Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 08-14-2002, 07:28 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Anyone have keyless entry in a 97 98 or 99 forrester?
I realise that in the forrester of these years there was a harness that enabled "plau and play" installation of the keyless entry.
Using this knowledge I have basically been able to map out most of the connections on the harness.
If you have the keyless entry could you do me a HUGE favor and map wires?
What Im referring to is which pin on the car side of the connector (hiding under the dash) matches with which pin on the alarm box side of the connector.
If you help do this, any forrester owner could install keyless entry new from the dealer for about 35 dollars! Why? The impreza version is only 25-30 dollars at dealers while the exact same forrester version (minus the plug on one side of the harness) is usually 200-250$
Old 08-14-2002, 08:23 PM   #2
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Lightbulb
That would be Forester with 1 r. Sorry can't help you with the diagram.
lakepop is offline   Reply With Quote
Old 08-14-2002, 10:27 PM   #3
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'l check mine out this weekend, if I have time.
What do you need? Colors and pin locations, right?
LVSUBARU is offline   Reply With Quote
Old 08-16-2002, 03:31 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
Basically I would like to make a drawing that would allow forrester owners to use the impreza (cheap) keyless system.
If you have the cable that runs from the keyless to the connector under the dash all you would need to do is give a pin out like:
pin 1 on the square car side connector equals pin 5 on the larger alarm side connector.
I dont think the colors will be the same otherwise Id ask for that.
Old 08-19-2002, 04:03 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
bump
LVSUBARU or anyone else, all you would need to do is give a pin correlation between the one end of the cable that connects to the keyless box and the other end that connects to the plug that normally has a loopback connection.
If I remember right it is only 7-8 wires.
This info would let anyone add keyless entry to an early forrester for less than 50 dollars (my dealer has them for 28 dollars now).
98 Outback - Do I have Keyless entry? compression Outback Forum 2 03-16-2005 10:10 AM
Anyone have the FSM's for a 98 or 99 Impreza RS? (Brake info needed) Legacy777 Brakes, Steering & Suspension 0 09-03-2002 07:44 PM
Anyone have the FSM's for a 98 or 99 Impreza RS? Legacy777 General Community 0 09-01-2002 10:43 AM
Doing a ver 6 ra swap in 97, 98 or 99 impreza L questions mrtrex Normally Aspirated with bolt-on Forced Induction Powertrain 24 07-12-2002 07:18 PM
Which headlamps better? 97-98 or 99-00? NotAnRS Normally Aspirated Powertrain 7 04-29-2002 11:45 PM
