Closed Thread
Old 11-02-2012, 11:28 AM   #10926
besthaticouldo
Member#: 279660
some shots from Subiefest, dunno if i posted these
besthaticouldo is offline
Old 11-02-2012, 11:33 AM   #10927
wrbwrx52
Member#: 275907
2011 wrx
wrb
Originally Posted by PROcede View Post
What happened to it?
nothing broke, doing a motor build over the winter
Originally Posted by swpshgnwgn View Post
^^ Looks good. Love the gold on blue.
thank you, going to be changing the color up a bit just not sure what yet
Originally Posted by xluben View Post
Intercooler is upside down.
it sure is, i talked to fast ms and they told me it was the correct way when everyone else with the same fmic is different and yours is different as well. so i just said the heck with it and put it on and fits fine
wrbwrx52 is offline
Old 11-02-2012, 11:59 AM   #10928
HALFnelson
Member#: 319959
2012 WRX
Dark Grey Metallic
My 2012 DGM
HALFnelson is offline
Old 11-02-2012, 12:22 PM   #10929
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, they got in a bad batch and tried to play them off as normal. Did yours actually come with pipes that fit? Some of them came with the normal pipes.
xluben is offline
Old 11-02-2012, 12:30 PM   #10930
dstorm
Member#: 329237
2013 WRX
CBS
dstorm is offline
Old 11-02-2012, 12:32 PM   #10931
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Originally Posted by Celery GT-5 View Post
what reason is their to turn them on at all?..they don't do anything in fog
they do light up the road so you can see little animals running near the car and road debris better, they are for that and style basically so I see no point in shutting them off
Lighting up the road near the car actually lessens your perception of objects further away from the car.
In clear conditions, more foreground light is not a good thing, it's a bad thing. Some foreground light is necessary so you can use your peripheral vision to see where you are relative to the road edges, the lane markings and that pothole 10 feet in front of your left wheels. But foreground light is far less safety-critical than light cast well down the road into the distance, because at any significant speed (much above 30 mph), what's in the foreground is too close for you to do much about. If you increase the foreground light, your pupils react to the bright, wide pool of light by constricting, which in turn substantially reduces your distance vision—especially since there's no increase in down-the-road distance light to go along with the increased foreground light. It's insidious, because high levels of foreground light give the illusion, the subjective impression, of comfort and security and "good lighting".
From http://www.danielsternlighting.com/t...fog_lamps.html
It also basically doubles the amount of glare coming off your car that oncoming drivers have to deal with.
Don't be a dick. Turn your fog lights off when you're not driving in heavy fog or snowfall.
evilspoons is offline
Old 11-02-2012, 12:51 PM   #10932
wrbwrx52
Member#: 275907
2011 wrx
wrb
the pipes are alittle short but i was able to make them work just fine
wrbwrx52 is offline
Old 11-02-2012, 01:36 PM   #10933
MADMIKE874
Member#: 280732
2011 STI hatch
I have the same kit from FMS my cooler was upside down as Well. My pipes did fit perfect though actually I think that it probably fits better than if the pipes where on top. The only thing I did not like and actually changed was which side the hot side pipe was I cut both pipes and swapped them around so that the hot side Turbo pipe was on the opposite side of the intake. This actually made a drastic difference on intake temps. And look much better IMOP looks just like the PERRIN kit , with red pipes and black core. This would probably not work for the wrx but you can work it pretty easy on the STI setup
MADMIKE874 is offline
Old 11-02-2012, 01:42 PM   #10934
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
My fogs are on all the time. I rewired the DRL's to be the fog lights instead of the high beams.
guitarman19853 is offline
Old 11-02-2012, 02:10 PM   #10935
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think they got new pipes so that they could sell all the incorrectly manufactured cores.
That layout is the one reason to the FMS instead of the Perrin. You made it so the "cold" side of the pipe runs directly over the hot turbo before going into the motor. The standard TurboXS/FMS layout keeps the cooled air as cool as possible.
