Closed Thread
Old 06-13-2013, 09:03 PM   #20176
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
Originally Posted by theEZV View Post
Did suspension and wheels/tires. Will take some better pics when the weather gets better.
I like the silver wheels a lot. How much of a drop? What size wheels and tires?
Buzzed Trucks is offline
Old 06-13-2013, 09:13 PM   #20177
theEZV
Member#: 324205
2014 335i; 2016
Crosstrek; 2013 WRX(sold)
18x9.5 +40. 265/35. KW V1. Out of the box they were pretty low, raised them around 1/4" all around to get some more clearance up front. Probably 1.25-1.5" drop, somewhere around there. They can go quite a bit lower too.
theEZV is offline
Old 06-13-2013, 10:06 PM   #20178
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Good setup. I do like the look of NT03s, but man they have to be a bitch to clean with that band through all the spokes
Don't forget to get an alignment and corner balance for your set up. Ask locally for a quality shop. KWs are good stuff.
JSchell1309 is offline
Old 06-13-2013, 11:37 PM   #20179
Iownit4
Member#: 358947
13 Wrx
Default 2013 wrx ny
What's the Biggest tire and rim I could put on a stock suspension 2013 wrx with out rubbing or mod fenders.
[/url][/IMG]
Iownit4 is offline
Old 06-13-2013, 11:39 PM   #20180
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
There's a thread for that:
http://forums.nasioc.com/forums/show....php?t=2155863
RM_2 is offline
Old 06-13-2013, 11:39 PM   #20181
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
Celery GT-5 is offline
Old 06-13-2013, 11:42 PM   #20182
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
^ I don't care who you are, that's funny.
turbogc8 is offline
Old 06-13-2013, 11:53 PM   #20183
JSchell1309
Member#: 321321
Tuxedo Black
So I have been having this recurring boost leak for the last month now. It is on the red 90 degree pipe from the turbo outlet to the intercooler Y pipe. I will tighten this band down and in a few weeks it will slip off. Well after tightening it down this time I noticed it isn't sitting correctly on the red pipe. I decide to jam my phone down there to grab a picture of the back where it isn't fitting well.
... this is awesome. Going to ask the dealer WTF is up with this. They were the last ones to monkey around with my TMIC and turbo.
All the way off
Shot of the back, after I tighten it down best I can.
Old 06-14-2013, 12:04 AM   #20184
Erittz
Member#: 282506
2011 WRX
I hope you get it figured out before saturday!!! Good luck!
Erittz is offline
Old 06-14-2013, 12:08 AM   #20185
JSchell1309
Member#: 321321
Tuxedo Black
I won't. It's definitely still drivable, I just probably shouldn't push it. Good thing the Sunday autocross was canceled or else I would have pushed it
I have 30k maintenance I need to get to, so I will have them look at it then. Not too please after seeing that.
A small group of us KC guys are heading out tomorrow around 2 p.m. Should be hitting your area round 4 p.m. if you wanted to join up.
Caravan meet thread here:
http://kcsubaru.com/showthread.php?1...re-meet-Cruise
Old 06-14-2013, 12:09 AM   #20186
Sleeperwagon1
Member#: 138901
2012 WRX sedan
ISM
Take of that screw clamp. It's just going to keep chewing the elbow. Use a t-bolt clamp, and you should be fine.
Sleeperwagon1 is offline
Old 06-14-2013, 12:10 AM   #20187
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Satin White Pearl
It won't get better, you need a new coupler. Same thing happened to me on my 06. The c-clamp wasn't tightened enough, and from boosting out of turns so much it puts alot of pressure and movement in there. So little by little over time the clamp started sliding and eventually cut into the rubber coupling. You can either get the oem one or one from autozone. Also don't use the same clamp. There are different style tightening ones. I forgot which one i got but it fixed the issue. It won't be easy getting the new one on tho. Good luck man
CASHxMONEYxMIKE is offline
Old 06-14-2013, 12:13 AM   #20188
Iownit4
Member#: 358947
13 Wrx
<P><IMG src="http://"></P>
Iownit4 is offline
Old 06-14-2013, 12:19 AM   #20189
JSchell1309
Member#: 321321
Tuxedo Black
Yeah I need to do this. I have a big problem with worm gear clamps, they are garbage. I have been wanting to replace the two large worm gears on the throttle body hose as I have heard those are always a trouble spot and good idea for 2 T-bolt clamps.
