Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-20-2012, 11:27 PM   #6551
ryan6f7
Member#: 288621
2011 STI LMTD
Dark Metalic Grey
Yeah, a bunch of subies with the Seattle back drop would be awesome.
ryan6f7 is offline   Reply With Quote
Old 07-20-2012, 11:45 PM   #6552
nisti
Member#: 290168
2014 XV Crosstrek
CBS
Originally Posted by ryan6f7 View Post
Nice WRX
nisti is online now   Reply With Quote
Old 07-21-2012, 12:17 AM   #6553
Il Capitano
Member#: 299619
2011 Evo X
WW
Did my chrome delete today! Driver side came out flawless, passenger side is meh :/. I highly recommend it, especially on darker colors. Gives it a nice stealty look. Pics will be up when I get my mudflaps installed
Il Capitano is offline   Reply With Quote
Old 07-21-2012, 12:39 AM   #6554
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
How did you do it. I did mine with plastidip and it came out like **** so I took it off. Then I tried to vinyl it two different times but I couldn't cut it perfect enough to not show Any chrome....
Jive Turkey is offline   Reply With Quote
Old 07-21-2012, 12:50 AM   #6555
Il Capitano
Member#: 299619
2011 Evo X
WW
Link to what I used: http://www.premiumautostyling.com/pr...blackout%20kit
I'm not sure if you used the pre-cut ones like I did but after the failing twice I found out a way that worked (for me at least lol).
They have them cut a little bit longer so you can place it a little bit off. They way I did it was: I didn't even pay attention to the bottom. I had some one hold the vinyl and I slowly went and placed in down only looking at the top. I went maybe an inch and took off the air bubbles and repeated that process. If you just line up the top you are good to go, and make sure you have that second person holding it for you or else its literally impossible.Basically if there is no chrome on the top, you wont see any peeking through at the bottom. It took me some time, but the result is worth it.
Old 07-21-2012, 02:14 AM   #6556
Avalon786
Member#: 297031
2011 WRX Sedan
WRB...duh!
Cool
Originally Posted by mw1484 View Post
Saw you at the BNW, looked fun. Pretty crazy start to the course with those first to turns before the slalom.
Yeah, I had lots of fun out there. I was pleasantly surprised with my cars capabilities stock! Only thing I would change is suspension. I was also surprised there weren't more 11+'s out there.
New trunk trim
Avalon786 is offline   Reply With Quote
Old 07-21-2012, 03:24 AM   #6557
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
I have a friend who wraps car and etc so I just cut strips and tried to cut it on the car. Honestly I'm just going to paint this ****ing thing with flat black paint.
Old 07-21-2012, 06:44 AM   #6558
MFwrx
Member#: 264415
2011 impreza WRX
I plasti-dipped mine yesterday. Started with the passenger side and learned from my mistakes. All you need is a lot of painters tape and spray in really light coats. Drivers side came out 99% perfect (stupid mirror can be a bitch). I'll take pics after work. I'm impressed with how clean it came out.
MFwrx is offline   Reply With Quote
Old 07-21-2012, 09:55 AM   #6559
cmiller219
Member#: 187179
Chapter/Region: HIIC
14 STi
Cocain
i plasti dipped mine and it came out 100%. you have to pull all the tape off as soon as your done spraying while its still wet so it doesnt set to the tape. I did 3 coats
cmiller219 is offline   Reply With Quote
Old 07-21-2012, 10:22 AM   #6560
Asubie
Member#: 275582
2011 WRX
Asubie is offline   Reply With Quote
Old 07-21-2012, 10:39 AM   #6561
MFwrx
Member#: 264415
2011 impreza WRX
Some plasti-dipped accessories:
don't mind the dirt spots, the badge is ALL black.
And this is for giggles.
Old 07-21-2012, 10:42 AM   #6562
nisti
Member#: 290168
2014 XV Crosstrek
CBS
You only need one person.
Leave the vinyl on the wax paper while you slide it off onto the car.
I also lined up the top, and trimmed the excess when finished.
Honestly, this product is ****.
The height of the vinyl is too much. So it partially sticks to the rubber frame of the chrome trim. This is not something it wants to be stuck to.
After 4 months of having this on, the tops and bottoms of the vinyl pieces are wavy and no longer sticking to the rubber portion of the trim.
I'm with cmiller, going to plastidip next, more of a long term solution without painting.
Old 07-21-2012, 11:08 AM   #6563
Asubie
Member#: 275582
2011 WRX
I need to do this ASAP
Old 07-21-2012, 12:31 PM   #6564
cmiller219
Member#: 187179
14 STi
Cocain
This was my process. Two rows of tape then paper all over. Take your time with the first row of tape to get it as close as you can to the chrome.
then i put the paper on.
As soon as i was done spraying each coat i carefully removed all the tape and paper while it was still wet.
and it cam out like this.
no one flaw even right up on it. Under the mirrors was the trickiest part just take your time.
Old 07-21-2012, 01:53 PM   #6565
airbornesoldier
Member#: 282013
2012 Subaru WRX
SPW
I've been a good boy, maybe santa will bring me a big Turbo Kit.
airbornesoldier is offline   Reply With Quote
Old 07-21-2012, 03:01 PM   #6566
Il Capitano
Member#: 299619
2011 Evo X
WW
If the the stickers come off, ill just end up using plastidip
Old 07-21-2012, 05:08 PM   #6567
Astronautalis
Member#: 323990
Astronautalis is offline   Reply With Quote
Old 07-21-2012, 05:32 PM   #6568
mcuzzin
Member#: 292732
2007 FXT
SGM
Turned out nice but probably took you a lot longer than necessary plastidip is awesome because it wipes off easy on glass and paint, and cuts itself at seams. I taped an inch above the chrome strip and an inch below. After 3 light coats...just peeled away the tape and finger rolled any excess plastidip. When I first started I got some on the window but it just wipes off...nbd
mcuzzin is offline   Reply With Quote
Old 07-21-2012, 05:37 PM   #6569
xlaterdaysx
Member#: 285807
2011 WRX 5-door
Subtle pinstripe on grill and scoop. I had the red on before, but thought about trying this. Even more subtle on the picture.
xlaterdaysx is offline   Reply With Quote
Old 07-21-2012, 06:25 PM   #6570
TWlSFM
Member#: 286220
2011 WRX SWP
1991 Ford Ranger v6
TWlSFM is offline   Reply With Quote
Old 07-21-2012, 07:34 PM   #6571
Game_Over
Member#: 296693
2011 Subaru WRX -WRB
Torqued Perfomance Stg 3+
Game_Over is offline   Reply With Quote
Old 07-21-2012, 07:45 PM   #6572
1 sicK gtR33
Member#: 178814
@ game_over...car looks great.where did u get the rear diffuser?
1 sicK gtR33 is offline   Reply With Quote
Old 07-21-2012, 07:54 PM   #6573
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Probably ht autos
Let's Spool is offline   Reply With Quote
Old 07-21-2012, 08:04 PM   #6574
armadatilem
Member#: 252270
2011 WRX 5dr Premium
Nice WRX
STI ?
armadatilem is offline   Reply With Quote
Old 07-21-2012, 08:09 PM   #6575
b1aze
Member#: 284003
2010 Alpine 135i
Wrx intake mani.
b1aze is offline   Reply With Quote
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
