Old 01-25-2012, 04:45 PM   #1
Slooturbo
Member#: 301410
WHITE
Default Airbag Light Please Help
hey guys whats up, not sure if im in the right topic or not but i think i am ha, anyways i have a 2002 subaru wrx with 69,xxx miles , got it on a trade. Car has a full 3 inch turbo back exhaust and a agency power bov, and a apexi turbo timer that is all i belive.
My question here is does anyone know what i did wrong after taking my steering wheel off . i did it the right way , negative battery was taken off, waited 10 min, took of screws from each side, pulled airbag off carefully did not brake any sensors, then i took the steering wheel off right after i unscrewed the nut. disconnected the cruise control too, i was trying to see how to take it all apart because i just bought a jdm steering wheel 320 for it, i did happen to chip a little plastic piece in the little hole where the nut sat. i put it back together, my horn does not work. and my airbag light is on. can any one help me ? i do want to go to the dealer ship as they are over priced. i checked both seats for the sensors under them and made sure they were clicked . if any one could help me i would really appreciate it as this is my baby ! and im returing the junky steering wheel staying stock just need my horn back and the light gone.
Slooturbo is offline   Reply With Quote
Old 01-25-2012, 05:20 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You probably damaged the clockspring. Get the code read to confirm, but the horn not working is a strong sign that is what happened.
Old 01-25-2012, 05:24 PM   #3
Slooturbo
Member#: 301410
WHITE
is that a expensive fix? how do i check this code
Old 01-27-2012, 02:11 AM   #4
Ovenmitt123
Member#: 307637
1993 Impreza1.8L FWD
Red
Easy way to check the code: Get a friend/mechanic w/ an obdII reader/scanner to do it for you.
Harder and more expensive: Buy one and run it yourself.
Might be a self-diagnostic mode for your car... not sure. I'm working with an older subaru.
Good luck!
Ovenmitt123 is offline   Reply With Quote
Old 01-27-2012, 02:20 AM   #5
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
I believe a regular obd 2 scanner will not be able to scan the air bag system. For that is something we are not really authorized to tamper with. You will need a special scanner or like the post above stated a good friend who can help. It sounds like you did everything right above but you could of damaged the clock spring in the steering wheel. Good luck and be careful with the air bag.
subaru_sti_steve is offline   Reply With Quote
Old 01-28-2012, 12:58 PM   #6
Slooturbo
Member#: 301410
WHITE
im pretty sure its the clock spring not a big deal for me found one brand new at 80$..
how do i fix my horn though ???
#BOGIN
Old 01-28-2012, 01:33 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The clock spring is used for both the airbag and horn. As I said in post #2, the airbag light with a non-working horn is a dead giveaway that it's bad, although it still is a good idea to read the code. There is a procedure in the service manual for reading airbag codes by connecting the diagnostic plugs together and counting flashes of the light.
Old 02-09-2012, 02:42 AM   #8
Slooturbo
Member#: 301410
WHITE
thanks so much mulder !
Airbag Light On?? Help! SUBYAWD85 Service & Maintenance 6 05-30-2009 11:07 PM
lights, codes and more lights...please help rpetrecca Tribeca Forum 3 06-26-2008 09:21 AM
NRG Wheel + Steering Release + Quick Release - Airbag light?! Need Help! Owners? vipernj Interior & Exterior Modification 7 10-08-2006 01:58 PM
Flashing Airbag Light please help CoastGuardSuby Service & Maintenance 1 03-06-2004 01:36 PM
OEM Flashing Security Light...please help. FiveStar Car Audio, Video & Security 6 05-13-2002 11:46 PM
