Old 05-24-2013, 09:58 PM   #301
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Added some horsies under the hood
...and if you look closely, yea thats condensation in the left headlight
so I popped it back in the oven ans sealed up the lens seam with plenty of this:
Ill have to wait and see if I was successful
Also installed some hood pin lanyard cables. Its funny cuz I got these on ebay for $3.00 and when I noticed the packaging after opening the envelope they are the same ones autozone had on their shelf for $10.00
They were on all day, didnt feel em at all at first but they are really growing on me now:
KeithS05RS2.5 is online now   Reply With Quote
Old 05-24-2013, 11:09 PM   #302
mrchyes
Member#: 294069
98 Forester
Green
uhhhhhhhhhhhhh. get some quality hood pins
mrchyes is offline   Reply With Quote
Old 05-24-2013, 11:46 PM   #303
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Nah, these will do.
Wasnt looking to get a spendy set, just needed a better way to keep the hood down other than a zip tie...
Old 05-31-2013, 07:59 PM   #304
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Had a scary moment till I realized it was something stupid:
Got on the truway on my way home, hit 65 and ... SLAP SLAP SLAP SLAP!
Then nothing. Drove to my exit paid the toll, pulled over got down on all fours and inspected everything, all seemed fine.
Pull back onto the main drag, hit 60 and SLAP SLAP SLAP SLAP!!
Stopped at the light, turned right got to 60 and nothing
Stopped at the light, turned left got to 65 and SLAP SLAP SLAP SLAP!!
Pulled in my garage perparing to lift the front up and take the wheels off to inspected everything and then it dawned on me ...
The hood pin lanyard was slapping against the hood/headlight/bumper
Also greased and lubed my door hinges, all the unused doors were stiff and my drivers door started squaking loudly today
Old 05-31-2013, 09:03 PM   #305
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Ok so I was definitely wrong. Something is very wrong with the car. I headed back out to grab some stuff, got on the parkway and got up to around 65. Started getting a Bump, Bump, Bump, Bump kinda like when you drive over a bridge and hit the steal cross piece thingys, the the SLAP SLAP SLAP SLAP SLAP started in and as I came to the end of the parkway slowing to a stop there was some sort of hot smell ... maybe a hot metal smell I think, but Ive never smelled it before.
Turned back home after coming to a stop not getting over 40 and all seemed fine, except smelling the odd smell twice more.
I dont have time to look at it tonight but I have the weekend off so hopefully I can get this figured out before Monday
Old 06-01-2013, 11:37 AM   #306
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Ok so I think the slapping noise was just some damage to the under-tray in the front causing it to flap:
And since I already had the front up in the air and the drivers side tire off I decided to try to tackle that damn bracket again now that I bought a decent set of drill bits.
Broke half the smaller bits and burnt the tips to most the larger bits to no avail. So Im going to go ahead and just order a set of brackets for the front from a member over at rs25
Hopefully I can get em asap, Im paranoid driving with that bracket held on by 1 and 1/4 bolts
Old 06-01-2013, 10:26 PM   #307
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So the muggy heat today kept me down till:
By the time those kicked in all I had time to do was aim the headlights:
Cheap ebay headlights = cheap ebay cutoff. Im told however you can get into the projector assembly and modify the cutoff shield to a more sharper cutoff.
Then did some impromptu surgery:
Old 06-09-2013, 05:52 PM   #308
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Oil change today ... decided to jump on the T6 bandwagon
Then scanned my code, thinking I need to widen the spacer some more
Also got a ton of subie love out on the road today
Old 06-12-2013, 06:18 PM   #309
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Got a pair of front caliper brackets from a member over at rs25.com
Got to installing them and I think I figured out my sticky front drivers caliper situation. The rubber sleeve seems to have split and caused the slider pin to sit in the bracket rough
Installed:
Now I got worried as I went to put the wheels back on ... as I turned the wheel and the rotors spun there as a significant metal on metal grind. Not to be discouraged I continued on and cautiously took her for a drive, grinding sound went away after about 20 feet and the brakes feel fine.
I also opened up my O2 spacer a little more to 7/8 while I had the car jacked up, lets see if this does the trick
Old 06-17-2013, 07:06 PM   #310
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Annoying caliper is being annoying >:0
CEL popped back on, looks like Ill open the spacer up a bit more
Also noticed this today, you cant see the cracking straight on, but get at the right angle with the sun on the light and they light right up. Not sure if it was from baking/pulling them apart or if its just cheap plastic ... or both
Old 06-17-2013, 07:26 PM   #311
mrchyes
Member#: 294069
98 Forester
Green
cheap plastic :/ that sucks man
Old 06-24-2013, 07:02 PM   #312
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So I picked up a bushing kit to fix the worn out bushing on that one caliper slider pin:
Got the new sleeve on the pin and everything seems much better with the pins, however as I went to put everything back together I saw the reason why my calipers have been making noise after the new brackets:
Apparently the reverse p# lookup I did was false, bc according to what I dug up these should fit all 04-05 imprezas
But I shrugged it off and got to work on the new extra outlet mod Ive been thinking up, to use those two oem outlets I picked up at the junkyard
Wiring looks crazy lol, I need to pick up some more butt connectors to finish it up
Old 06-26-2013, 07:59 PM   #313
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Finished up the extra outlets
Just gotta get some more faux fiber to wrap the faceplate
Old 08-10-2013, 03:28 PM   #314
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Decided the need to get everything kosher again for the front brakes was more important than waiting to come across a good deal on a set of 4pots, so I ordered a stock set. And set to work...
