Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-11-2013, 11:54 PM   #276
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Took tomorrow and the next day off to do the battery relocation .... but I did it in 6Hrs today after work today lol.
Started by gutting the drivers side interior:
Found these under the carpet
Rusty Steel Balls:
Then Routed the Positive Cable
First behind the fender:
Then next to the drivers seat which conveniently had
these nice little holders lol:
Then I realized my starter cable was too short
So I made a new one:
Then hooked everything up to the disty-block which is mounted where
the old battery tray used to sit
KeithS05RS2.5 is offline   Reply With Quote
Old 04-11-2013, 11:54 PM   #277
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Then connected the ground
Sanded:
Installed:
To keep the wires in place in the corner of the trunk floor I actually drilled holes to run two zip ties to hold the wires snug. Then I applied liberal amounts of undercoating to seal it up:
Battery and circuit breaker installed:
The Leftovers:
Vid of first startup:
(My voice sounds weird lol)
Also anyone want to time their windows going up and down and compare it to this? I think it may be slower
I took it for a short drive to get the battery all charged up (Short because the drivers side headlight and fender are still off. Its funny how without the back seats in you can hear the fuel pump and the gas slosh around in the tank
Also (And I did notice this before the relocation, just think it may be a hair worse now) If the windows are up and headlights are on and I hit up on any of the windows the lights dim slightly and If I hold it it causes a ever-so-slight rough idle. Also happens to the lights when I step on the brakes but much less noticeable than when I do the window
So all thats left for tomorrow is to put the drivers headlight fender and side skirt back on, rear seats and trim back in, and trunk trim pieces back in
Old 04-17-2013, 05:07 PM   #278
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Ordered a new front bumper
Old 04-19-2013, 04:47 PM   #279
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Put all the trim back in the trunk:
And I got my weak 12V cordless drill upgraded for my birthday , these I will be using on the car tomorrow:
Old 04-19-2013, 06:52 PM   #280
Dpwhitehead1
Member#: 139996
2016 Silverado 1500
Deep Ocean Blue
It's clean my man. I wanna do the same
Dpwhitehead1 is offline   Reply With Quote
Old 04-19-2013, 07:14 PM   #281
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Dont lol.
It turns into an obsession, I already have plans to move the fusebox and disty block hidden insode the car to eliminate most of that wiring mess by the washer bottle. Oh yea and Im entertaining moving that to the trunk as well using an STI intercooler spray bottle
Old 04-22-2013, 04:13 PM   #282
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So Ive been getting an occasional squeak from the rear end that Im pretty sure is a sticky caliper. So I decided today after work to pull all the calipers and grease the slider pins and whatnot.
First I got myself a late birthday present:
Then I got to work:
Rear passenger, no problem
Rear driver, no problem
Even tightened up the adjusters in the rear so now my e-brake functions
Front passenger, no problem
Front Driver ... top bracket bolt snapped
After I looked at the picture after uploading it, this may not be to bad
If someone could tell me which part is threaded, or both, but Im thinking just the bracket is threaded which means
if I remove the bottom bolt then I can just punch the top sheared part out with the bracket
If they are both threaded then I have some drilling to do
Old 04-23-2013, 09:14 AM   #283
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
From what i see and remember from having done brakes you should be able todo the bottom bolt and that will pop off. I don't see any threads on it and i am certain when i did my brakes there were no threads. Just threads on the caliper
SnowWhite07 is offline   Reply With Quote
Old 04-23-2013, 09:27 AM   #284
mrchyes
Member#: 294069
98 Forester
Green
the bracket is not threaded
mrchyes is offline   Reply With Quote
Old 04-23-2013, 10:31 AM   #285
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Thnx guys, I ordered two OEM bolts, which btw were a pain to find
The other one is for the other front caliper bracket, someone at some point replaced the bottom bolt with some 19mm one and IM OCD like that
Old 04-23-2013, 02:09 PM   #286
mrchyes
Member#: 294069
98 Forester
Green
good call, it is no bueno if those bolts are the right ones
Old 04-26-2013, 02:03 PM   #287
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got the new bumper today:
Then ordered some bumper quick release hooks
Old 04-26-2013, 06:14 PM   #288
rich045
Member#: 210633
02 wrx
Then I got to work:
That happened to me before, i had my friend torch it at his shop and then use the reverse bit to take it off.
