Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-24-2012, 09:38 AM   #1
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
Default Question on ABS Sensors
ok so my wifes car, 98 toyota avalon, has had an ABS light on since her struts got changed out. i did their little troubleshoot thing and got a code 34 which is the left rear wheel speed sensor. i pulled out her seat to ohm the connection for the sensor and got nothing, its showing open. i checked the other side, right rear, just to verify i could get a reading and i did. this should pretty much tell me i need to replace the sensor correct? just want to make sure before i get one cause they're pricey
Jncominco2 is offline   Reply With Quote
Old 01-24-2012, 10:00 AM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
check the wires on the left rear and see if anything is messed up.
bhhamblin is offline   Reply With Quote
Old 01-24-2012, 11:32 AM   #3
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
well its kinda hard to check the wires themselves since its got a coating on them. the plug that i got an ohm reading on only goes to the sensor and right back, no where else. id be worried if i cut the coating off that it would get ruined later on
Question on O2 sensors and headers rbahr Built Motor Discussion 15 06-20-2011 02:34 AM
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else? kirbykirb Legacy Forum 4 06-19-2010 10:37 PM
abs sensor line on agx's on gc rs. Blase Brakes, Steering & Suspension 1 10-12-2008 02:31 AM
Advice needed on ABS sensor problem AccidenT Brakes, Steering & Suspension 1 08-18-2005 06:45 AM
Question on knock sensor hesitation! Help. klmbnhgh Service & Maintenance 2 04-13-2004 10:46 AM
