Old 02-18-2013, 04:27 PM   #251
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Yep
H3 bulbs for the projectors
Im going to install them and later on upgrade to an HID kit, I want a decent kit though so Im not in a hurry to upgrade right away
KeithS05RS2.5 is offline   Reply With Quote
Old 02-18-2013, 05:10 PM   #252
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Dismantled:
Old 02-18-2013, 05:55 PM   #253
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Paint done
Old 02-18-2013, 07:12 PM   #254
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Finished
Old 02-18-2013, 10:14 PM   #255
mrchyes
Member#: 294069
98 Forester
Green
looks good! makes me want them!
mrchyes is offline   Reply With Quote
Old 02-19-2013, 02:42 PM   #256
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Loosely fitted the battery tray today
Needed some tweaking:
Then went and picked up the hardware to mount the tray
as well as 1200 zip ties for 10 bucks from harbor freight!
Old 02-19-2013, 10:12 PM   #257
mrchyes
Member#: 294069
98 Forester
Green
lmao 1200 zipties
Old 02-20-2013, 08:13 PM   #258
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Friends pos civic was acting up again, bad idle and cylinder 3 misfire code.
She asked me to do her plugs and wires
Afterwards, idle was a little better, but still cylinder 3 misfire as well as cylinder 4 misfire, not sure whats up there. Made me happy though, I love working on cars, and doing work for other people means you dont have to pay for parts lol
Old 02-20-2013, 08:48 PM   #259
mrchyes
Member#: 294069
98 Forester
Green
lmao, and then you can call their car a POS
Old 02-20-2013, 08:59 PM   #260
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
it is lol
Exhaust has a hole in the middle, the auto tranny doesn't shift till redline, I replaced the calipers,rotors,pads,drums,and shoes and the brakes still vibrate when you step on the pedal, valve cover leaks like a mofo, exhaust smokes from either burning oil or coolant, you need two hands to move the shifter, key sticks 9 times out of ten in the ignition, high beams are low beams and vice versa, alternator is crapping out so it takes about 5 minutes for a window to go all the way down and back up
Just character I guess lol
Old 02-20-2013, 09:23 PM   #261
mrchyes
Member#: 294069
98 Forester
Green
hahahhaa , lots of character
Old 02-21-2013, 01:50 PM   #262
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Mounted the battery tray today
Im going to be putting a piece of sheet steel in the bottom of the tray so the battery wont be sitting directly on the bolt heads
Old 02-21-2013, 10:48 PM   #263
mrchyes
Member#: 294069
98 Forester
Green
i like that! but how are you going to get power wires to and from the battery? also does this make your alt. work harder?
Old 02-22-2013, 10:08 AM   #264
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Ill post pics when i run the wire.
And no it shouldt effect the alternator, could make the starter work harder but Im running a nice thick 2ga cable so it should be fine
Old 02-22-2013, 04:00 PM   #265
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Positive cable ... check!
Old 02-22-2013, 10:42 PM   #266
mrchyes
Member#: 294069
98 Forester
Green
probably gonna have to solder that
Old 02-23-2013, 08:18 AM   #267
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Nah, crimp tool + shrink wrap FTW with gauge wire this thick
Old 02-23-2013, 09:36 AM   #268
mrchyes
Member#: 294069
98 Forester
Green
ahh i see..
welll good luck!!
Old 03-01-2013, 11:20 AM   #269
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Neg. cable ... check!
Old 03-07-2013, 09:43 PM   #270
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Battery Terminals ... check!
Old 03-11-2013, 05:04 PM   #271
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Disty Block ... Check!
Old 04-03-2013, 04:27 PM   #272
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Have kinda been neglecting the car lately so I pulled it in the store to get a good look at everything.
Noticed a small amount of seepage next to the oil filter, not sure if head gasket leak?
Also noticed as you can see in the picture one of the header flange nuts worked its way loose, gotta figure out where to get one of those.
Also got some stuff for the battery relocation
- Battery
- Shrink Wrap
- Wire ring terminals
- Sheet metal and window/door sealer
- Circuit breaker (Ordered/on its way)
And A quick test fit for the battery in the tray
Old 04-05-2013, 05:06 PM   #273
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Circuit breaker .... check!
Old 04-07-2013, 07:02 PM   #274
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Not installed yet...
On another note:
I made a little box for the disty-block to keep it out of the elements once its installed in the engine bay.
Its rough right now, gonna hit it with some wrinkle black, gotta coat the inside of the cover with something non-conductive, and then figure out where the wires will be coming in from and cut holes for em
Old 04-08-2013, 09:12 PM   #275
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Finished up the box before install which should be happening this weekend
Wrinkle finish didnt really "wrinkle" I think I went too light on the coats
Springs for a 2005 Impreza 2.5RS rs05 Brakes, Steering & Suspension 22 11-01-2012 12:14 AM
2005 Impreza 2.5RS pros and cons? BradM Newbies & FAQs 33 11-30-2004 02:07 AM
2005 Impreza 2.5RS Wagon- Steel Wheels? oliverB Tire & Wheel 0 10-26-2004 10:24 PM
Fog light covers for 2005 Impreza 2.5RS Wagon? Subaru-aholic Private 'Wanted' Classifieds 4 09-29-2004 02:53 PM
2005 Impreza 2.5RS gets new "Sport" model Opie News & Rumors 10 04-30-2004 10:49 PM
