Old 06-25-2012, 10:25 AM   #1101
TYEFIM
Member#: 323090
2012 Impreza Sport
Obsidian Black Pearl
Originally Posted by ST Eye View Post
So in this picture the headlights are on also?
Did you change your headlight bulbs as well?
The headlights in those pictures ARE on. The angle I took the picture at and the fact that it was daylight hours just made it harder to see. If I take a picture in front of the car at the headlight level, the lights are pretty blinding at the correct level. The housing is pretty good at keeping it low enough and dispersed pretty evenly even though the housing is stock.
TYEFIM is offline   Reply With Quote
Old 06-25-2012, 03:34 PM   #1102
Angelus911
Member#: 89967
2012 Impreza Sport
[quote=TYEFIM;37454432]
Originally Posted by FlyerHazen View Post
What I had done was change the bulb itself to HID and add a ballast to each bulb. The HID kits came with ballast, bulb and wiring. Very simple conversion. Though I did notice a problem, that the foglight housing seemed to be heating up very quickly, causing a sort of "haziness" on the backside reflective interior near the bulb of the housing. It seemed to clear up after a bit of cooling off but I think its because the housing is not really made for that kind of heat (cheap material?), so far not causing any trouble i have noticed other than the 'haziness'.
The problem is that you installed HID bulbs in non-HID enclosures (if I read your post correctly). It's probably not a good idea to install those in the stock enclosure. There was a thread on here a little while ago about someone who did that on their WRX and the light ended up catching on fire due to the increased heat.
Angelus911 is offline   Reply With Quote
Old 06-25-2012, 04:45 PM   #1103
TYEFIM
Member#: 323090
2012 Impreza Sport
[quote=Angelus911;37457299]
Correct. It is the non-HID enclosure. The headlights are perfectly fine with the non-HID enclosure because they have more 'breathing room' in there. The fogs, not so much of course. The bulb has much less space to dissipate the heat. I will def consider changing at least the fog light enclosures, hearing that it can end up catching fire is not something i want to risk (who does). Ill be looking out for any signs of over heat until then. Dont have much experience with HIDs so all input is appreciated. Thanks Angelus911!
Old 06-25-2012, 11:24 PM   #1104
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
The plastidip is flat black. Easy to work with, my first time using it but didnt turn out too bad!
The lights were kind of interesting. When i had my friend tint the car I had bought the HID kits off of him and he wired it all for me. Originally id do it all myself but since I work so much now, its hard to find time to play around with these things. The headlights are 6000k and the fogs are 3000k yellow i think. I will have to double check on the fogs. I did not change the daytime running lights though.
How is the beam pattern with the HID headlights?
It's not cheap material, the stock bulb is a low power bulb. The house was never intended for use with HIDs.
ST Eye is offline   Reply With Quote
Old 06-26-2012, 11:08 AM   #1105
TYEFIM
Member#: 323090
2012 Impreza Sport
[quote=ST Eye;37461482]
Here is a shot of the lights on the garage. Best I could do last night, couldnt go further back was blocked by a car. (I probably should have let the lights warm up a bit more, you can probably see that the illumination looks a little unevenly distributed)
I will be looking into changing the housing for the fog lights to support the HIDs
Old 06-26-2012, 11:57 AM   #1106
highgain510
Member#: 324294
2012 Impreza Sport-P
Dark Gray Metallic
Proud new owner of an Impreza Sport Premium 5-speed in Dark Gray Metallic, first Subie too, but after having been in several I finally took the jump! My buddy has an '11 STI that is an absolute monster, so this is a bit tamer but an excellent daily driver and the stock engine sounds great when shifting. Only thing I absolutely have to change will be the stereo, not huge on the stock head unit.
I'll take better pictures with my SLR once I actually get tags and whatnot since I bought out of state and I'm waiting for the DMV to get the new tags out to me, so for now this is the only picture I have up:
Love it! I had an extended warranty on my trade-in so I'm waiting for the refund on the balance and then I can buy the new head unit and likely get it tinted too. Can't wait!
highgain510 is offline   Reply With Quote
Old 06-26-2012, 05:40 PM   #1107
ST Eye
Member#: 73068
Looking good! Welcome to the club!
Old 06-27-2012, 10:52 AM   #1108
maddog39
Member#: 242919
2011 Outback 6MT
SSM
Your at faulkner subaru in bethlehem aren't you?
maddog39 is offline   Reply With Quote
Old 06-28-2012, 12:15 AM   #1109
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
Hey guys. Just pics of my subbie.
6000k HID
LED daytime runners
carbon fiber rear diffuser overlay
Wes_888 is offline   Reply With Quote
Old 06-28-2012, 12:57 AM   #1110
imcausinmadrukis
Member#: 318978
6000k HID
LED daytime runners
Where and what brand are your led drl?
imcausinmadrukis is offline   Reply With Quote
Old 06-28-2012, 01:48 AM   #1111
HinGurl
Member#: 293678
2012 Impreza 2.0i
5 Door Limited. Silver
What brand is the carbon fiber rear diffuser overlay? Is it real or is it a vinyl? Di Noc 3M carbon fiber vinyl?
