Closed Thread
Old 01-09-2013, 11:50 PM   #13026
Romdizzle
Member#: 294852
2011 WRX
Obsidian Black Pearl
Originally Posted by geddesk2 View Post
Looks like a great way to vent some heat from the engine bay.
Maybe while sitting still but the venting heat will just go right back into the scoop to the TMIC while moving.
Romdizzle is offline
Old 01-10-2013, 12:21 AM   #13027
colbygrease
Member#: 311468
'13 STI Hatch
Originally Posted by Romdizzle View Post
Here's mine...
I can't decide if I like that grill or not. Looks pretty good on your car though. Now all you need is some more tire on there.
colbygrease is offline
Old 01-10-2013, 12:31 AM   #13028
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
I think hes putting a FMIC on. Theres more detail about in the unique mods thread
imac6471 is offline
Old 01-10-2013, 12:43 AM   #13029
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Here's mine...
Agree with the above. I have been wanting to go HTAutos for my grille for a while. I like it on yours. I think it looks a little better if you keep the stock WRX or STI badge. Basically a subaru badge delete. Kinda cleans up the front end.
Edit: **** those taillights look good on black
Those rear tires though...
JSchell1309 is offline
Old 01-10-2013, 01:03 AM   #13030
Dka67
Member#: 296721
11 5door
....+1.
Dka67 is offline
Old 01-10-2013, 02:31 AM   #13031
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Originally Posted by krypton View Post
I had prosport gauges halo series worked for like 3 months then had to replaced them went DEFI nvr looked back only regret is wasting 250$ on prosport ...
this i what I'm having to do i regret wasting my money on prosport also
Gregor91 is offline
Old 01-10-2013, 04:01 AM   #13032
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Don't know if I share these yet:
Fresh debadge and myself cleaning the wheels
Stickarzzz.
kyletakahero is offline
Old 01-10-2013, 07:16 AM   #13033
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
This is what I'm hoping for. I already have an FMIC installed, so the scoop is actually useless and detrimental to performance at this point.
My original plan was just to make a permanent scoop block plate. Once I pulled off the stock scoop insert, I realized I could probably make it into something similar to an Evo 8/9 hood vent. It's hard to see in that crappy pic, but the scoop opening is blocked with a piece of sheet aluminum with a grill mesh on top to match the vent opening. I also have a sheet aluminum piece that I'm putting on the underside of the vent to help direct air up and out of the engine.
I should hopefully have this done and installed by the weekend with better pics.
atf78 is offline
Old 01-10-2013, 08:30 AM   #13034
J_Maher_WRX
Member#: 290307
Seems like a pretty good idea, though I'm not still it sure of it. I'd be still worried about the dirt/rain getting directly into and top of the engine. And the scoop is by no means detrimental to performance lol the aero on the car still draws in cool air from the scoop to cool down the engine bay so I don't see how it's negative. And if you're talking about its aerodynamic drag, unless you're a race car driver it really doesn't matter
I think it'll look cool when it's done though, cool that you made it yourself as well. interested to see some pics
J_Maher_WRX is offline
Old 01-10-2013, 09:10 AM   #13035
PearlRex11
Member#: 284420
2011 WRX Sedan
I think I read somewhere that the hood scoop messes with the air flow over the fmic somewhat. That may be what he is talking about. Could be wrong though.
PearlRex11 is offline
Old 01-10-2013, 09:34 AM   #13036
JSchell1309
Member#: 321321
Tuxedo Black
It's a cool idea and if like to see it mounted. Would be interesting to see it plexiglas instead. I have seen some 03-07 guys delete the scoop with plexiglas and it looks great. As mentioned earlier not much to look at with the plastic under the WRX though
Old 01-10-2013, 11:04 AM   #13037
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
With more details, now the scoop modification seems reasonable.
The block off plate on the scoop avoids positive pressure in the engine bay, while the new meshed area will serve multiple purposes.
FLEX'N WRX is offline
Old 01-10-2013, 11:11 AM   #13038
rwfloberg
Member#: 327538
2012 WRX (307/344)
Would be interested in possibly buying that for the right price once I can see if your willing to make another...
with a FMIC the scoop sucks in air into the engine bay which supposedly causes high pressure -> harder for air to move through the radiator -> higher engine temps
rwfloberg is offline
Old 01-10-2013, 11:31 AM   #13039
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
^This is all spot on. The scoop creates higher pressure in the engine bay. While this might be nice to cool down the engine bay, but it will reduce flow through the FMIC and radiator. I still like the flat hood if it's paired with a FMIC. Rear facing vents would be nice, but I don't think they're really necessary. Some air is able to flow out through the fender vents already. The rest just goes out the bottom like normal.
xluben is offline
Old 01-10-2013, 11:41 AM   #13040
Ultimateone
Member#: 48025
15 Mustang GT
too much stretch...
Ultimateone is offline
Old 01-10-2013, 12:32 PM   #13041
211STi
Member#: 283286
2011 STi
What is the threshold for too much?
211STi is offline
Old 01-10-2013, 01:03 PM   #13042
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Those taillights look great on the black hatch!
ocdpvw is offline
Old 01-10-2013, 01:37 PM   #13043
JSchell1309
Member#: 321321
Tuxedo Black
When it looks like a clown car.
Old 01-10-2013, 01:38 PM   #13044
colbygrease
Member#: 311468
'13 STI Hatch
any at all
Old 01-10-2013, 01:46 PM   #13045
vikingRS
Member#: 87098
'12 WRX - PBP
'95 STR Miata - Black
It looks funny, but it's also unsafe and detrimental to performance...
vikingRS is offline
Old 01-10-2013, 02:09 PM   #13046
HTAutos
Member#: 116476
1998 Pick Up Impreza
Just joined the clan, Picking it up Saturday
Already got some parts ready to go on it;
Will now be making a lot more parts
Mark @ HTAutos.
SHOP; http://www.subarukits.com/shop_usa_5.html
HTAutos is offline
Old 01-10-2013, 03:36 PM   #13047
JSchell1309
Member#: 321321
Tuxedo Black
^ Yes more 08+ support haha! Sedan or hatch? Can't tell from the diffuser.
Also post up pics of the grille installed, still debating that.
Old 01-10-2013, 03:52 PM   #13048
J_Maher_WRX
Member#: 290307
That diffuser is for the sedan I believe. And yes pics of said grille, looks gooood
Old 01-10-2013, 03:56 PM   #13049
vikingRS
Member#: 87098
'12 WRX - PBP
The trunk lip spoiler looks like a sedan part as well... going to look good, love plasma blue, but I'm biased.
vikingRS is offline
Old 01-10-2013, 05:10 PM   #13050
HTAutos
Member#: 116476
Yes, its a sedan
Online shop; http://www.subarukits.com/shop_usa_5.html
HTAutos is offline
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
