Old 01-26-2012, 06:05 PM   #1
bluesubie
Member#: 767
04 FXT
Ok, you Honeywell haters/Framophobes. You now have a new Wix option. I was browsing the Newbie forum and came across a reply stating that there is a brand new Wix filter with the Subaru 23 psi bypass seting that wasn't even in stores yet. The person did not state their source.
I checked Wix's site and found this pdf in the news section showing the 57712 mentioned in the reply, but no mention of bypass (bottom of list):
http://www.wixconnect.com/assets/WIX...7-2012)NOP.pdf
So I sent an email to Wix and received the following reply:
[email protected]> wrote:
bypass valve is set at 23 lbs. of differential pressure.
Thank you for your interest in WIX Filters.
check out our website @ www.wixfilters.com
National Hotline (800) 949-6698 Mon. 8-5,
Tues 8:45-5, W-F 8-5 (Eastern)
Hi,
What's the bypass pressure on your new 57712 oil filter for Subaru applications?
Thanks,
Dennis
Happy hunting!
Old 01-26-2012, 09:59 PM   #2
ndtechie_rx8
Member#: 118011
2011 WRX Limited
World rally blue
thanks!
ndtechie_rx8 is offline   Reply With Quote
Old 01-27-2012, 07:31 PM   #3
SubLGT
Member#: 207528
2005 Legacy GT
bluesubie also provided these dimensions (in a bitog posting):
"Height is 2.577. Is diameter "O.D."? That's 2.685.
Flow rate is 9-11 GPM's."
Those dimensions are the same as I measure on the black Tokyo Roki xxxxxxA100 filters.
Subaru says the oil pump in the 2.5L turbo motor can put out 12.4 gal/min, or more, at 5000rpm and 176 degF.
SubLGT is offline   Reply With Quote
Old 01-28-2012, 01:10 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000000000000000000000000000000000000000000 0000d!!!!!
does anybody know what the 3.0 H6 oil pump will put out??
i have no factory service manual on that one
Old 01-28-2012, 11:04 AM   #5
bluesubie
Member#: 767
04 FXT
So is O.D. diameter? I might drop by Autozone later and see if they have it in their computer yet. Have three filters that I got free with oil purchases that I was going to use in the RS and want to try to swap them.
My guess is that we're still a few weeks away from being able to get this since it only became available from Wix two weeks ago.
-Dennis
Old 01-28-2012, 11:18 AM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Napa Gold # FIL 7712
http://www.napaonline.com/Catalog/Ca...712_0352281275
Part Number: FIL 7712
Product Line: NAPA Gold Filters
Attributes:
Beta Ratio : 2/20=6/20
Burst Pressure : 300 psi
Flow Rate : 9 - 11 gpm
Gasket I.D. (Inches) : 2.173"
Gasket I.D. (mm) : 55 mm
Media Type : Cellulose
Oil Filter Gasket O.D. (Inches) : 2.475"
Oil Filter Gasket O.D. (mm) : 63 mm
Oil Filter Height (Inches) : 2.577"
Oil Filter Height (mm) : 65 mm
Oil Filter O.D. (Inches) : 2.685"
Oil Filter O.D. (mm) : 68 mm
Oil Filter Style : Spin-On Lube Filter
Oil Filter Thread Size (mm) : 20 x 1.50 mm
Features and Benefits: Best Efficiency + Capacity In Industry
Steel Coil Spring
Spiral Wound Center Tube For Industry Leading Strength
Has a 23 lb. By-Pass Relief Valve Setting
Silicon Anti-Drain Back Valve - Industry Leading Life
Holds 45% More Dirt, Last 30% Longer Than Other Leading Brands
21 Micron
flstffxe is offline   Reply With Quote
Old 01-28-2012, 11:57 AM   #7
bluesubie
Member#: 767
04 FXT
I guess that answers your question about whether or not this will be available as a NAPA filter!
