Old 01-25-2012, 10:11 AM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Default Boost question
Ok so I have a 01 rs 2.5 coupe with a 95 jdm sti swap. Need to know if motor can handle 18psi. currently running 15psi
jollyblue84 is offline   Reply With Quote
Old 01-25-2012, 10:22 AM   #2
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
why dont you do a ocmpression/leakdown test and you tell us if it can based off those results......
jayman4312 is offline   Reply With Quote
Old 01-25-2012, 10:26 AM   #3
jollyblue84
Member#: 292300
01 GC8
blue
The motor has about 45,000 miles. Its been taken care of. What does the test do exactly?
Old 01-25-2012, 10:37 AM   #4
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Tells the health of the motor internally... You should talk to a tuner btw.
wrxlaunch is offline   Reply With Quote
Old 01-25-2012, 10:39 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You should be talking to a tuner, NOT the internet. You don't just turn up boost on Subarus without knowing engine management, whether your motor is good, what turbo you have, knoweldge and use of air fuel ratio equipement, etc.
Old 01-25-2012, 12:22 PM   #6
My 05 WRX
Member#: 301549
2005 banging one
aspen white
Test it and boost it!
My 05 WRX is offline   Reply With Quote
Old 01-25-2012, 12:58 PM   #7
jollyblue84
Member#: 292300
01 GC8
blue
Lol nice!
Old 01-25-2012, 01:07 PM   #8
jollyblue84
Member#: 292300
01 GC8
blue
I know I should be going to a pro. But you tell me were ill find someone in texas and ill go today. Atleast call them. Im just wanting some opinions on if the motor is capable of handling the extra 3psi. If you can't answer that then I guess I'm not asking you.
Old 01-25-2012, 01:11 PM   #9
crotchbuffet
Member#: 205324
2002 Impreza wrx
midnight blue pearl
dont the jdm sti's boost 18-19 from the factory?
crotchbuffet is offline   Reply With Quote
Old 01-25-2012, 01:15 PM   #10
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
It should be able to handle 18 psi at least for long enough to break something. How do you plan on increasing the boost? If you are going the MBC route, at least find out what your A/F ratios look like at 15 psi. Increase it by 0.5 psi increments at a time. Then report back when you've blown a piston.
guroove is offline   Reply With Quote
Old 01-25-2012, 01:15 PM   #11
jollyblue84
Member#: 292300
01 GC8
blue
I couldnt tell you. This is my first subaru. I'm learning as I go. But this is a 1995 jdm sti motor.
Old 01-25-2012, 01:26 PM   #12
jollyblue84
Member#: 292300
01 GC8
blue
My turbo actuator is going out. I have 2 others in my hands. 1 allows 13psi the other 18psi. If I can use the 18psi actuator then I save $150.00. But if need be I will buy a boost controller to aset the boost lower. I'm simply wondering once again if it could handle the extra boost. But thanks everyone for being a$$es. I was told this site has respectable people but I have seen otherwise. Peace
Old 01-25-2012, 01:36 PM   #13
guroove
Member#: 129833
2005 Forester XT
The reason why everyone is giving you a hard time is because it's nearly impossible to say whether it can handle it or not, given the age of the engine. Also keep in mind that JDM engines are made to run on higher octane fuel than we run here. Do you have any way to monitor A/F ratios, knock, and EGT?
Old 01-25-2012, 01:47 PM   #14
jollyblue84
Member#: 292300
01 GC8
blue
No I dont. What would be a good but lower cost way to do so?
Old 01-27-2012, 01:01 PM   #15
crotchbuffet
Member#: 205324
2002 Impreza wrx
midnight blue pearl
if the wastegate actuator is the reason your gonna be going to 18 psi then either buy something that can monitor data, or turbosmart just came out with an internal wastegate for subaru's that has different springs so you could just put in the 15psi spring. there's probably many other brands that offer wastegates that do the same thing sorry if giving you info. is being an a$$ then you shouldn't have asked a question.
Old 01-27-2012, 01:20 PM   #16
guroove
Member#: 129833
2005 Forester XT
Since it's JDM, and pre-1996, I'm not sure any OBD II readers are going to work on it, so you probably need to install hard-wired gauges to read that information.
Old 01-27-2012, 03:29 PM   #17
jollyblue84
Member#: 292300
01 GC8
blue
Hmm.. Ok any idea were a good place to get some would be?
Just installed boost guauge, have a boost question? RS 1986 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-22-2010 07:22 PM
newb boost question....how do you turn up the boost Meat Supply Newbies & FAQs 9 03-16-2009 07:25 PM
I just installed a boost gauge and I have a boost question... Hokie-wrx wagon General Community 12 08-28-2005 01:58 PM
Boost Question. S Leung Vancouver Impreza Club Forum -- VIC 9 06-07-2001 12:03 AM
Boost question Tensecgn Normally Aspirated Powertrain 0 03-11-2001 02:32 PM
