Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-25-2012, 07:32 PM   #1
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Default 04/05 STI swaps P1446 Code HELP!
So I have removed all the codes except for the "Fuel tank sensor control
valve" code P1446. This is because this extra valve isn't on the RS tank, and well, obviously the ECU is looking for it.
QUESTION: Does anyone of the resistance of this sensor? If anyone has one lying around, can you check too see how many ohms this sensor has.
I can't find one anywhere to measure myself, and i don't know anyone who will help me flash it out free, and i need to smog my car by the end of the month.
Any help would be appreciated.
DHRDAN is offline   Reply With Quote
Old 02-25-2012, 06:31 PM   #2
tom bauer
Member#: 310141
all that is required is that the ecu 'see' 12 volts on the wire going to the vsv. use a 1200 ohm 1/2 watt resistor, connect one end to any ig power and the other to the ecu pin used on your application.
tom bauer is offline   Reply With Quote
Old 02-27-2012, 04:48 AM   #3
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I just bought a BFM cord and flashed it out for $35.
Old 02-27-2012, 04:52 AM   #4
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I did not want to risk excess heat.... so i just wimped out and reflashed. THough i agree your fix is sound.
Old 02-27-2012, 10:05 PM   #5
tom bauer
Member#: 310141
ok, but the 'heat' is calculated at .144 watts, you cannot even feel it.
04 sti center console to 05 sti swap davidsti1 Interior & Exterior Modification 7 04-29-2010 05:54 PM
05 STI swap into 04 WRX Wagon. HELP! pismobeachrider25 Built Motor Discussion 6 04-12-2010 10:58 AM
FS: 99 White RS with 04/05 Sti swap 2002ImprezaRS Private Vehicle 'For Sale' Classifieds 16 07-16-2009 06:28 PM
looking to start a 04/05 sti swap in an 02/03 bugeye need shopping list 02MidnightPearlRS Subaru Conversions 2 03-09-2008 05:08 AM
stock 04 STi throwing misfire codes... help!! aznatama Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 12-31-2005 05:16 AM