Any idea what is the outer diameter of this 90 degree red hose is so I can pick up the right clamp? Should be fun trying to get in on there.
Old 06-14-2013, 12:30 AM   #20190
rwfloberg
Member#: 327538
2012 WRX (307/344)
Anyone ever use an oil extractor to do a 30k mile service?
Also, cell pic
rwfloberg is offline
Old 06-14-2013, 12:38 AM   #20191
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
Turbo outlet flange: 2.0" (54-62mm)
TMIC inlet: 2.5" (67-75mm)
TMIC outlet: 2.75" (73-81mm)
Throttle body: 2.75" (73-81mm)
For the last three, having the silicone hoses installed increases the OD a bit, so slightly larger clamps would probably work as well (2.75-3.0").
turbogc8 is offline
Old 06-14-2013, 12:40 AM   #20192
Sleeperwagon1
Member#: 138901
2012 WRX sedan
ISM
JSchell: a whole lot easier to just remove the intercooler with the elbow attached. Isn't the OD 2.5"? At least that's what I thought.... Not too sure so don't quote me on that.
Edit: turbogc8 beat me to it...
Old 06-14-2013, 12:43 AM   #20193
JSchell1309
Member#: 321321
Tuxedo Black
Thanks for the help guys. I will check my local hardware stores and pick up an assortment of these. Should be a good project for a slow day. I really should replace that hose too while I am going through all this.
Old 06-14-2013, 12:48 AM   #20194
Sleeperwagon1
Member#: 138901
2012 WRX sedan
ISM
Yup, I would replace it. Vibrant makes a real good product that is usually a real good fit. I have never had any issues...
Old 06-14-2013, 12:49 AM   #20195
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
With as shredded as that hose is, you definitely need to replace it. A new clamp will only act as a bandaid.
turbogc8 is offline
Old 06-14-2013, 12:50 AM   #20196
Iownit4
Member#: 358947
13 Wrx
Thanks for the help.
Iownit4 is offline
Old 06-14-2013, 01:50 AM   #20197
Erittz
Member#: 282506
2011 WRX
I'm actually back home for the summer in Cape Girardeau so I'll be coming from a different direction. Thanks for the invite
Pic
Barn work by Erittz, on Flickr
Erittz is offline
Old 06-14-2013, 02:01 AM   #20198
Boogaloo Shrimp
Member#: 315215
2012 WRX
like others said, that wheel thread is ur go-to for this. if you want to be able to drive the car and make u turns, lets say 18x10 with a 275/35-18 with rolled rear fender. absolutely no mods at all you would probably be able to do a 18x 9.5 with a 235 tire.
when I had stock suspension i had a 18x9.5 +38 with a 265/35 and the rears rubbed hard with little effort... my buddy had the same setup but with a 245/40 and his rears rubbed pretty easily too. this question has many answers, so we need to know what you plan to do with the car and what your expected outcome is. My little seed of advice, just get the rears rolled, get over not doing it because if you want better wheels at all you will have to do this. I didn't want to and had to suck it up, but the lip on the rears is no joke.
Boogaloo Shrimp is offline
Old 06-14-2013, 02:40 AM   #20199
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by Wrx Cruiser View Post
Yeah I love it and most other people do. Especially since I haven't seen anyone else with it. I thought about putting the STI trunk on it but you know how people get when you try to pretend you have a Sti when you really have a WRX. Besides I love the LED 3rd brake light and it matches my other led brake lights. And I think there might be a clearance issue with the other wing on it when the trunk opens.
Thank you! Yeah its single, double looks better but love the sound of single.
I have an STI trunk on my wrx. I have the base model (no spoiler) and I didn't like the sti spoiler at all when I bought mine, I liked the wrx spoiler even less. The sti spoiler grew on me after about a year. I kept walking up to my car and thinking it was missing something. The sides and front of our cars have pretty aggressive features but the back doesn't as much Imo. I was told by someone that the body of our cars was designed with the spoiler on it and then they removed it for the wrx models (not sure if it's true) mine is debadged , I have no intent on making people think I have an sti, I just feel it completes the rear of the car, I also did a trunk swap with another pearl white with no cash involved which made it easier for me to decide I wanted it. Do what you want.
Before
After
PearlRex11 is offline
Old 06-14-2013, 02:42 AM   #20200
PearlRex11
Member#: 284420
2011 WRX Sedan
I've heard zebra clamps are even better. Never tried them myself though.
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 09:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 04:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-17-2011 12:51 AM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 03:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 06:21 PM
