#1301 | |
Member#: 327734
E. Canada
Vehicle:2012 Impreza sdn MT DGM |
I keep seeing people recommend shifter bushings, how much of a difference does it make on a brand new car?
#1302 | |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
ALOT. Any manual transmission car has good bushings, but the travel on it is alot getting from 1 to 2nd 3rd to 4th etc. |
#1303 |
Member#: 328195
![]() ![]() Looks like they found grass and a Subaru on Mars ![]() Last edited by MySubaruIsNamedIgor; 08-09-2012 at 10:47 PM. Reason: typo |
#1304 |
Member#: 328223
SCIC
Vehicle:2012 Impreza Sport Pearl White |
I've been looking around and I'm trying to figure out if I can put the RallyArmor Mud flaps with the aero kit on my Sport Premium. Or if I have to take them off in order to put the mud flaps on.
Also, if I do need to remove the aero kit, do you guys think that it looks better with the aero kit or the Mud flaps. Thanks! |
#1305 |
Member#: 301179
BAIC
IMO both would look nice, and i believe you should be able too mount both at the same time..
#1306 | |
Member#: 302491
Vehicle:2012 Impreza 2.0i Pr Dark Grey Metallic CVT |
I personally like the look of the flaps better than the aero guards; the aero guards seem useless to me. |
#1307 |
Member#: 328223
SCIC
Great! Thanks SleepNMnky!
#1308 | |
Member#: 328578
Pretty much any festoon 31mm bulb will fit. The LEDs from this seller are white with a slight blue tinge. Turning on both maps and the dome makes it look like daylight inside its so bright. Quick note on install, the LEDs are pretty much drop-in, but do require bending the contacts a bit to make the slightly larger festoon bulb to fit. |
#1309 | |
Member#: 328578
![]() Would the slight mod of the grille work even if I have the sport mesh grille installed? |
#1310 | |
Member#: 328578
These are the same ones being sold here for $45 (http://store.ijdmtoy.com/9005-9006-L..._fog_sku41.htm) as far as I can tell. Shipping was much quicker than what they state as well which was a plus. LEDs Straight drop-in although keep in mind your high beams won't really work due to the drastic reduction in light output (but they do still flash if you need them to get people's attention). I never use my highs anyways so not a problem. |
#1311 | |
Member#: 301179
BAIC
![]() Sorry I wouldn't know as I dont know how the mesh grill and the standard grill are constructed in the back. But from the looks, you should be getting the same results with the mesh grille. |
#1312 |
Member#: 317014
Vehicle:2012 Impreza Sp Ltd. Dark Grey Metallic |
Thanks for the info Evergreen, I just ordered some LED bulbs from ijdmtoy...
Stan |
#1313 | |
Member#: 318978
#1314 | |
Member#: 323103
Vehicle:2012 Limited 2.0i Dreamy Gray Mistress |
Lets see some more pics. Am I srsly the only guy with a limited sedan? lol ![]() |
#1315 |
Member#: 323090
NWIC
Vehicle:2012 Impreza Sport Obsidian Black Pearl |
I posted earlier with pics of my hid fogs in yellow. They got too hot in the stock housing (causing slight melting, baaaad) so I finally custom fitted some HID bi-xenon projector lens w/angel eyes into the bumper. Took some time to make brackets, position it correctly and wire it so it worked the way I needed it. But I like how it turned out. I can actually USE the fogs now! Theyre at 6000k to match my headlights. Here is a shot of the DRLs w/the angel eyes on. (sry about the bad qual photo. Ill try to get some better ones of the lights when i get some time)
#1316 | |
Member#: 308400
Vehicle:2012 Imp Sport Pr. Dark Gray Metallic |
#1317 |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
The Newest member of our Family
![]() ![]() ![]() I was surprized to find out the car has the hill holder clutch thingy...meaning when u stop on a hill, you take your foot off the break and it holds the brake for up to 2 seconds or untill it feels the car starting to move forward. Good for the wife ! After Putting on some new rims, a light came on. "honey grab the book, check out what the squigly dick with balls light is !" " oh thats the tire pressure monitoring system light, what is that?" ![]() For anyone interested, I got it for base price, $17,495. The strake kit, side door ding moldings, exhaust tip cover and floor mats were an extra like 350 bucks. So with inspection and a full tank of gas it was JUST over 18 grand....not bad. DO not pay for ****ing delivery fees and all the bull****. The car rides absolutely FANTASTIC. Verry smooth acceleration. The 5 speed shifts like a typical subaru transmission (clunky as hell) But is a pleasure to drive. Its surprizingly faster than I had thought it would be. great car, the whole family is psyched ! ![]() My only quirk is the base model does NOT have cruise control ! This drives me nuts. Anyone know if there are any kits out there? I would love to just swap in the entire new steering wheel with controls and everything... Last edited by IllNastyImpreza; 08-11-2012 at 10:49 AM. |
#1318 |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
Hey I've been getting into modding my 2012 DGM Impreza and I thought I would post some pics. Ive gotten some 20% tints, Strake and Aero Kit, Sharkfin Antenna, K&N Box filter, Sti 19mm RSB. More to come as upgrades become available. Looks great, burns oil, and has a squeaky seat...but at least it looks good
![]() ![]() ![]() ![]() ![]() ![]() Last edited by gregorz4; 08-12-2012 at 10:21 PM. |
#1319 | |
Member#: 328223
SCIC
#1320 | |
Member#: 326540
BAIC
Vehicle:2012 Impreza MT SP DGM |
#1321 |
Member#: 317014
My friend has the ISM sport and it looks great with the aero splash guards but i think the RA guards look better on my DGM sport.
#1322 | |
Member#: 308400
#1323 |
Member#: 319171
Vehicle:2012 Impreza Spt Ltd Sky-Blue/Gray |
![]() impreza at mitchell point in the gorge by Happy McMaster, on Flickr Wow, such a beautiful view. Oh, the rocks are cool looking too.... ![]() |
#1324 |
Member#: 317014
Great shot!
#1325 |
Member#: 263485
Vehicle:2012 Imprez Spt Prem DGM |
Anyone smoke their tails yet? Tailights make the rear too cute for me lol
| Thread Tools | |
| Display Modes | |
| 07 Impreza 2.5i Special Edition Speakers *BRAND NEW* | Jonny07subie | Interior/Dressup/Audio & Security | 0 | 08-10-2007 03:13 PM |
| FS: LAMCO Boost Gauge (you know the stock one) | meridock | MAIC Private Classifieds | 7 | 04-30-2007 06:50 PM |
| What happened to Member #100,000 (You know... the guy from Sri Lanka.) | snvin | Off-Topic | 4 | 12-23-2005 01:02 PM |
| Hey Kosai, I saw you! (you know the drill, "not subie!") | RandyF | North West Impreza Club Forum -- NWIC | 16 | 04-26-2000 12:54 AM |
