Closed Thread
Old 04-13-2013, 04:23 PM   #16376
SubieLuvin
Member#: 248202
2013 WRX Sedan
Originally Posted by rosedaleny806 View Post
anyone want/need the stock cluster with a gauge pod attached to it??
I'd love one if you are looking to donate it ! Lol
SubieLuvin is offline
Old 04-13-2013, 07:15 PM   #16377
J_Maher_WRX
Member#: 290307
installed my smy cluster and my boost gauge vac is good at 20 but not hitting full boost on the gauge. maybe a kink in the vac line? or sum sort of leak
Have you logged? Run some logs and compare your boost gauge readings vs what your logs are telling you. That'll immediately rule out boost gauge being faulty if they're the same. Check all lines for kinks, make sure you've clamped all of them haha otherwise, could have a boost leak. If not, then look at the tune.
J_Maher_WRX is offline
Old 04-13-2013, 07:18 PM   #16378
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
well my cobb ap is telling me im hitting full boost. but my spt gauge literally stops at 15psi goes a tiny bit up while my cobb tell me more (which is notmal) probably a kink in the vac line. lol
rosedaleny806 is offline
Old 04-13-2013, 07:51 PM   #16379
michal
Member#: 159770
2012 STI Sedan
2015 STI Ordered
Summer Mode
michal is offline
Old 04-13-2013, 08:11 PM   #16380
garudatwo
Member#: 322385
Makes the boost gauge pretty much useless huh? LOL at the NYPD patch, I wonder if that'll help you from getting parking tickets.
garudatwo is offline
Old 04-13-2013, 08:47 PM   #16381
13whiteguywrx
Member#: 351622
2013 Wrx
Originally Posted by michal View Post
Summer Mode
Beautiful 😇
13whiteguywrx is offline
Old 04-13-2013, 08:56 PM   #16382
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
I still can't get over that they went from black headlights to chrome housings.
Aarron_M is offline
Old 04-13-2013, 08:56 PM   #16383
13whiteguywrx
Member#: 351622
2013 Wrx
Alittle bit of baking and problem solved
Old 04-13-2013, 09:00 PM   #16384
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
I think it looks a lot worse in pictures than in person, I thought it was awful until I started seeing them on the road, now I think they look fine.
I will trade my black housings for chrome with OEM HIDS any day lol
Celery GT-5 is offline
Old 04-13-2013, 09:01 PM   #16385
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Go out on the freeway and go from 3rd to 5th and let the boost build and peak. Many cars won't max out the boost if you are shifting normal.
Louie is offline
Old 04-13-2013, 09:02 PM   #16386
Celery GT-5
Member#: 98210
2002 WRX SRP
but his ap is showing full boost....
Old 04-13-2013, 09:03 PM   #16387
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Derp: gotcga.
Louie is offline
Old 04-13-2013, 09:22 PM   #16388
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
And then they'll leak and have condensation. Doesn't change that it still looks worse. It's like when they went from the 04-05 tails to the 06-07 rice-tastic tails.
Aarron_M is offline
Old 04-13-2013, 09:33 PM   #16389
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
lol it does, thats and my nypd pba card, my friend works for 105th precinct
Old 04-13-2013, 09:41 PM   #16390
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
Originally Posted by W.K.S. View Post
I think I've been to that commissary before.
you been to Monterey?
Mr. Lin is offline
Old 04-13-2013, 09:46 PM   #16391
michal
Member#: 159770
2012 STI Sedan
2015 STI Ordered
Beautiful 😇
Thanks
I didn't like them at first but I got used to them, I'm not planning on changing them to black.
michal is offline
Old 04-13-2013, 10:27 PM   #16392
jjablo6
Member#: 265697
2015 STi
Ligtening Red
Summer Mode
Me like it
jjablo6 is offline
Old 04-13-2013, 11:09 PM   #16393
Ultimateone
Member#: 48025
15 Mustang GT
Does anybodies dead pedal squeak? mine just started to?
IMG_0634 by Ultimatetwo, on Flickr
IMG_0644 by Ultimatetwo, on Flickr
Ultimateone is offline
Old 04-13-2013, 11:13 PM   #16394
garudatwo
Member#: 322385
Had it, fixed it myself, haven't heard it since. I just pulled the two plastic fasteners and swapped them from top to bottom. Spoiler alert: it's just thin sheet metal with a block Styrofoam underneath.
Gosh your muffler looks low to the ground. Ever scrape 'em?
Don't flash that card if you get pulled over for doing a 3rd gear pull lol, gonna make your buddy look bad.
Old 04-13-2013, 11:23 PM   #16395
Celery GT-5
Member#: 98210
2002 WRX SRP
car looks great!
pretty much everything squeaks in these cars
Old 04-13-2013, 11:25 PM   #16396
garudatwo
Member#: 322385
I've had rattles (that I've pinned down to a valve stem tool in the glovebox), but the dead pedal was the only squeaking problem I've ever had. Then again, that might be because I couldn't hear them over the screaming tranny...
Old 04-13-2013, 11:39 PM   #16397
Celery GT-5
Member#: 98210
2002 WRX SRP
should be pretty easy to just pop the dead pedal off and check it out
Old 04-13-2013, 11:44 PM   #16398
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
I have the dead pedal squeak as well when i push down on it. Doesn't bother me much. My car actually has tons of rattles on the interior now. Approaching 45k on my 11. I don't mind it much just turn the volume up or roll the windows down.
PROcede is offline
Old 04-13-2013, 11:46 PM   #16399
JuanWins
Member#: 328915
2009 WRX
Lightning Red
Originally Posted by JuanWins View Post
How do you like that top mount. Notice any big difference?
Do let me know when you install it. I might buy this from a buddy until I can afford a Perrin fmic.
JuanWins is offline
Old 04-13-2013, 11:49 PM   #16400
Celery GT-5
Member#: 98210
2002 WRX SRP
both of my a-pillars rattle when its cold. Beyond that the car just has a generally creaky nature to it, you can hear everything shifting about when you go over bumps.
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