rich045 is offline   Reply With Quote
Old 04-27-2013, 05:25 PM   #289
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got a rough idea today:
Old 05-03-2013, 01:18 PM   #290
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Fender liners came:
Caliper bolts came:
Fender retainers came:
and did this and got all exited that Im just waiting on two more things to get here and I can get this **** put on:
Old 05-10-2013, 12:28 PM   #291
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got the last couple things I was waiting on
Lots o clips:
And new bumper/headlight/grille brackets:
Now I just gotta find time and get this new front end put on
Old 05-17-2013, 10:23 PM   #292
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Started operation un-crash-aru tonight:
Basically took the front end off, wired in the new headlights (Basically plug and play other than wiring in the halos which was a huge thumbs up to Spec-D), and wrapped my head around what I have to do tomorrow.
I cut off the top of the bumper supports to get a good visual of how much adjusting I need to do:
Pass side:
Drivers Side:
Vid of the lights:
Old 05-18-2013, 09:18 PM   #293
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got pretty much everything done today:
Whats left for the front end is to get and install a set of hood pins, unfortunately no matter what I tried the hood doesn't sit flat when I use the normal hood latch. Once the pins are in I can put the grille back in
Also tried to tackle the bracket bolt issue I ran into a while back. I swapped out the rando bolt that was on the passengers side:
But as for the sheared top bolt on the drivers side, nothing I tried worked to get the sheared portion out of the caliper bracket (Vice grips, penetrating oil, easy-out + impact, back drilling with a step bit.
Looks like Ill need a new caliper bracket. Im wondering of there are any foresters,outbacks,or legacys that share the same brakes cuz there are plenty of those at the local junk yard.
I also made a little tip video for getting stuck rotors off:
Old 05-18-2013, 09:31 PM   #294
mrchyes
Member#: 294069
98 Forester
Green
awesome work nice job! and congrats!!
Old 05-18-2013, 09:48 PM   #295
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Thanks man!
Old 05-18-2013, 09:50 PM   #296
mrchyes
Member#: 294069
98 Forester
Green
thanks to you i have a new fender waiting to be painted so i will have to get a nice drivers side pic posted here once i get it all done haha.
thats how it sits right now
Old 05-18-2013, 10:40 PM   #297
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
I like your choice of wheels! And I looks lowered, yes?
And what do you mean thanks to me?
Old 05-18-2013, 10:45 PM   #298
mrchyes
Member#: 294069
98 Forester
Green
you pointed me in the right direction through that website so i could find a nice priced new fender
also yeah, im on STi struts and road magnet springs
also have an entire ej205 rebuild in the works estimating around 350whp, going for the world record with a td04
Old 05-19-2013, 10:38 AM   #299
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Oh man, that sounds epic
Old 05-19-2013, 04:16 PM   #300
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Installed some hood pins today
Now I can stop having to zip-tie the hood down and can put the Grille back in
Not bad for some autozone specials
And before the ricer talk starts I have always considered hood pins ricer in most applications but I really had no choice here
Springs for a 2005 Impreza 2.5RS rs05 Brakes, Steering & Suspension 22 11-01-2012 12:14 AM
2005 Impreza 2.5RS pros and cons? BradM Newbies & FAQs 33 11-30-2004 02:07 AM
2005 Impreza 2.5RS Wagon- Steel Wheels? oliverB Tire & Wheel 0 10-26-2004 10:24 PM
Fog light covers for 2005 Impreza 2.5RS Wagon? Subaru-aholic Private 'Wanted' Classifieds 4 09-29-2004 02:53 PM
2005 Impreza 2.5RS gets new "Sport" model Opie News & Rumors 10 04-30-2004 10:49 PM
