Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Alaskan Impreza Club
Old 01-26-2012, 06:44 PM   #1
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Default huge trail of smoke
Huge trail of smoke behind me driving. Whats that mean
cosseywrx is offline   Reply With Quote
Old 01-26-2012, 06:59 PM   #2
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
What color smoke?
Old 01-26-2012, 06:59 PM   #3
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Something went bang...white or black smoke?
tribalwrx is online now   Reply With Quote
Old 01-26-2012, 07:11 PM   #4
cosseywrx
Member#: 276443
Heavy white smoke. Overboostn part throttle. Sucking down oil as well. Just added a qrt last weekend and its past low mark on dip stick. Gonna check the turbo this weekend i guess. Only did.this for 5-10 mins on highway then it stopped
Old 01-26-2012, 07:20 PM   #5
cosseywrx
Member#: 276443
i did some searching....bad turbo or excessive crank case pressure from possible clogged AOS.
Old 01-26-2012, 07:26 PM   #6
coldfiremx
Member#: 285848
Make sure and verify the head gasket is not leaking. PM me if you have any questions.
coldfiremx is offline   Reply With Quote
Old 01-26-2012, 07:27 PM   #7
JordyB
Member#: 20328
'05 FXT - '98 Foz
'07 Legacy spec.B
cracked ring-land?
JordyB is offline   Reply With Quote
Old 01-26-2012, 07:35 PM   #8
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Smell the smoke. Identify oil or coolant smell. When turbo goes bad this is one of the things that can happen.
Look for other obvious stuff wrong, intake and ic drowning in oil, lines blown off.
How is it at idle? Rough and smoke?
Compression check will rule out some basic stuff.
P3Auto is offline   Reply With Quote
Old 01-26-2012, 07:52 PM   #9
cosseywrx
Member#: 276443
Idle is smooth. Pretty sure its oil thing. Coolant level hasnt moved on over a year. Niether has the color of it. Ive hag to add lots of oil tho. Gonna remove aos and check the turbo. Compression test as well
Old 01-26-2012, 10:27 PM   #10
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
see the milky oil thread!
Nomadgene is offline   Reply With Quote
Old 01-28-2012, 03:29 AM   #11
cosseywrx
Member#: 276443
welp all cyclinders tested good in my eyes....the aft two were high tho.
1 and 2 cyl 150 psi
and 3 and 4 were 210 psi
heres some pics of where all the oil went to...removed the aos and returned that to stock and i will buy new spark plugs and refill the oil and start her up tomorrow.
enjoy
Old 01-28-2012, 03:32 AM   #12
cosseywrx
Member#: 276443
all because i of the AOS is how i see it...wouldnt let the crank bleed of built up pressure.
Old 01-28-2012, 04:21 AM   #13
JesseL
Member#: 169556
07' OPB STi BW S256
01' 2.5rs GM6 w/leather!
Yup, tis why I got rid of my Grimmspeed AoS... Tanks + Extreme cold = win
I popped the seals on my BorgWarner on a really cold day last year, Bullseye turbo said most likely from to high oil pressure
JesseL is offline   Reply With Quote
Old 01-28-2012, 04:26 AM   #14
cosseywrx
Member#: 276443
just needs some clean love then back on the road again!
so a catch can is the way to go then?
Old 01-28-2012, 04:28 AM   #15
AKSubie
Member#: 6214
92 Corrado SLC
www.motorsportsalaska.com
ironically, I had a similar thing happen to me this evening on the way home. Freaked me out and thought I had blown a turbo as well.
I think it was my PCV system got frozen/clogged as there was no smoke after having the car looked over with Tim. Still freaky though.
AKSubie is offline   Reply With Quote
Old 01-29-2012, 08:06 PM   #16
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Heated AOS --- http://store.crawfordperformance.com/store/products/73
Those compression readings are pretty interesting. Thats a large variation 150-210.
WRX Specs Compression:
Compression (at 200 - 300 rpm):
Standard
981 - 1,177 kPa (10 - 12 kgf/cm2, 142 - 171 psi)
Limit
882 kPa (9.0 kgf/cm2, 128 psi)
Difference between cylinders
Less than 49 kPa (0.5 kgf/cm2, 7 psi)
Old 01-29-2012, 09:00 PM   #17
cosseywrx
Member#: 276443
In the process of pullin the intake mani and what not. After it gets back together i will run it and do another comp test
Old 01-29-2012, 09:18 PM   #18
coldfiremx
Member#: 285848
When you do the compression test again heres a few tips. Make sure you have a battery charger hooked up to the battery @ 40 amps to ensure equal cranking voltage and crank speeds, make sure you hold the throttle wide open and also make sure your crank duration is consistent throughout the tests. All of those tips should help make your results as accurate as possible.
Old 01-30-2012, 04:19 PM   #19
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Also expect lower numbers if the motor is cold.
Old 01-30-2012, 07:07 PM   #20
shaggydog
Member#: 247390
'11 STi
Does this happen a lot with the GS AOS when it comes to extremely low temps? Also would the oil weight play another factor in this as well?
shaggydog is offline   Reply With Quote
Old 01-30-2012, 07:20 PM   #21
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
There have been reports of this on the internet. Even a catch can has frozen up if its cold enough and mounted in a cool spot.
We have not seen this car but if his compression has anything to say, even with the numbers being out of whack (gauge is wrong) the difference between the cyls is very large so I would speculate to say the problem is more than just the AOS if the next result is the same.
We will see when he gets it checked again. The last time we saw this much oil in an intake it was two broken ring lands and a completely cracked piston.
I hope it turns out ok for this guy.
Sorry your other question about oil. The reason the AOS will block up is due to water vapor and moisture that can freeze up in the lines. Oil can gunk up for sure if its thick but usually not block.
I think really if people have concerns or they see ice buildup they should just install a tee in its place until the weather warms up.
Small amount of smoke coming out of scoop after service statik213 Newbies & FAQs 6 10-05-2010 10:55 PM
FS : Cleaning of shop sale, huge variety of parts, Turbos, Shortlocks, Suspension.. Oh MY! MartinSTi05 MWSOC Private Classifieds 16 08-16-2010 03:38 PM
a lot of smoke coming off of rear cat partingwrex88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-03-2009 09:49 PM
New Trail of Dead album is available on the Intramaweb Fach Off-Topic 4 10-26-2004 01:55 PM
June 8th Trail of Tears Rallycross DammitBevis Mid West Subaru Owners Club Forum -- MWSOC 0 06-05-2003 08:09 PM
