Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 01-25-2012, 09:35 PM   #1
jamesfacts
Member Sales Rating: (134)
Member#: 51282
98 RS
black & blue from parking
Thumbs up NYC: DCCDPro Universal Controller kit - Auto control DCCD
I have what is a mostly complete DCCDPro Universal Controller kit. It was installed in a car I bought - very sloppily, but it all appears to be there.
Totally untested, unfortunately, I don't have anything to test the kit out with. I emailed DCCDpro and they say everything appears to be in order - except for a g sensor. The outside of the g sensor case is damaged by the epoxy that was used to mount it inside the center console. It may need to be replaced - I'm not sure.
$sold.
http://dccdpro.com/zcart/index.php?m...4fd356b7c92ad1
Aftermarket standalone Automatic DCCD controller for JDM and USDM 6 speed transmissions as well as older 5 speed DCCD transmissions.
Did you swap the transmission in your car and need to control the DCCD?
This product is specifically designed for swapped cars, and includes everything required for automatic and manual DCCD operation, including a properly designed and handbuilt custom control module in a water resistant enclosure, with a nice adjustment knob for setting the locking force, this system is infinitely adjustable between fully locked and unlocked.
Each control module is fully bench tested prior to shipment.
Technical Details:
Microchip's PIC 16F887 microprocessor
2 axis high resolution g-sensor
custom firmware with driver adaptive capability
several internal modes based on driver throttle behavior and g- sensor behavior that switches on the fly automatically
DCCD calculations are using advanced formulas instead of unintelligent static mapping or lookup tables
This controller also features direct manual control of the center diff
Can be optioned with both the OEM STi thumbwheel control and OEM STi Auto / Man switch so that you can maintain the factory look.
Can also be optioned with an interface to the STi cluster display to show "real time" power output to the DCCD.
jamesfacts is offline   Reply With Quote
Old 01-25-2012, 09:36 PM   #2
jamesfacts
Member#: 51282
98 RS
Sold!
Old 01-26-2012, 09:13 AM   #3
jamesfacts
Member#: 51282
98 RS
PMs replied
WTB : DCCDPro Universal Controller pezcore Private 'Wanted' Classifieds 13 01-05-2012 02:28 PM
FS : BRAND NEW Hallmann Pro RX Manual Boost Controller Kit - Anodized Blue urabus2 Engine/Power/Exhaust 0 04-19-2011 01:16 AM
FS : DCCDpro auto controller abgusaf Drivetrain 14 12-12-2010 07:23 PM
fs: Auto Driveshaft, DCCDPro Universal Controller Mooneyes13 MWSOC Private Classifieds 0 03-09-2010 11:01 PM
Installing Cruise Control Kit - stripped square bolt Keshav Service & Maintenance 8 06-30-2004 10:03 PM