HinGurl is offline   Reply With Quote
Old 06-28-2012, 02:24 AM   #1112
FlyerHazen
Member#: 320610
2012 2.0L
Sparco Assetta Gara in matte black? What size are they? Looks awesome. I have a four door base 5-speed in satin white pearl with hubcaps...I need to ditch them for some better wheels immediately.
FlyerHazen is offline   Reply With Quote
Old 06-28-2012, 03:07 PM   #1113
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
6000k HID
LED daytime runners
Wow that looks great! I would do those things to mine if i wasn't leasing
An owned guy is offline   Reply With Quote
Old 06-28-2012, 09:49 PM   #1114
Wes_888
Member#: 320291
http://store.ijdmtoy.com/9005-9006-L..._fog_sku41.htm
Its a 3M Carbon Fiber overlay. It was a custom make by a shop.
Thanks!!!! =) Cost is minimal though. As far as modding goes. Its still reasonable if you wanted to do it.
Old 06-28-2012, 10:05 PM   #1115
goleee33
Member#: 301701
2012 WRX 5-Door
Our newest addition to the family! 2012 Sport Limited
goleee33 is offline   Reply With Quote
Old 06-29-2012, 12:50 AM   #1116
NaturallyAspirated
Member#: 64792
2001 Impreza L
BRP
Looks great! Hoping to pick up that same exact car/color in the near future! Can I ask what you paid for it?
NaturallyAspirated is offline   Reply With Quote
Old 06-29-2012, 12:54 AM   #1117
BigVoxjammer
Member#: 319171
2012 Impreza Spt Ltd
Sky-Blue/Gray
Were you able to order it yet? I know they're tough to find, and that there's one exactly like it (white Sport Premium) sitting at Dick Hannah's in Vancouver Washington.It's on their website. Might be able to get them to ship it?
BigVoxjammer is offline   Reply With Quote
Old 06-29-2012, 02:21 AM   #1118
NaturallyAspirated
Member#: 64792
2001 Impreza L
BRP
Thanks for the suggestion! But I'm still deciding if I *need* to upgrade yet. If anything, I'll most likely be picking up a 2013 model.
Old 06-29-2012, 02:52 AM   #1119
goleee33
Member#: 301701
2012 WRX 5-Door
Funny thing is, my mom is on vacation in Vancouver, WA right now and saw the car and called home saying our car was accidentally delivered to Washington!
Old 06-29-2012, 11:42 AM   #1120
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
Ha Ha! I think Dick Hannah has had it for a bit, because they've had it on Craigslist for a month or so. People can see it there. It must be a return or a repo cuz it has 1200 miles or so on it, so it is "used" but they are hard to find and it is there. Funny thing is, they are asking 2k more than I got my Sport Limited for from them, so I'm sure that price is negotiable.
Old 06-29-2012, 11:44 AM   #1121
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Not trying to sh** in anyone's cheerios, but I hate the new impreza. Actually, it's dreadful. At least the BRZ doesn't suck.
5lipstream is offline   Reply With Quote
Old 06-29-2012, 12:26 PM   #1122
HinGurl
Member#: 293678
2012 Impreza 2.0i
Nice! Did you do the install yourself or was it done by the shop? I can't stand that plastic plate that's supposed to house a rear fog lamp. I understand the tow hook covers since those are functional. But we don't even get the rear fog lamp in North America.
Old 06-29-2012, 12:32 PM   #1123
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
Yes, I think there are BRZ threads as well. I suspect the 2 wheel drive BRZ is to Subarus what the water cooled, front-engine models of the 80's were to Porsche....
Old 06-29-2012, 04:48 PM   #1124
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
Thanks!!!! =) Cost is minimal though. As far as modding goes. Its still reasonable if you wanted to do it.[/quote]
Yeah im more worried about them giving me trouble when I go to turn it in.
Old 06-29-2012, 04:50 PM   #1125
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
I think your in the wrong thread then.
07 Impreza 2.5i Special Edition Speakers *BRAND NEW* Jonny07subie Interior/Dressup/Audio & Security 0 08-10-2007 03:13 PM
FS: LAMCO Boost Gauge (you know the stock one) meridock MAIC Private Classifieds 7 04-30-2007 06:50 PM
What happened to Member #100,000 (You know... the guy from Sri Lanka.) snvin Off-Topic 4 12-23-2005 01:02 PM
Hey Kosai, I saw you! (you know the drill, "not subie!") RandyF North West Impreza Club Forum -- NWIC 16 04-26-2000 12:54 AM