Lower intake temps that you saw are not benefiting you, because those temps are before the turbo and intercooler. You actually raised the temps of the air going into the motor. Having slightly higher IAT's with the hot pipe next to the intake can be accounted for in the tune, it's really just an indicator. Hotter air actually going into the motor is bad news.
People modify the Perrin setup to have counter clockwise flow for a reason, it is getting colder air to the motor. Taking a proper setup and making it goes backwards is so counter productive.
http://www.ryan-white.net/car_resour...%20(Large).JPG
Why is this? To look cool?
xluben is offline
Old 11-02-2012, 02:12 PM   #10936
HALFnelson
Member#: 319959
2012 WRX
Dark Grey Metallic
Originally Posted by Asubie View Post
very nice, on coilovers?
Old 11-02-2012, 02:21 PM   #10937
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
oh wow daniel stern lighting said so on an antiquated website...must be true. OEM fogs are not that bright and pretty much just there for looks, they don't really do anything in fog so I guess you better go on a crusade to have all WRX OEM fogs uninstalled. They are lighting up the ground so I don't see why they would create more glare for oncoming drivers. I've never been blinded by dim OEM fogs in oncoming traffic
Celery GT-5 is offline
Old 11-02-2012, 02:38 PM   #10938
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by dstorm View Post
http://farm9.staticflickr.com/8468/8148023189_3762ef2281_z.jpg
This exhaust looks amazing!
xluben is offline
Old 11-02-2012, 02:39 PM   #10939
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
I think it looks better than the stock DRL's. I've never liked the look of high beams as DRL's, not to mention the harm it causes to the bulb by running it at low output. If Subaru had made a low beam DRL or LED DRL's I probably wouldn't have changed it. I see the logic behind cars requiring DRL's so I didn't want to disable them all together.
Old 11-02-2012, 02:44 PM   #10940
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
I don't see how fogs are any worse than DRLs unless they are crazy blinding ricer hids
Old 11-02-2012, 03:20 PM   #10941
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
Back on top, while staying on topic... Disabled DRL's updated to LED DRL by Phillips!
Struttin by mw1484, on Flickr
Untitled by mw1484, on Flickr
mw1484 is offline
Old 11-02-2012, 03:22 PM   #10942
colbygrease
Member#: 311468
'13 STI Hatch
Looks like the SPT to me.
colbygrease is offline
Old 11-02-2012, 03:37 PM   #10943
ripandrun
Member#: 293547
2003 VW GTI
with all of this fog light talk...
are there any bulbs out there that match the look of the HIDs? I don't care so much about brightness, but I hate that the fogs and HIDs don't match.
ripandrun is offline
Old 11-02-2012, 04:07 PM   #10944
dstorm
Member#: 329237
2013 WRX
CBS
You are correct. I had exhaust finishers but took them off and had them powder coated gloss black. Just picked them up today. We'll see how it looks...
dstorm is offline
Old 11-02-2012, 06:01 PM   #10945
wlwarfield
Member#: 304010
2011 STi & 2013 BRZ
Lightning Red
Here's my 4x4. Next mod will be coilovers.
wlwarfield is offline
Old 11-02-2012, 06:51 PM   #10946
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Installed my winter setup today. What do you guys think? I wasn't sure what color and style of wheels look good on a Plasma Blue, so I went with some black ones. ( they were cheap :P ) They came last night from TireRack.com
Navendra94 is offline
Old 11-02-2012, 08:18 PM   #10947
warmitup
Member#: 158926
11 WRX 4dr ltd
spark silver metallic
I hear toast adds 3hp. Correct me if I'm wrong....
warmitup is offline
Old 11-02-2012, 08:51 PM   #10948
blek08
Member#: 225701
2012 WRX
Thumbs up Terribly Wrong
Toast adds at least 6hp as long as its not whole grain wheat n all....
blek08 is offline
Old 11-02-2012, 08:52 PM   #10949
Navendra94
Member#: 327495
Plasma Blue
Lol. Buttered Toast
Old 11-02-2012, 09:00 PM   #10950
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Perrin shorty with my vortex gen
Nighthawkra is offline
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
