nothing. figured it wasnt the fuses but i just gave it a shot. any help would be awesome!
Gilberator is offline   Reply With Quote
Tail lights, gagues, and hvac light problem 04_wagon Electrical & Lighting 2 11-16-2007 04:03 AM
Fog Light Mod / Instrument Light Problem Wedge Car Audio, Video & Security 5 10-03-2002 01:20 AM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 06:35 PM
('93-'01) Gauge light problems please help me Texas25RS Impreza Forum 1 04-25-2001 09:44 AM
Head light & fog light problem White Knight Legacy Forum 4 03-29-2001 07:27 PM
