Old 01-25-2012, 02:38 AM   #1
iMPoRT GeeK
Member#: 216182
2008 WRX
Question 2008 WRX TD06H 20G 8cm- Mustang Dyno
2008 WRX
Perrin CAI
Perrin Turbo Inlet
Kinugawa TD06H 20g 8cm IWG
Grimmspeed EBC (3 Port)
FMIC
3" Catless D/P
2.5" PRE Prototype Catback
UEL Header & Uppipe (1 piece)
750cc Injector
255L Walbro fuel Pump
Cobb AP, dyno tuned
20 psi
Mustang Dyno - Tuned by Mike @ GST
304.4 HP
301.9 TQ
Why do I have So MUCH LAG? I don't hit full boost till 4500-4650 rpm... Is that normal???
iMPoRT GeeK is offline   Reply With Quote
Old 01-25-2012, 03:53 AM   #2
KpT KiM
Member#: 242422
picture isn't showing up for me. is it for others?
KpT KiM is offline   Reply With Quote
Old 01-25-2012, 04:45 AM   #3
blame
Member#: 226359
2006 WRX
obp
No pic for me either.
Have you thought about a 3-port EBCS? Is the turbo IWG or EWG?
-sean
blame is offline   Reply With Quote
Old 01-25-2012, 09:23 AM   #4
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Was the intake Mani taken off before the tune? Check for vac/boost leaks in intake Mani. The inlet . And ant ic piping u have. What bpv are you using
BlackFighter is offline   Reply With Quote
Old 01-25-2012, 11:01 AM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
why don't you ask your tuner instead of us?
Old 01-25-2012, 09:17 PM   #6
iMPoRT GeeK
Member#: 216182
2008 WRX
Question
Sorry I forgot to list that I have Grimmspeed EBC (3 port)
Intake Manifold was never taken off...
UEL Header & uppipe (1 piece)
Tuned by Mike @ GST
Its Kinugawa TD06H 20g w/ 8cm IWG
Tuner(Mike) said its the Turbo BUT I talk to the guy ("engineer") where I got my turbo and he said its the Tuning. Idk which way to go...
Can you see now???
Old 01-25-2012, 09:43 PM   #7
kakarot09
Member#: 182375
08 Sti
Wrbm
still can't see the picture. the td06 20g's always seem to spool late to me. They just make more power up top. The tune will impact the spool but if you're looking for 1000rpm better spool it isn't going to happen. Tuning has a smaller effect on the spool. I don't have any other kinugawa dyno plots to compare to but the first one I found of a blouch td06 had peak torque at 4300. Yours is slightly slower. Could be tuning, could be the turbo, could be both. Mike has tuned a lot of cars though I doubt it's much in the tune. Have you seen his time attack car?
kakarot09 is offline   Reply With Quote
Old 01-25-2012, 10:21 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
it's a kinugawa turbo, all signs point to that.
Old 01-25-2012, 10:23 PM   #9
2011boostdwrx
Member#: 263470
Because you have a 20G w/8cm hostide. This is why I went with the HTA68 8cm hostside and I have an FMIC and i still have more lag then the previous VF52. As above nothing has improved my spool in the tune, the only thing that might work is MEth injection and higher timing but maybe that would increase spool 100-200 rom earlier. I am also using the PNP GS exhaust manifolds.
You are stuck where u are for spool, i would guess.
2011boostdwrx is offline   Reply With Quote
Old 01-26-2012, 04:24 PM   #10
iMPoRT GeeK
Member#: 216182
2008 WRX
Question
see, I don't really mind the lag as long as i have power top end. But its ONLY 301hp! I was hoping to get over 350 close to 400 with the 20g...???
Anyone else with a 20g? have a dyno sheet that like to share???
I've seen other 20g that made over 350+hp easily... but I'm ONLY at 301!!!
Would another tune help? From some other tuner???
Who do you recommend in the bay area?
Old 01-27-2012, 01:19 AM   #11
kakarot09
Member#: 182375
08 Sti
Wrbm
What does a stage 2 Sti make on that dyno? I've heard mikes dyno reads lower than most. 301 does seem low though. Did you ask mike about the tune? 20psi is pretty safe. If you want to push it more you could ask him to do so and see what he says. Do you have an egt gage? If not he may not feel comfortable pushing it harder. I know the forum is the first place you want to come ask other opinions but it would be good to talk to your tuner about it all. I talk to mike once in a while and he would much rather have your car safe than blow it up.
Old 01-27-2012, 06:53 PM   #12
Need BB
Member#: 66103
2005 Legacy GT Wagon
While
Something doesn't seem right. I have a Kinugawa TD05H 20g 8cm EWG on my LGT wagon and boost is great. I make 18PSI by 3400 which I thought was great for a turbo this size. I have not dynoed the car, but I am only running 18.5PSI of boost but with Virtual Dyno it is making decent power.
Need BB is offline   Reply With Quote
Old 01-28-2012, 03:01 AM   #13
iMPoRT GeeK
Member#: 216182
2008 WRX
Question
That is weird... Are your using the stock style turbo housing where theres a flange on the turbo outlet or do you have the sti style housing???
