Old 01-26-2012, 09:49 AM   #1
Rejukem89
Member#: 229456
2002 Impreza WRX
Default Identifying EJ22 Engine
I have a question and cannot seem to find an answer on any forum (NASIOC, FastWRX, Scoobymods). I bought an 02 WRX last year and was made aware that the engine was swapped out by a previous owner. I discovered later that the clutch was slipping and a bearing in the tranny was bad so this month I finally started on that project. Upon removing the transmission I discovered missing bolt holes, then found out there was an EJ22 engine block in my car. Short of removing the engine is there anyway to tell if the engine is closed deck? Or if the previous owner was just cutting corners.
Thanks
Rejukem89 is offline   Reply With Quote
Old 01-26-2012, 10:13 AM   #2
RallyColtTurbo
Member#: 16819
The bulge on the bellhousing for the starter......
Smooth = open deck
Ridges = closed deck
Seach for "closed deck hatching" or "closed deck grid" for pictures.
RallyColtTurbo is offline   Reply With Quote
Old 01-27-2012, 01:09 PM   #3
Rejukem89
Member#: 229456
2002 Impreza WRX
Thank You
Old 02-02-2012, 01:22 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The stock block might have had a failure, and he decided to throw in an EJ22 for more power.
The motor is open-deck, as is the EJ205, so not really a problem. Replacing a blown EJ205 for an EJ22 is a good move, IMHO.
~Josh~
how to read/identify EJ25 Engine Serial number ChAi Subaru Conversions 2 05-19-2011 09:12 PM
Help me identify these engine bay plugs! sith Subaru Conversions 10 06-08-2006 08:24 PM
Help identify this engine sith Subaru Conversions 15 06-14-2005 07:46 AM
Need help identifying EJ22 Soob_pwr Normally Aspirated Powertrain 4 01-13-2002 11:28 PM
