Old 01-24-2012, 12:50 AM   #1
neimadnosrap
Member#: 302324
2015 STi
Default AP stage 2 acn tune help
Hey i just upgraded to stage2 and i ran this log after i was running it for a week.
I was just wondering if you guys can take a look at the log and tell me if it seems everything is running ok. I havent had any problems and i followed cobbs video but i'm still kind of a noob when it comes to reading the log.
Thanks for the help
2011 wrx sedan
https://docs.google.com/spreadsheet/...GtlUGx4U2hFRmc
neimadnosrap is offline   Reply With Quote
Old 01-24-2012, 09:57 AM   #2
Cobb Tuning
Member#: 4803
Thanks for the help
2011 wrx sedan
Log looks good. You are underboosting a little, but not too bad. Your load is a bit high for a stage 2 WRX. Are your outside temps really cold there? Sometimes excessive load can indicate a boost leak, but your long-term fuel trims look OK. I would at least double check the intake tract for leaks especially if you pulled off the intercooler to install the downpipe (a pressure/smoke test would be a good idea)
Bill
Old 01-24-2012, 10:21 AM   #3
neimadnosrap
Member#: 302324
2015 STi
Yeah it was really under boosting before so I had to use the HWG map. Where can I go to run a test like that to see if I'm leaking anywhere?
Old 01-24-2012, 10:21 AM   #4
neimadnosrap
Member#: 302324
2015 STi
It's been cold lately but cold for San Diego CA.
Old 01-24-2012, 10:27 AM   #5
neimadnosrap
Member#: 302324
2015 STi
I live in ca so it's been a little cold here for San Diego. I did do the test in the morning right after the engine heated up for about 5-10 min. Do you think that could have caused that issue??
Old 01-24-2012, 10:47 AM   #6
Nairb336
Member#: 144642
2006 6spd Wagon
SGM
clark turner, he's a member on here and his maps are worth the tune. He did a great job on my map and I have never had any issues. http://www.clarkturnertuning.com/
Nairb336 is offline   Reply With Quote
Old 01-24-2012, 10:53 AM   #7
Cobb Tuning
Member#: 4803
You can make your own pressure tester and use an air compressor to test (search for DIY pressure tester). You can also see if you have a local shop that has a smoke machine for testing intake tract leaks. When you pull the intercooler off, the most common source for a leak is the BPV, especially if you re-used the gasket. If you did, get a new one and torque the BPV bolts to spec. Also check for loose clamps (although don't overtighten).
Bill
Old 01-24-2012, 11:07 AM   #8
neimadnosrap
Member#: 302324
2015 STi
I'm just going to replace the gasket since that should be cheap. I can't seem where to find one online. I am on my phone but if you could throw a link up for a stock bpv gasket I wouldn't object
Also I can keep driving my car with this issue right? It's not going to hurt anything correct?
Old 01-24-2012, 12:27 PM   #9
neimadnosrap
Member#: 302324
2015 STi
I forgot to also mention i'm running a catless dp with the tune could that be causing the problem you are seeing?
Old 01-25-2012, 10:14 AM   #10
Cobb Tuning
Member#: 4803
No, catless won't impact it. It is just a guess at this point. The load looks a little high for a stage 2 WRX, but it could very well be that high for your particular car. The best indication of a leak would be your long-term fuel trims (A/F Learning 1). They look OK in your logs, but they are reset when you install the AccessPORT, reflash a map, reset the ECU via AccessPORT or disconnect the car's battery. So, it would depend on how long you've been driving since you performed any one of those procedures. I would drive for about a week without performing any of those and then check your A/F Learning 1 A, B, C, D values. They should generally be within +/- 5% with any outside about +/- 8% may indicate a problem.
Bill
Old 01-25-2012, 11:40 AM   #11
neimadnosrap
Member#: 302324
2015 STi
here is the log i ran last night, its been about 2 or 3 weeks since i ran the first one i posted.
https://docs.google.com/spreadsheet/...UNZdDY2ZFdna3c
Old 01-25-2012, 12:35 PM   #12
Cobb Tuning
Member#: 4803
You have a borderline value for one of the long-term fuel trims. Being that it is negative and given the high load that is reported, I would say there's a chance that you have a boost leak. Best way to determine this would be via a pressure or smoke test. There's some DIY instructions on Nasioc for creating your own pressure tester (if you have an air compressor) and some shops can do it (or can smoke test the intake tract).
Bill
Old 01-25-2012, 01:57 PM   #13
neimadnosrap
Member#: 302324
2015 STi
Thanks for all the help. I'm replacing the TMIC next week so do you think I will be ok till then?
Old 01-25-2012, 03:34 PM   #14
Cobb Tuning
Member#: 4803
Yeah, you'll be fine. There may not even be a problem.
Bill
Stage 2 Acn Map Or Stage 2 91 Oct? 07subie Southern California Impreza Club Forum -- SCIC 8 09-24-2007 12:45 AM
Ap Stage 2 and Pro tune EJ2point0 AccessPort 2 10-01-2006 07:28 AM
AP Stage 2 CA 91 map tuned down that significantly? sandwi54 Engine Management & Tuning 4 02-06-2006 07:11 PM
Help! Installed DP, AP Stage 2 and no boost, stalls! idkew Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-20-2005 04:48 PM
AP stage 2 help brex16 Engine Management & Tuning 21 08-04-2005 06:52 PM
