Old 02-13-2012, 03:08 AM   #26
slovak
Member#: 168922
Originally Posted by Patrick L View Post
Okiedude collects old racers. It's an old dirt track. He's got some other cool stuff. I'll let him talk about them if he wants.
I got you, I have soft spot for older vehicles, trying to import my grandpas old Volga gaz21 from Slovakia to the US.
None the less have you made more progress on you track car? Also, what color is your Impreza?
slovak is offline   Reply With Quote
Old 02-13-2012, 07:37 PM   #27
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Na, took last weekend off to take it east and rest up a sort foot. Plus we had our region awards dinner Saturday night. The car is Blue Ridge Pearl.
Patrick L is offline   Reply With Quote
Old 02-21-2012, 01:31 PM   #28
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Got a bit more done last weekend. All the sound deadening is out now. Started prepping the floor and rear shock towers to get ready to weld in plate on the mounting points.
Found some unwanted stuff inside the rear quarter panels......RUST!
Here is how the interior looks as it sits now.
Old 02-21-2012, 01:38 PM   #29
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Old 02-21-2012, 04:17 PM   #30
ratt_finkel
Member#: 46218
06 EVO 9
That's awesome Pat! Are you still going to autocross?
ratt_finkel is offline   Reply With Quote
Old 02-21-2012, 10:00 PM   #31
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Yes, I'll still autocross it. Just need to finish it first.
Old 02-22-2012, 12:13 AM   #32
S13Silvia
Member#: 135522
2001 RS2.5 Coupe
BRP
The rules in Improved Touring, no. I have to keep the original panel. I can clamp or weld it in place. Now, Super Touring, it's probably a different story.
I was going to use the studs on the bottom off the panel and take some aluminum bar stock and clamp it in place since there is a lip for the panel to rest on. Plus you some RTV to seal it too the roof so it don't leak.
Are you allowed to strip off the sunroof panel framing so that you are only left with the skin?
If you can do that, then that would eliminate most of it's weight.
Mark
PS: I got some P90X vids that would help you eliminate 40-60lbs of dead weight and you wouldn't even need to touch the car. LOVE YA BRO!
S13Silvia is offline   Reply With Quote
Old 03-03-2012, 01:00 PM   #33
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
No photos today but weighed the car and removed some more out of the car. Right now with the dash thrown back with with the driver seat and other needed parts. 2473 lbs. Add about 100lbs for the cage and myself. I am getting closer to my min weight at 2660lbs. I got a few more places to drop weight easily.
Old 03-03-2012, 06:12 PM   #34
vicious_fishes
Member#: 158864
2003 SOHC destroker
IMO pull as much weight as you can and then add what you need to in the footwell of the rear seats.
if you can't reduce it you can still move it right?
vicious_fishes is offline   Reply With Quote
Old 03-03-2012, 11:53 PM   #35
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I got it covered.
Old 03-04-2012, 09:01 AM   #36
okiedude
Member#: 37736
2003 WRX Race Wagon
Wish my wagon was that light! I think you + cage will be more than 100lbs., unless you went on one hell of a workout program in the last two weeks-LOL!
okiedude is offline   Reply With Quote
Old 03-04-2012, 01:00 PM   #37
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I was saying just the cage about 100lbs. Me on the other hand is a different story.
Old 03-20-2012, 01:50 AM   #38
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Getting started
Took the heater core out of the heat and air unit to use with the dash to have a defroster in case of a wet race or I am at a cold event. I'll have some shut off valves for the hot days when I don't need it.
Old 03-20-2012, 12:09 PM   #39
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
looks good man, hurray for gc race cars!
012.5RS is offline   Reply With Quote
Old 04-01-2012, 01:44 PM   #40
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Main hoop and rear down tubes all done. They were going to finish welding up the hoop last night. They are going to start on the A pillars, door bars and halo tomorrow.
Old 04-01-2012, 10:03 PM   #41
TrunkMonkeyManiac
Member#: 175898
2002 Impreza
Subscribed, looking good, can't wait to start my own project.
TrunkMonkeyManiac is offline   Reply With Quote
Old 04-02-2012, 12:30 AM   #42
misterwaterfallin
Member#: 101091
Why did you choose to make your own cage rather than get a kit? I imagine there are some decent kits out there for the gc no?
misterwaterfallin is offline   Reply With Quote
Old 04-02-2012, 09:29 AM   #43
okiedude
Member#: 37736
2003 WRX Race Wagon
I think because he wants a "Real" cage, and he has access to one of the best cage building duos in the Southwest.
Old 04-02-2012, 06:33 PM   #44
Colin60
Member#: 272033
2003 PSM WRX
BUGStuned
bolt in cage kits are generally trash
Colin60 is offline   Reply With Quote
Old 04-02-2012, 06:53 PM   #45
misterwaterfallin
Member#: 101091
You guys do understand that you can also get pre bent/cut kits right? Something like this: http://www.customcages.co.uk/Rollcag...ype=Int%20GrpN
That takes all of the bending and majority of the cutting out. Just cut to fit, notch, and be done with it. If you wanna build your own that's cool, I was just curious why you would do that as it's usually much more labor intensive
Old 04-02-2012, 11:12 PM   #46
okiedude
Member#: 37736
2003 WRX Race Wagon
That British kit is no bargain by the time you factor in freight/exchange rate and you still have to pay someone to do all the Tig/Mig welding. The welding portion is really more labor intensive. When you have the proper tubing notcher/bender/ protractor/levels/CNC plasma cutter; bending and cutting the actual components is not too bad. Plus they can walk 50 ft. across the shop floor and use my cage as a pattern (which these buys built also).
Old 04-03-2012, 08:59 AM   #47
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I want the cage built in a certain way. Mainly to the rules I am going to run under. It can only be 8 points and can't tie into the chassic on the pillars or floor except for the 8 point. Plus you can't trust these pre made cages to fit right.
Old 04-03-2012, 12:27 PM   #48
wtyree
Member#: 29879
2002 WRX Wagon
subscribed
wtyree is offline   Reply With Quote
Old 04-04-2012, 12:38 AM   #49
BOXER_4_Life
Member#: 274404
Subscribed and Good Luck with your build
BOXER_4_Life is offline   Reply With Quote
Old 04-06-2012, 10:21 PM   #50
rallyx12
Member#: 315983
nice car man
rallyx12 is offline   Reply With Quote
My 2.5RS Rally Car Build...! Rallycarperson Member's Car Gallery 162 04-30-2011 03:05 AM
2.5rs sohc build gc8v6 Built Motor Discussion 4 08-26-2010 10:34 AM
N/A 2.5rs motor build, pistons question brian3676 Built Motor Discussion 7 04-14-2008 02:06 AM
My 2.5rs gd6 start/build. midnight2.5rs-t Normally Aspirated with bolt-on Forced Induction Powertrain 0 10-19-2007 09:05 PM
What color to paint my 2.5rs bumper that is going on my OBS FlooredSubaru Interior & Exterior Modification 0 06-01-2002 06:03 PM