How they always come from rockauto,
cheap silver coating and covered in a oily film:
After a scotch brite session and some brakleen:
Two light coats and one heavy coat of VHT Gold caliper paint:
Subaru caliper decals:
The finished product after two light coats and one heavy coat of VHT caliper clear coat
Old 08-12-2013, 06:56 PM   #315
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Picked up the rotors today
Old 08-14-2013, 09:35 PM   #316
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Anywho, got everything installed yesterday:
Old 08-31-2013, 08:17 PM   #317
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
So without the fog light inserts in my replacement bumper, you could see a lot of the rusted metal bits behind the bumper so I pulled it off today and hit all of it with some sprayable undercoating.
Also moved the horns and chirp thingy so you cant see them through the grille
Also made a bracket for my plate to mount it over the driver side opening, pass. side im going to use a fog light insert bezel for an air inlet (Props to the goldenfist for the idea)
Old 08-31-2013, 08:47 PM   #318
kminde04
Member#: 366904
04 WRX
Great build man.
kminde04 is offline   Reply With Quote
Old 09-02-2013, 06:50 PM   #319
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Thanks man!
Everything is still pretty basic, but Im hoping the spring is going to bring a couple of big things that Im exited about
Old 09-11-2013, 04:23 PM   #320
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Craigslist FTW!
Got a nice winter wheel/tire setup now, picked up and test driven today.
Old 09-19-2013, 12:32 PM   #321
Shecker141
Member#: 368756
2005 impreza
San remo red
Hey Keith, I'm looking to drop my 2005 2.5rs about 2 inches, what would you suggest be a good spring to get? And btw I'm just looking to get springs not the whole shock.
Shecker141 is offline   Reply With Quote
Old 09-19-2013, 12:58 PM   #322
enderx475
Member#: 368792
2002 WRX Wagon
I'm curious... I'm looking to get into Subarus, why the RS instead of the WRX?
enderx475 is offline   Reply With Quote
Old 09-19-2013, 02:26 PM   #323
Shecker141
Member#: 368756
2005 impreza
San remo red
The rs is cheaper and the insurance is way cheaper, at least for me because I'm 18, but it is a little lacking in power but the handling is surprisingly awesome.
Old 09-19-2013, 06:34 PM   #324
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
^^What he said. Basically if you can afford a WRX by all means get one. (dohc 2.0 turbo v.s sohc 2.5 non turbo) Other than the engine its basically the same car
Anyway, about lowering. Not too sure about springs, Im going with coilovers so ive only done research on those brands.
Eibach and Tein are always leading the spring market. Ive heard the name Swift thrown around on here as well.
And just so you know, in my personal opinion, if you have more than about 50k on the odo you should really get new struts as well. Stock struts arent made to ride low and will often blow when paired with lowering springs
Old 09-19-2013, 09:16 PM   #325
04EckoSti
Member#: 247135
2014 WRX
ISM
Originally Posted by KeithS05RS2.5 View Post
^^What he said. Basically if you can afford a WRX by all means get one. (dohc 2.0 turbo v.s sohc 2.5 non turbo) Other than the engine its basically the same car Anyway, about lowering. Not too sure about springs, Im going with coilovers so ive only done research on those brands. Eibach and Tein are always leading the spring market. Ive heard the name Swift thrown around on here as well. And just so you know, in my personal opinion, if you have more than about 50k on the odo you should really get new struts as well. Stock struts arent made to ride low and will often blow when paired with lowering springs
If it's an 06+ it's a 2.5 turbo
04EckoSti is offline   Reply With Quote
Springs for a 2005 Impreza 2.5RS rs05 Brakes, Steering & Suspension 22 11-01-2012 12:14 AM
2005 Impreza 2.5RS pros and cons? BradM Newbies & FAQs 33 11-30-2004 02:07 AM
2005 Impreza 2.5RS Wagon- Steel Wheels? oliverB Tire & Wheel 0 10-26-2004 10:24 PM
Fog light covers for 2005 Impreza 2.5RS Wagon? Subaru-aholic Private 'Wanted' Classifieds 4 09-29-2004 02:53 PM
2005 Impreza 2.5RS gets new "Sport" model Opie News & Rumors 10 04-30-2004 10:49 PM