FMIC or TMIC?
I have the TD06 and yours is a TD05 , is that make a different???
LMK
thanks
Old 01-28-2012, 11:20 AM   #14
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
You should search for Mike at GST and find out what baselines and similar set ups are putting out on his mustang dyno. NeedBB should feed his log into the virtual dyno on the Mustang setting instead of the Dynojet setting and see what he come up with. Makes a noticeable difference.
theotherguy is offline   Reply With Quote
Old 01-28-2012, 12:48 PM   #15
kakarot09
Member#: 182375
08 Sti
Wrbm
^^ definitely agree. Also yes the td05 and td06 makes a difference. The td06 will support more flow than a 20g compressor will flow and it lets the 20g make slightly more power up top but as you see, at the expense of spool. Does it spool the same on the street in 3rd gear?
Old 01-28-2012, 12:49 PM   #16
pearl08
Member#: 282356
2008 wrx
I have an 08 wrx with the vf52, invidia dp and cat back exhaust, turbo xs cai, turbo xs 50/50 bov, Grimmspeed 3 port. Im at three hundo hp 340 tq. You should have more then what I got
pearl08 is offline   Reply With Quote
Old 01-28-2012, 12:55 PM   #17
kakarot09
Member#: 182375
08 Sti
Wrbm
I'm guessing yours was not dyno'd at gst so comparing numbers is difficult at best. Haven't you noticed the huge differences in power from different dyno's?
Old 01-28-2012, 01:15 PM   #18
ROFLBOXER
Member#: 188503
2003 Built EJ257 WRX
2.5xtr+W2A IC
Don't focus on numbers. Does it feel faster? Is it running smooth? Those are the big deals. If you're really worried about numbers look at how much more you are making than a stock car on the same dyno.
FWIW I just blew up a TD05 20g running 22psi on a custom liquid intercooler setup, as well as Kelford 264 cams. I was supposedly only making 285awhp, but that was on a mustang that's been shown to read very low. If I went to a different dyno it could very well have been 350. The car felt like an absolute rocket.
ROFLBOXER is offline   Reply With Quote
Old 01-28-2012, 02:20 PM   #19
pearl08
Member#: 282356
2008 wrx
Ya that's true mine was on a different dyno with a different tuner. The power I gained is a good amount. Pushing 18.5 psi. I still have the stock tmic so we couldn't push it anymore.
Old 01-28-2012, 08:51 PM   #20
iMPoRT GeeK
Member#: 216182
2008 WRX
Talking
so now i need to re-tune on a different dyno? Does anyone know a good tuner in SF-Bay Area...
See, this is what I hate about letting someone else tune my car. I don't know what they did...??? I have COBB AP, wideband a/f & open road. Can't I do it myself??? Please help with info...(sorry for off topic) If there's a way, please show me, I can do it...
Thanks...
Old 01-28-2012, 10:24 PM   #21
2011boostdwrx
Member#: 263470
I am making 318whp w/the HTA68 on my11 on a very low reading mustang dyno.
Old 01-28-2012, 11:01 PM   #22
Need BB
Member#: 66103
While
I would track down why you are spooling so late. You should be hitting around 18psi by 4K with that turbo. You can self tune google subaru tuning guide.
Old 01-28-2012, 11:20 PM   #23
theotherguy
Member#: 191514
'05 FXT 6spd, 98
No, you just need to find out what the baseline of the gst dyno is. A quick check yielded 220 on a stock 08 sti, 210 on another, saw a rotated 30r at 335, an 18g in the 290's, etc, etc...
Haha, guess what I did last weekend...
td05 20g blew bad and it couldn't be rebuilt, I replaced the blown chra with a kinugawa chra and it spools really well on an ej255 with ej25d heads. AWIC too.
Old 01-29-2012, 01:56 PM   #24
ROFLBOXER
Member#: 188503
2.5xtr+W2A IC
Nice awic man! And you're having good luck with the kinugawa? I've been trying to figure out what turbo to replace mine with.
/Thread Derail.
Old 01-29-2012, 02:44 PM   #25
kakarot09
Member#: 182375
08 Sti
Wrbm
Thanks...
Don't need another tune or tuner yet. Did you talk to mike about it? You can log your car with the accessport and see what it makes on an airboy dyno spreadsheet. That would be a good starting point also. Just start at 2000 rpm and floor it to redline. Then you can compare numbers from a road dyno.
2008 WRX Stock vs. Stage II dyno tuning Dyno Flash Proven Power Bragging 41 08-29-2012 10:05 PM
2002 VF43'd 2.0L WRX makes 284/274--On Mustang Dyno Claymra Proven Power Bragging 21 06-08-2010 02:57 PM
2009 WRX Numbers on a Mustang Dyno wrxphantom Proven Power Bragging 50 09-30-2009 10:36 PM
Ultimate Racing 2008 WRX CAI + Turboback Exhaust + FMIC DYNO Results Ultimate Racing Proven Power Bragging 80 07-16-2008 02:19 AM
02 WRX - TD04 - Mustang dyno - PDX Protuned 02WHITEDUB Proven Power Bragging 13 07-25-2006 02:10 AM
