#1151 | |
Member#: 302491
Vehicle:2012 Impreza 2.0i Pr Dark Grey Metallic CVT |
#1152 | |
Member#: 320291
Vehicle:2012 Impreza Sedan White |
lol! I love it. |
#1153 |
Member#: 87505
RMIC
Vehicle:2012 WRX Hatch Black 2012 5door 2.0i red |
![]() Daily driver detail day!! Put the WRX OEM set up on the daily driver and will save the Conti ExtremeContact DWS for winter use. Realized that the base 2.0i model does not have a rear sway bar...hahaha. I need to find some brackets and uplinks so that I can install the STi 19mm bar I have. |
#1154 |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2012 Impreza Limited ISM |
^^ Looks nice with the WRX wheels.
#1155 |
Member#: 176522
SCIC
Vehicle:2012 Imp Sport CVT Sage Green/Ice Silver |
#1156 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
Do you know where I could get a set of those rims? and is there anything that needs to be changed to make the rims fit our 2012 impreza? They are 17s? |
#1157 |
Member#: 274252
W. Canada
Vehicle:2002 WRX Sedan 6 speed PSM |
#1158 |
Member#: 87505
RMIC
I am sure you can find some on ebay or in the classifieds here. I took them off my 2012 WRX. I have the ATEQ scanner/programmer, so resetting the TPMS is not an issue, takes maybe 3 minutes total. Outside of that, they are a direct fit. The OEM WRX wheels like that are 17x8, et53, and have 235/45/17 tires on them. They fit nicely without any issues at all.
#1159 | |
Member#: 316869
#1160 |
Member#: 87505
RMIC
Did not care. But I am sure it will be a little loss...but that is irrelevant to me. If you are only concerned with MGP...then go smaller wheel diameter, to reduce weight, and then get a much thinner tire...like the OEM base wheels that are 15inch rims with a 195 tire on them. That will increase your MPG.
I am less concerned about losing 3MPG than most people here with the new Impreza....I do it for style ![]() |
#1161 | |
Member#: 316869
But it definitely looks great with the red lug nuts. I will be on the look out for those rims. |
#1162 |
Member#: 87505
RMIC
higher MPG tires lose performance/traction. In efforts to decrease rolling resistance, the compounds are less traction oriented. I'd rather have a great handling tire, for cornering and braking than an extra MPG or 2 due to compound or MPG rating. Again, just a personal preference. I have more value in being able to "drive" the car than someone else that may be much more concerned about ultimate reduction in environmental impact. That is the great thing about any car, you can make it what you want!!
#1163 | |
Member#: 320291
#1164 | |
Member#: 320291
I wanted the STI rims but realized it was not 5x100. Last edited by Wes_888; 07-05-2012 at 08:51 AM. |
#1165 |
Member#: 73068
#1166 |
Member#: 24162
Vehicle:2011 WRX 2012 Impreza 2.0i |
looks good w/stock wrx wheels
#1167 |
Member#: 320291
#1168 | |
Member#: 87505
RMIC
#1169 |
Member#: 159474
AKIC
Vehicle:2013 BRZ Ltd 6MT CBS Counter-steer like a boss |
#1170 | |
Member#: 73068
On a side note, the 2008 STI base model wheels are heavy as well. I shaved a ton of weight when I went to the Volk RE-30. |
#1171 | |
Member#: 159474
AKIC
Spacer adapter will look like these: ![]() You'll need M12 1.25 (I believe that's the correct sizing) tapered lug nuts, open-ended. I've been looking at purchasing a new set and some come with them already, which is nice. Torque them down, slap on the wheels and use your regular lugs and you're good to go! These are the equivalent of stock STI wheels on a stock STI using 5mm spacers to make them more flush. No rubbing, comfortable ride height for Alaskan standards. |
#1172 |
Member#: 324842
South East
Vehicle:2012 Impreza S Prem marine blue |
#1173 |
Member#: 324842
South East
#1174 | |
Member#: 320291
I was able to identify the car as an STI cuz of the rims... aside from that, its totally unrecognizable ![]() |
#1175 |
Member#: 325358
Vehicle:2012 Impreza White |
Got one in satin white!
| Thread Tools | |
| Display Modes | |
| 07 Impreza 2.5i Special Edition Speakers *BRAND NEW* | Jonny07subie | Interior/Dressup/Audio & Security | 0 | 08-10-2007 03:13 PM |
| FS: LAMCO Boost Gauge (you know the stock one) | meridock | MAIC Private Classifieds | 7 | 04-30-2007 06:50 PM |
| What happened to Member #100,000 (You know... the guy from Sri Lanka.) | snvin | Off-Topic | 4 | 12-23-2005 01:02 PM |
| Hey Kosai, I saw you! (you know the drill, "not subie!") | RandyF | North West Impreza Club Forum -- NWIC | 16 | 04-26-2000 12:54 AM |
