Old 01-03-2012, 04:17 PM   #1
nightfire
Member#: 85379
Default STi vs EVO X - handling question
I know this is like beating a dead horse and i've done plenty of searching on the topic. All the newer threads that I could find ('08+ STi vs EVO X) said the subie is better for DD but isn't as easy to work on, can't make as big of power as cheaply, and doesn't handle nearly as well/have as good of an AWD system overall. My main question for those of you that know both the evo and sti is, what can STi owners do to make their cars handle like an EVO X (quick handling with slight oversteer and easy to point into turns/get sideways in)? Even after watching the sti vs evo X top gear shootout vid on youtube it's really seeing the STi is pretty far behind compared to the evo besides from a luxury (if you can call a subie that) and DD standpoint. Any comments?
nightfire is offline   Reply With Quote
Old 01-03-2012, 05:38 PM   #2
Zachfeen
Member#: 277479
Look at any of the other 6 million threads comparing the sti to the evo
Zachfeen is offline   Reply With Quote
Old 01-03-2012, 05:44 PM   #3
nightfire
Member#: 85379
I do and I didn't see any specific info about what to add to the STi. Sway bars etc. I'm not looking for a super stiff ride just something that oversteers more and points the nose like the stock evo handles.
Old 01-03-2012, 05:48 PM   #4
liv4psi
Member#: 206505
'04 STI
JBP, 360whp 355tq @18psi
Changing the rear sway bar will help promote oversteer. There's only so much you can do, Subaru's are nose heavy cars.
liv4psi is offline   Reply With Quote
Old 01-03-2012, 05:50 PM   #5
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
As I saw once on a Best Motoring video:
"The STI balance with the Evo electronic assistance would make an unbeatable car!"
Maybe Subaru and Mitsubishi should consider "mixing" these two cars LOL
wrxstijdm is offline   Reply With Quote
Old 01-03-2012, 05:57 PM   #6
ShinjiML
Member#: 257231
2011 STI
well, the EVO handles the way it does because of all the electronics that control its AWD system and its suspension, in the form of AWC or S-AWC, which manages the AYC, ACD, and Sport ABS. Basically, the computer works harder to control the power distribution, yaw rate, along with torque vectoring, to keep the car turning the way you intend it to. Subaru doesn't use as many fancy electronics, but instead, relies on improving the engineering of the car's mechanical elements. So, there's not much subie owners can do to actually emulate an EVO's handling besides using sway bars, springs, struts, camber, toe, etc.
ShinjiML is offline   Reply With Quote
Old 01-03-2012, 06:19 PM   #7
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
The Evo is just better in the handling department than an Sti, period.
No swaybars or coilovers will make an sti out perform an evo in handling.
But powerwise, thats a different story.
Ysidro is offline   Reply With Quote
Old 01-03-2012, 06:46 PM   #8
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Maybe I'm totally lost, but what you guys recommend is to search in the forum, and what I've always read is that for the same $$$ and same mods, Evo gets more HP...
Old 01-03-2012, 07:18 PM   #9
Ysidro
Member#: 197418
07 WRX Ltd
The Evo will get more hp. But you will need to beef up its transmission.$$$$. Thats its weakness.
On the other hand, the Sti already has great transmission. You just spend money on a bigger turbo, supporting mods, and dont have to worry about the trans until you go even bigger. Plus Id rather have the extra 0.5 displacement than a 2.0 Not a big deal to others but to me, it is.
Old 01-03-2012, 07:28 PM   #10
ShinjiML
Member#: 257231
2011 STI
It depends on how much power you're adding, to a certain extent, the difference isn't too big, but once you go BIG power, the Evo starts to shine. There are a number of 7-8 sec Evos around, but how many 7-8 second STis are there? Obviously, it takes a monster amount of power to build a 7-8 second car, or even a 10 second car, so for most people I don't think that's really a concern.
Old 01-03-2012, 07:46 PM   #11
NoGraffix
Member#: 276209
I am Rub
Function>Form
OP are you planning to build a track car? If you are why not just start with the evo because out of the box it is a better preped track car.
As far as handling "like an evo," like others said only mechanical hardware can get you upgraded handling preformance. Upgraded sways, a better spring/strut combo, and a good alignment. If you do these things the gap in handling between the two cars will be slim.
NoGraffix is offline   Reply With Quote
Old 01-04-2012, 12:47 AM   #12
nightfire
Member#: 85379
What should I start with to make the handling better? A rear sway? I'm still a little leery about changing shocks and springs because I don't want it to be a super stiff ride because i'll be using it as a daily driver.
Old 01-04-2012, 02:47 AM   #13
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
front and rear sways and a performance alignment will get you a great start.
Old 01-04-2012, 02:50 AM   #14
damonchoy
Member#: 279935
03 350Z - Summer
97 E36 328i - Winter
If you want it to handle like an EVO, why not get an EVO?
damonchoy is offline   Reply With Quote
Old 01-04-2012, 02:56 AM   #15
liv4psi
Member#: 206505
'04 STI
Don't you have school in the morning?
I guarantee evolutionm.net doesn't get this many "Why is the STi better? threads.
Old 01-04-2012, 02:57 AM   #16
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
liv, you pose a very good question for the young boy...
Old 01-04-2012, 03:01 AM   #17
damonchoy
Member#: 279935
03 350Z - Summer
Nope, I'm off until Monday.
Canaderp gives us little munchkins a nice amount of time off school.
Old 01-04-2012, 03:03 AM   #18
liv4psi
Member#: 206505
'04 STI
Very well, carry on.
Old 01-04-2012, 03:05 AM   #19
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
canaderp...hmmmm
Old 01-04-2012, 03:26 AM   #20
damonchoy
Member#: 279935
03 350Z - Summer
I'm going to bed now, though... I've got lots of video editing to do tomorrow!
Originally Posted by drewvdw View Post
canaderp...hmmmm
I thought it sounded funny at the time.
Old 01-04-2012, 03:33 AM   #21
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
damon, that makes you a canaderpian...
Old 01-04-2012, 12:04 PM   #22
nightfire
Member#: 85379
lol thanks for the replies guys. Seems like a fun community on these forums
One more question for you, drewvdw you mentioned a "performance alignment", what exactly does that entail?
Old 01-04-2012, 12:07 PM   #23
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
simply going to a trusted alignment shop and telling them what you want for alignment specs. if you need advice, search around the suspension forum. the guys there are very willing to help.
Old 01-04-2012, 12:17 PM   #24
ShinjiML
Member#: 257231
2011 STI
usually it's like a custom alignment, where you tell them what camber and toe settings you want. Basically, negative front camber will improve handling, while toe out will further improve handling, but anyway, check the forums, there are lots of threads about alignments =)
Old 01-04-2012, 03:49 PM   #25
Decipher
Member#: 262760
2011 WRX Hatch Limtd
That explains a few things... ;-)
Who are we kidding, Damon molests his NASIOC app in class more than the hot little ladies in high school these days. Damnit son, don't let that gift of tail go!
Decipher is offline   Reply With Quote
'07 STI vs Evo IX - Sti has the upper hand ! Dyno Flash Proven Power Bragging 207 09-22-2007 02:26 PM
Biggest event ever - WRX/STI vs EVO Showdown - Raceway Park - 9/11/04 alfriedesq Proven Power Bragging 294 10-01-2004 01:13 PM
Handling aspects STi vs EVO Impreza01 STi Forum Archive 11 05-01-2003 09:31 AM
