Old 01-12-2013, 05:15 PM   #226
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
fender was 233 shipped from subarupartswarehouse
KeithS05RS2.5 is offline   Reply With Quote
Old 01-12-2013, 05:50 PM   #227
mrchyes
Member#: 294069
98 Forester
Green
ill have to check that out. thanks man! sorry again about your car
mrchyes is offline   Reply With Quote
Old 01-12-2013, 08:37 PM   #228
MGigantelli44
Member#: 234591
2004 STI
Sorry about your car dude. Just means you get to make it a little better
MGigantelli44 is offline   Reply With Quote
Old 01-12-2013, 08:47 PM   #229
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Thnx guys.
Pretty bummed still
But already making a shopping list
Gonna be gearing all my efforts to getting back ship shape as fast as possible
Old 01-12-2013, 09:07 PM   #230
mrchyes
Member#: 294069
98 Forester
Green
looks like its just new bumpers, and tail light. hopefully no frame damage
what happened anyways?
Old 01-12-2013, 09:32 PM   #231
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Bumpers, taillight, headlights, fender
No frame damage to the chassis, but the front fender/rad support framework will need to be pulled back out, which ive been told isnt that big of a deal
I was coming back from the mall, left hand turn after the light turned green, accelerating up to speed while still turning, back end stepped out on black ice right as I was entering the railroad bridge tunnel, panicked, over corrected right into the wall of the tunnel impacting the front drivers headlight area, bounced off making a complete 180 with the rear end impacting the wall again at the drivers side, came to a stop. Had that same old feeling of "Holy **** that did not just happen"
Old 01-12-2013, 09:38 PM   #232
mrchyes
Member#: 294069
98 Forester
Green
that sucks so much
id be interested in the passenger side headlight if its cheap. my housing leaks after taking them apart so much hah.
Old 01-12-2013, 09:40 PM   #233
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Originally Posted by mrchyes View Post
that sucks so much
All the shifting caused 2 of the 3 mounting tabs to snap on the pass. headlight as well
Old 01-12-2013, 09:42 PM   #234
mrchyes
Member#: 294069
98 Forester
Green
well damn
Old 01-12-2013, 09:48 PM   #235
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Yea, lots of carnage on this one.
Old 01-14-2013, 11:45 AM   #236
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So heres a better pic of the worst spot
You are looking from under the car looking right under the battery tray. You can see the inch to inch and a half of metal that collapsed "like its supposed to >:["
After looking at the picture for a bit I got sort of a brain blast. Im wondering if I can get my small floor jack or even the scissor jack from the trunk in between the two supports pointed out in the below pic if they will be strong enough to push it back out.
Im leaning toward they wont be strong enough, but its worth a try to save some money I think
Old 01-17-2013, 05:55 PM   #237
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got her inspected today
Old 01-17-2013, 10:23 PM   #238
mrchyes
Member#: 294069
98 Forester
Green
looks bad eekk
Old 01-18-2013, 02:37 PM   #239
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So I took the front apart to get a better look today
First I measured the fender "rails" and everything is fine there
Then I got a better look at the front. The crash bar took the brunt of the impact but that can be replaced, its just held in by four bolts and four nuts, the smashed side is going to be tricky though ... Im going to have to drill two access holes to get to the top bolt and nut since its now blocked by steel.
Here is the effected beam. Im really hoping this will be no prob for a body shop.
This is how shes sitting right now. I got kinda stressed so I walked away for a bit.
My plan is to put the body pieces back on later and deal with it till spring. Then take any money Ive saved on the side plus a chuck of my tax returns to a body shop and see what magic they can work.
If and when thats worked out then Ill start replacing the body panels
Old 01-19-2013, 01:32 PM   #240
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Put the bumper back on and gave her a name finally
Old 01-19-2013, 11:07 PM   #241
mrchyes
Member#: 294069
98 Forester
Green
i like the name not the meaning or the result
Old 02-02-2013, 07:08 PM   #242
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So I came up with a plan of action after thinking about it the past week or so (And before anyone says it, yea I know its not the smartest plan of action but whatever, it is what it is for now)
So ... the bumper doesn't fit right because the crash beam is crushed/bent. I cant replace the crash beam unless I straighten the end of the frame rail.
Sooooo ... Im just gonna remove the crash beam
Yes, yes I know, the crash beam serves a purpose and if I take it off and get hit in the front its bye bye radiator, and if its a bad accident its bad news for me, Ive thought that over, and I know.
So plan is: 1.) Remove crash beam
2.) Buy new headlights
3.) Buy new Tailight
4.) Buy STI replica front bumper
5.) Buy new splash guards
6.) Buy new Grille
7.) Buy new rear bumper (Maybe)
8.) Buy Coilovers
9.) Replace timing belt and extras
10.) Then if shes still running strong and I see a bright future with her, Ill have the frame rail fixed and a new crash beam put in
Somewhere in there also is get a winter tire setup for next winter which probably would have avoided this whole nonsense in the first place.
Old 02-08-2013, 07:58 PM   #243
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Good and bad today
Lifted her up to rotate the tires
Then got to work on that crash beam, opened up two holes and got to the covered bolt and nut out of the crash beam. Thats the good.
Then the bad, the last nut rounded out >:0
Kinda my fault I knew a box wrench was a bad idea but theres only about 3/4 to an inch of room between it and the back of the crash beam. I couldnt use a socket.
With only one nut holding the beam on I pulled it off the pas side studs and pulled it out, up, and down with all my rage hoping that "when in doubt, beat the **** out of it" might work ... but no.
So I put everything back together and Im going to sleep on it to try to figure out how to get that last nut off
Disappointing to get it that far and have to give up ... I was so optimistic I even ordered new headlights this morning
Pics to follow, just dont feel like uploading and whatnot right now.
Old 02-08-2013, 08:39 PM   #244
mrchyes
Member#: 294069
98 Forester
Green
stick in there man.. gotta get your car back to its self
Old 02-13-2013, 04:01 PM   #245
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Took it to a buddy
Air chisel FTMFW
Before:
After:
The Plan:
Old 02-15-2013, 02:36 PM   #246
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
This came today from Southwest Speed:
Old 02-16-2013, 12:06 AM   #247
02rhdsti
Member#: 285803
2006 Subaru
Grey
Nice man
02rhdsti is offline   Reply With Quote
Old 02-16-2013, 07:05 PM   #248
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Test fit
Like a glove, I think im going to spin it around with the side post terminal options facing the back when all is said and done
Old 02-18-2013, 03:57 PM   #249
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Headlights came!
Couple tweaks:
Old 02-18-2013, 04:12 PM   #250
mrchyes
Member#: 294069
98 Forester
Green
good idea on modding those lights!
remember, they are still halogen projectors though (pretty sure)
Springs for a 2005 Impreza 2.5RS rs05 Brakes, Steering & Suspension 22 11-01-2012 12:14 AM
2005 Impreza 2.5RS pros and cons? BradM Newbies & FAQs 33 11-30-2004 02:07 AM
2005 Impreza 2.5RS Wagon- Steel Wheels? oliverB Tire & Wheel 0 10-26-2004 10:24 PM
Fog light covers for 2005 Impreza 2.5RS Wagon? Subaru-aholic Private 'Wanted' Classifieds 4 09-29-2004 02:53 PM
2005 Impreza 2.5RS gets new "Sport" model Opie News & Rumors 10 04-30-2004 10:49 PM
