Old 06-09-2012, 01:09 AM   #51
Sikem2
Member#: 322644
How much did you pay?
Sikem2 is offline   Reply With Quote
Old 06-09-2012, 01:15 AM   #52
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Originally Posted by Joedubs View Post
Not sure it's a big deal and it's probably too late, but the wire going to the cig lighter probably isn't rated to power 4 aux devices. If you start popping fuses don't put bigger ones in, fuses are usually there as a way to prevent damage to the wiring due to too much current draw.
Well normally its just the radar detector and fm transmitter but I have noticed that when Ive got the gps going as well I notice that the fm transmitter gets funky, but no blown fuses, knock on wood.
For the tires? They were free in exchange for about 3hrs of digging to widen my managers driveway
KeithS05RS2.5 is offline   Reply With Quote
Old 06-15-2012, 07:31 PM   #53
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Decided to tackle a project Ive been wanting to do for a while now:
Cleared the amber out of the headlights and added some color to the bezels
lenses:
Assembled:
Some Shots:
Old 06-15-2012, 11:52 PM   #54
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
CarverSnell is offline   Reply With Quote
Old 06-16-2012, 12:22 AM   #55
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Thats funny lmao
But no, white ftw!
Old 06-16-2012, 01:07 AM   #56
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
I agree, I dont think it pulls off the white, I wouldve went black, but thats a cool project
Shipman is offline   Reply With Quote
Old 06-16-2012, 02:04 AM   #57
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
I think if you wanted to be different I would have color matched the headlights. That would look a lot better than random white headlight housings.
Old 06-22-2012, 05:50 PM   #58
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Little bit of a long update here
Found this on my doorstep today:
Everything is great except the fitment of the flange from the header to the midpipe, you'd think they would use the same sized flanges. (Looks worse than it is though)
Also think I might PnP (or whatever you would call it in this situation) the pipes that face the exhaust flow, its pretty bad
Was going to get a new spring bolt kit but ... duh ... dont need one now lol.
However, I do want new bolt for the flanges that bolt up to the heads, rockauto does not have these listed. Anyone know where I can get these?
Also there are three O2 sensor bungs, I need to plug one. What size plug am I looking for and any suggestions on where to get one?
Got some supplies too;
Thanks to TheGoldenFist for the tip on the paint-able stuff, Ive used the same but spray form and didnt like the coat quality.
So probably coating them tomorrow
Gotta so some math and order wrap and ties as well
Then I can get these bitches installed and get that clogged cat out of there
Old 06-23-2012, 03:43 PM   #59
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Finished grinding/prepping the midpipe. Than slapped on the High temp paint. Currently drying
Pics to follow
Old 06-23-2012, 03:46 PM   #60
Dpwhitehead1
Member#: 139996
2016 Silverado 1500
Deep Ocean Blue
Oh HAI GUY.
Dpwhitehead1 is offline   Reply With Quote
Old 06-23-2012, 05:38 PM   #61
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Hahaha, hey. Sent u a PM over at M247
...Ok so here we are with pics
Noticed that much of the fitment problem at the header outlet/HFCP inlet was due to the 2.5" piping at the inlet sticking past the flange and hitting the smaller flange at the outlet of the header
So I filled the gap with metal filler and then ground it down
Then I painted it with High Temp paint after prepping the surface with a scotch brite
And started the headers
First I filled the gaps with metal filler and ground the pipe edges down a bit
Then added liberal amounts of metal filler and let er dry
Then ground it all to a smooth angle
Not sure how the metal filler is going to hold up to the high temps but it is supposed to harden to metal strength, I mean this stuff was just as tough to grind down as the metal was. Anyway it was better than leaving it and worth the try to see what happens.
