Alaskan Impreza Club
Old 01-24-2012, 02:33 PM   #1
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
Default Moving later this year...
So it looks like I will be moving to Wainwright around Sept. I am really looking foward to living up there and meeting some of you guys. Any tips or things we should have before we come there? please dont say a jacket..
faSTI666 is offline   Reply With Quote
Old 01-24-2012, 03:38 PM   #2
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
A Parka?
Seriously though... welcome to moving to Alaska, being up in Fairbnaks there are LARGE temperature swings, from mid 90's in summer to -50's in winter.
September shouldn't be too bad, but I'd start getting your car ready for the Fairbanks winters. Might do a search in the AKIC as we have recently had a few threads of people moving here.
Car wise, I'd recommend getting a block heater and/or an oil pan heater. A battery warmer would be beneficial as well and helps keep the battery "fresh" and utilize ALL its cranking power (though some have reported the battery eating the heater). You'll need winter tires of some sort for the winter, and will have to change the coolant mix to a colder blend. I forgot the exact ratio, but was like 60/40 or some such.
Other than that it is more or less like living anywhere else, aside from higher prices and it gets a touch colder. Fairbanks especially.
AKSubie is offline   Reply With Quote
Old 01-24-2012, 04:05 PM   #3
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
No battery heater needed
cosseywrx is offline   Reply With Quote
Old 01-24-2012, 07:31 PM   #4
siamiam
Member#: 129469
93 automatic Miata
black
wainwright village or FT Wainwright?
car wise what aksubie said oil pan heater, block heater is a must , dedicated winter wheels etc
looks like you will be coming here at the start of winter, a thick winter coat, thermals help out a lot
siamiam is offline   Reply With Quote
Old 01-24-2012, 08:00 PM   #5
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
I will be headed to Ft Wainwright. I will probably get a place in fairbanks or north pole. Any areas we should avoid? Are there any local websites or publications that would list rentals up there? Im already on track for winterizing the cars. You guys know of any type of transmission/ fluid warmer. Here in Mass my trans gets very tight feeling and doesnt like to go into gear or shift when temp is around zero or colder until it warms up a mile or so down the road. Do you guys have to worrk about the local fuzz and mods on your cars? Also you guys only have 90 octane? Anyone know if ft wainwright has 93 or 90 also?
Old 01-24-2012, 08:53 PM   #6
siamiam
Member#: 129469
93 automatic Miata
black
http://classifieds.newsminer.com/
http://fairbanks.craigslist.org/
the local papers website and criagslist have some ads for places to rent or buy
ive used a transmission pad heater on a few of my cars
there are no emission test here and the cops are not too bad they seem more concerned about catching drunks then people in to the local car scenes
http://www.fairbanksforum.com/phpbb3/index.php
local forum
most people get along up here, they don't care about what you drive or how old you are as long as you are cool and just want to hang out
too bad your going to miss the 24 hours of daylight this year
the highest octane up here is 90 so if you need to either mix your own fuel or go with a meth kit
Chevron down the street from me is $3.91 for 87 octane
Old 01-24-2012, 10:37 PM   #7
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
You should consider a quality autostart too. You may find it cheaper to get a good one installed in the lower 48 than here in Alaska.
bjcarter2 is offline   Reply With Quote
Old 01-24-2012, 10:51 PM   #8
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
I would get one here, just for warranty issues.
LiLpNoY is offline   Reply With Quote
Old 01-25-2012, 12:27 PM   #9
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
As far as the 90 octane goes I can reflash my car but my wifes FXT is stock. Being that the manual reccomends 92 octane or higher what should I do. Do the subarus sold up there have different ecu settings from the factory than in the lower 48? Her car will stay as stock as possible.
Old 01-25-2012, 01:27 PM   #10
AKSubie
Member#: 6214
01.5 Audi S4
I know JordyB, Carter and Seth could tell you more, BUT.. if you keep your wifes car stock and dont romp on it too badly I think 90 with the stock programming should be fine. The car will adjust a bit to run the 90 instead of its programmed 92.
FWIW, There are quite a few Subaru's up here, turbo and non, and I'd be willing to bet a vast majority do not use meth, torco or any other additives. And by vast majority, I am speaking of the FXT/OBXT/LGT/BAJAXT camps. Heck, I'd even be willing to bet many of those OBXT/BAJAXT people dont even use premium.
Old 01-25-2012, 01:37 PM   #11
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
^ Correct answer. Same goes for all the places using 90/91 octane in the Lower 48. The car will learn if it encouters any knock, the stock system is quite robust in that area.
retrac is offline   Reply With Quote
Old 01-25-2012, 02:35 PM   #12
fightnhawaiian
Member#: 299648
05 Sti
Cgm
The down grade in gas was a issue for me, I was lucky enough Pdx came down to Hawaii before I shipped the car and retuned for 90
fightnhawaiian is offline   Reply With Quote
2010 Volvo XC60 R-Design Revealed, Coming To Aus Later This Year AVANTI R5 Non-Subaru News & Rumors 4 07-07-2009 09:43 AM
Ford and Honda CEO expect auto sales to rebound later this year AVANTI R5 Non-Subaru News & Rumors 6 05-19-2009 11:48 AM
STI Limited Sedan Later This Year? Jon [in CT] News & Rumors 117 02-26-2008 09:18 PM
Safety: Let's see how the Impreza does later this year... DTECH-WRX General Community 9 03-08-2005 09:09 PM
Moving to Hawaii later this year - I have a few car-related questions Patrick Olsen Hawaii Impreza Club Forum -- HIIC 26 10-07-2002 04:34 PM
