Closed Thread
Old 06-20-2013, 05:12 PM   #20451
yenny
Member#: 143116
Originally Posted by CASHxMONEYxMIKE View Post
So anyone else had or know how to adjust this issue without resetting anything? As i was driving to work, i made a left turn, didn't go over any bumbs/ glass/ obstructions, etc. I was in second gear at like 15mph and as soon as I came out of the turn my tire pressure sensor light came on. All 4's look fine, couldn't hear or see any leaks. Drove to work another 5 miles or so, checked them again and still fine. Just wondering if our model years have super sensitive or super sh***y sensors in them. Thanks guys
TPMS lights up also when pressure is too high. As tires warm up pressure increases and may light it up
yenny is offline
Old 06-20-2013, 06:04 PM   #20452
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Satin White Pearl
Problem after problem with me, now my car is making a loud rattle after install of the KB SS w/ F+R bushings.. Any ideas?
CASHxMONEYxMIKE is offline
Old 06-20-2013, 06:12 PM   #20453
sdirep
Member#: 359672
2013 STi
What size wheels and tires you running on those? Perfect Fit FilipinoGuy
sdirep is offline
Old 06-20-2013, 06:13 PM   #20454
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
Maybe it's the KB SS w/ F+R bushings...
Aarron_M is offline
Old 06-20-2013, 06:18 PM   #20455
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Satin White Pearl
One could assume.........
Old 06-20-2013, 07:11 PM   #20456
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
Wingless Sedan OBP
Welcome to the world of Subaru's. With every bushing upgrade, suspension stiffening, and time your Subaru will make more noise than a 2 year old teething. Unless its repeatable under a set condition I would stack it up to the persona of a Subaru.
Check and make sure everything is torqued properly to the specs, make sure the linkage for the short shifter isn't loose, if everything checks out I wouldn't worry. Just my opinion, I'm sure others here will also have some advice for you.
Improbus is offline
Old 06-20-2013, 07:15 PM   #20457
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Did you put that worthless heat shield back on? Get down there and tighten that all down and shake on it like a drunken ape.
JSchell1309 is offline
Old 06-20-2013, 07:34 PM   #20458
garudatwo
Member#: 322385
+1 for heatshield. Double check that you haven't bent it as well.
garudatwo is offline
Old 06-20-2013, 08:00 PM   #20459
IBLinKYI
Member#: 172067
2011 Subaru WRX
Drunkmann Tuned LRP
Came across this from the weekend.
IBLinKYI is offline
Old 06-20-2013, 08:24 PM   #20460
JSchell1309
Member#: 321321
Tuxedo Black
Mmmmm,
Lightning Red - Check
Hatch - Check
BBS LM (reps ) - Check
Very clean, I do have a chub.
Old 06-20-2013, 08:34 PM   #20461
durtydurt
Member#: 235745
2011 WRX 5dr
durtydurt is offline
Old 06-20-2013, 10:29 PM   #20462
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Satin White Pearl
It was the heat shield!!!! Just needed to be moved over a tad and it went away. Thanks guys. Also today was seriously the shi**iest day I've had in awhile. Look out for a new random thread ill be starting. I basically might have a law suit pending -_______- (sigh) I just wish things went my way for once.
Old 06-20-2013, 10:34 PM   #20463
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Originally Posted by durtydurt View Post
Nice car man. Simple, clean, functional, I dig it!
Overland04 is offline
Old 06-20-2013, 10:37 PM   #20464
garudatwo
Member#: 322385
You're driving a '13 STi. That's a sign that a LOT of things are going your way.
Old 06-20-2013, 10:39 PM   #20465
JSchell1309
Member#: 321321
Tuxedo Black
What a damn good event. All credit to David Mullis for his awesome work behind the lens that day. Check out the rest of them here:
http://www.flickr.com/photos/scoobapalooza/
Old 06-20-2013, 10:44 PM   #20466
garudatwo
Member#: 322385
Love your plate delete. Trying to work with another member here to see if he can make me one that says USMC.
Old 06-20-2013, 10:46 PM   #20467
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by Improbus View Post
Turn Signal Bulbs are Dual Filament. If one of the filaments comes loose the light will still work but will blink quickly. The dealer replaced mine under warranty. If not a new turn signal bulb and you'll be good to go.
Mine had a pinched wire due to a factory installed zip tie. Acted exactly like that, I thought it was a bulb it because it is the same symptom but it wasn't the bulb.
PearlRex11 is offline
Old 06-20-2013, 10:54 PM   #20468
JSchell1309
Member#: 321321
Tuxedo Black
Thanks man. I'm working on a few new things for the hatch.
Old 06-20-2013, 10:55 PM   #20469
Turtlefart
Member#: 320054
2011 WRX
More from David Mullis of my car.
Turtlefart is offline
Old 06-20-2013, 10:58 PM   #20470
JSchell1309
Member#: 321321
Tuxedo Black
What did you think of the event over all, Turtlefart?
Old 06-20-2013, 11:53 PM   #20471
_davin
Member#: 260501
2003 miata SE
Blurple
Right side.
_davin is offline
Old 06-21-2013, 12:01 AM   #20472
mtl_sti
Member#: 351705
2012 STI Sedan
mtl_sti is offline
Old 06-21-2013, 01:33 AM   #20473
paterick
Member#: 305207
2012 WRX Sedan
Originally Posted by NWsoobie View Post
Japanparts.com has them. I think it's $400 for the entire kit. Surrounds, fogs, and switch.
damn I like dems but 400 dolla I cannot holla.
paterick is offline
Old 06-21-2013, 03:20 AM   #20474
jbgta007
Member#: 326113
2012 WRX
If you really think about it the U.S. fog light kit cost $350 from the dealer with no discounts or taxes... so $400 for the good looking hid jdm ones shipped is pretty do-able haha.
since we're on that topic: So If you buy the kit off japanparts how do you select what color garnishes for the lights? or do they just come unpainted? also is it totally plug and play or do they need modification?
jbgta007 is offline
Old 06-21-2013, 07:32 AM   #20475
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
It's been over a week since I ordered the R205 rear diffuser from japanparts...still no tracking info or shipping email.
Aarron_M is offline
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