Ill paint the headers tomorrow probably and order wrap later tonight
Old 06-23-2012, 09:49 PM   #62
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Last Little update before bed:
Regretting not taking as much time to scuff the surface of the header before painting, as I was taking it off the hanger the hooked aprt snapped from me spinning it earlier as I was painting it ... my thumb grabbed part of the painted area to keep it from falling and slipped a big spot of paint right off
Maybe Ill see how much I can force off and re-do them while I wait for the wrap to get here ... *shakes head at stupid-ness of cutting corners*
Old 06-25-2012, 12:31 PM   #63
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Quick test fit with the paint dired for a couple days and wow such a better fit. Not sure why they thought it was ok to send the pipe/flange out like that but w/e
And the whole shot
Old 06-25-2012, 12:33 PM   #64
wayfasterthanyou
Member#: 303801
07 STI Stg2
Pearl White
Default change
Originally Posted by KeithS05RS2.5 View Post
So Ive been noticing that when in 5th gear at cruising speed, there is a jingling noise like loose change coming from the shifter
Got to work early today so I pulled the shift knob off ... and guess what ... it was loose change lol. 16 cents to be exact
Funny , this same thing happened to me !!
wayfasterthanyou is offline   Reply With Quote
Old 06-25-2012, 12:38 PM   #65
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
The coins thing is pretty funny.
Suprisingly, I like your CF wrap on the interior (I don't usually like CF-look stuff). The white headlights are also a nice touch, too many people paint them black (not just Subaru owners we're talking about either).
evilspoons is offline   Reply With Quote
Old 06-25-2012, 04:21 PM   #66
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
I like them but after having em on a while they are a bit too "lookie at me!"
Might color match em to the body
Old 06-28-2012, 02:45 PM   #67
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
aaaaand boom:
On a more positive note, this came yesterday:
Old 06-28-2012, 02:52 PM   #68
dascher1200
Member#: 296201
2016 WRX premium
Dark Gray Metallic
[quote=KeithS05RS2.5;37483008]aaaaand boom:
That blows! Just and FYI if you source used RBP replacement parts 2004 and 2005 are 2 different colors. The 2005 has a bit of a dark tint to it.
dascher1200 is offline   Reply With Quote
Old 06-28-2012, 02:55 PM   #69
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Hey thanks for the heads up
Im really quite bummed right now, egg all over my face. This is what happens when you try to show off in front of coworkers and a mailbox gets in your way.
Trying to source a new fender seems like its going to be a tall order too
Old 06-28-2012, 02:58 PM   #70
dascher1200
Member#: 296201
2016 WRX premium
Dark Gray Metallic
Oh my, might I ask what happened?
Old 06-28-2012, 03:03 PM   #71
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Simply got the wheels spinning and got it a bit sideways around the parking lot as it wraps around the store, over-corrected too much and swiped the 4x4 holding the mailbox. Splintered the 4x4, actually surprised there isnt more damage.
Old 06-28-2012, 03:09 PM   #72
dascher1200
Member#: 296201
2016 WRX premium
Dark Gray Metallic
The damage sucks but this makes me jealous in a way. I settled for a low mileage RS in automatic and definitely get mine to break loose unless its snow or gravel. I'm actually picking up an 02 bug eye in 5 speed to have fun with.
here's mine
Old 06-28-2012, 04:01 PM   #73
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Ill never go back to auto, this is my first 5-speed and I love it.
Oh and super jelly of the roof rack
Old 06-28-2012, 04:15 PM   #74
dascher1200
Member#: 296201
2016 WRX premium
Dark Gray Metallic
can you post some audio of your exhaust? interested to see how it sound on the RS.
Old 06-28-2012, 04:51 PM   #75
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Cat-back clip is on page one, and in other news
Got one step closer to getting the exhaust finished
To order or not to order wrap coating spray...
You an also see my wrap estimation skills leave something to be desired
Springs for a 2005 Impreza 2.5RS rs05 Brakes, Steering & Suspension 22 11-01-2012 12:14 AM
2005 Impreza 2.5RS pros and cons? BradM Newbies & FAQs 33 11-30-2004 02:07 AM
2005 Impreza 2.5RS Wagon- Steel Wheels? oliverB Tire & Wheel 0 10-26-2004 10:24 PM
Fog light covers for 2005 Impreza 2.5RS Wagon? Subaru-aholic Private 'Wanted' Classifieds 4 09-29-2004 02:53 PM
2005 Impreza 2.5RS gets new "Sport" model Opie News & Rumors 10 04-30-2004 10:49 PM
