Old 01-29-2012, 07:32 PM   #26
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Originally Posted by ROFLBOXER View Post
Nice awic man! And you're having good luck with the kinugawa? I've been trying to figure out what turbo to replace mine with.
/Thread Derail.
So far so good with the kinugawa chra, for $400 shipped new, its hard to beat and the car runs great. I've had good luck with the kinugawa/kamak stuff, my brother-in-law is at 30k miles on his 20g in a legacy gt. I'm going to run a 60-1/td06sl2 built from kinugawa parts this spring.
Hopefully the OP will have the same durability with his turbo.
theotherguy is offline   Reply With Quote
Old 01-30-2012, 05:15 PM   #27
pooster.online
Member#: 120461
2004 WRX STi JBP
2.5" catback could be holding you back a bit.
pooster.online is offline   Reply With Quote
Old 01-30-2012, 11:52 PM   #28
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Although i do agree with this, I do not think that think this is the reason he is only making 301. But OP, you should consider getting a 3 inch CBE, you have a 3 inch downpipe going to a 2.5 inch cbe? does not make much sense. it is def restricting the exhaust flow. Getting a 3 inch cbe may free up a few hp.
But i think there may be a different reason you are making that low of numbers. Correct me if im wrong but other people with the same or similar setup are making around 330-350 at the wheels.
07ImprezaMB is offline   Reply With Quote
Old 01-31-2012, 07:43 AM   #29
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
OP, your tune is on 91 pump gas, right? You forgot to mention this....
On 91, with a TD06 and on a Mustang dyno, your results are normal, I think.
Old 02-01-2012, 09:19 AM   #30
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
This^^^. I bet you make closer to 330 on 93 and some tuning adjustments.
2Fast4U1DAY is offline   Reply With Quote
Old 02-03-2012, 02:46 PM   #31
prashanth
Member#: 123534
2012 Evo X MR
Grey
Its not the exhaust. I have COBB 3" downpipe going to 2.5" SPT CBE. I made 343whp/362WTQ on Blouch TD 06 20g turbo. Stock STI on this dyno is at around 225-230whp.
http://forums.nasioc.com/forums/show...07&postcount=1
prashanth is offline   Reply With Quote
Old 02-03-2012, 11:29 PM   #32
OCRace Shop
Member#: 297719
Still pretty impressive numbers! I bet it pulls really strong
OCRace Shop is offline   Reply With Quote
Old 02-04-2012, 02:54 AM   #33
pooster.online
Member#: 120461
2004 WRX STi JBP
dyno hp is not comparable. This is one of the lower reading mustangs vs a dynojet. though you do hit full boost about 500 rpm sooner or more if OP is correct about full boost.
Old 02-04-2012, 11:18 AM   #34
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
How much timing are you running?
banshee04 is offline   Reply With Quote
Old 02-04-2012, 01:59 PM   #35
SeRious10
Member#: 229792
2010 WRX
WR Blue
Not to mention the Perrin CAI is probably maxed out... Need to go larger to say a KS Tech.
SeRious10 is offline   Reply With Quote
Old 03-19-2012, 06:43 PM   #36
kakarot09
Member#: 182375
08 Sti
Wrbm
OP did you ever figure out if anything was wrong with the car? What did Mike say about it? You could have also had a preturbo exhaust leak which would cause the late spool.
kakarot09 is offline   Reply With Quote
Old 01-16-2013, 11:08 PM   #37
disque71
Member#: 57330
2008 WRX
bump for update
disque71 is offline   Reply With Quote
Old 01-17-2013, 06:58 AM   #38
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the tdo6-20g spool is slower than tdo5-20g.
plus your 2.5" exhaust.
but numbers are about what you see for 91 oct
for your set up.
2008 WRX Stock vs. Stage II dyno tuning Dyno Flash Proven Power Bragging 41 08-29-2012 10:05 PM
2002 VF43'd 2.0L WRX makes 284/274--On Mustang Dyno Claymra Proven Power Bragging 21 06-08-2010 02:57 PM
2009 WRX Numbers on a Mustang Dyno wrxphantom Proven Power Bragging 50 09-30-2009 10:36 PM
Ultimate Racing 2008 WRX CAI + Turboback Exhaust + FMIC DYNO Results Ultimate Racing Proven Power Bragging 80 07-16-2008 02:19 AM
02 WRX - TD04 - Mustang dyno - PDX Protuned 02WHITEDUB Proven Power Bragging 13 07-25-2006 02:10 AM