-Dennis
Old 01-28-2012, 01:45 PM   #8
SubLGT
Member#: 207528
2005 Legacy GT
Originally Posted by bluesubie View Post
So is O.D. diameter?.......-Dennis
O.D. = outside diameter
Old 01-28-2012, 02:12 PM   #9
SubLGT
Member#: 207528
2005 Legacy GT
Has anyone ever seen a flow rate specification for a Subaru OE oil filter? I am wondering if the 9-11 gpm of the Wix/Napa filter is adequate for the >12.4 gpm that the oil pump can presumably pump through the engine.
It is not clear to me whether that 12.4 gpm spec was determined on a test bench with no output restriction on the pump, or on a fully assembled motor with its numerous flow restrictions.
Old 01-29-2012, 01:13 AM   #10
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
The flow restrictions shouldn't matter as long as the pressure relief valve stays closed, and that opens at 85psi IIRC.
The spec is incomplete at best. 9-11 GPM under what conditions? 9-11 GPM before the differential pressure is 23psi? Could be, but with oil at what viscosity? How about contaminant loading? Is the filter clean or dirty for this test? Pretty meaningless if you ask me.
Good to know somebody else has come up with a 23psi filter for Subarus, though. Now there are three, OEM (Honeywell) Wix(Napa Gold) and Beck/Arnley. I suppose you could count the OEM Sti Tokyo Roki too if you're willing to pay through the nose.
gpshumway is offline   Reply With Quote
Old 01-29-2012, 01:43 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
dont forget the 3.0 h6 filter
Old 01-29-2012, 02:16 AM   #12
subi400
Member#: 216984
1996 Impreza outback
Green
I found the H-6 3.0 pureOne purelator here at Fred Meyer, but the part where it screws onto the engine is recessed into the filter, so it won't fit on my 96 impreza only a wrx.
I am not saying it is not an excellent filter just stating this for other people to know
On a side note, I would also like another option besides the purelator (this Wix one) if I can't get it for some reason....
subi400 is offline   Reply With Quote
Old 01-29-2012, 11:00 PM   #13
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
I thought the H6 filter was too big to fit on a 2.5 turbo with the exhaust close to the filter. I thought it only fit on 2.0 turbos. Do I have it wrong? Is it still a Tokyo Roki?
I presume it's the same filter for the 3.6.
Of course the old black AA100s apparently don't have the 23psi bypass valve either.
Old 01-29-2012, 11:18 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
well...there is a black tokyo roki filter that i got at the dealer 2 weeks ago on my 06wrx right now......now i didnt ASK....but i ASSumed that it was the 3.0 h6 filter because that is what had been discussed about 30 minutes prior to this filter being handed to me
it aint blue and it is a bit longer than the h4 filter...that is what i know.....i suppose i could go out and look at it and see if i can see the pn on it.....but id rather not do that tonite
and i dont know if the h6 3.0 and 3.6 filters are the same or not
Old 01-30-2012, 02:02 PM   #15
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Great info, thanks Unc!
Edit:
No need to look for the P/N. SGP has it on their website: 15208AA031
https://www.subarugenuineparts.com/p...oducts_id=1055
Looks like it's for all H6 cars, doesn't say 3.0 vs 3.6. Makes sense, I believe the blocks are the same or very similar.
Old 01-30-2012, 02:12 PM   #16
ndtechie_rx8
Member#: 118011
2011 WRX Limited
World rally blue
Edit:
Actually just installed this one this morning on my 11 wrx. Fits good. Wider than the punny blue one.
Old 01-30-2012, 02:12 PM   #17
ndtechie_rx8
Member#: 118011
2011 WRX Limited
World rally blue
Forgot to add that my parts dept guy recommended this one over the blue one. Says a lot of the their techs are doing the same thing.
Old 01-30-2012, 08:20 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
doh...another Uncle secret gets exposed
Old 01-31-2012, 08:32 PM   #19
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Napa Gold 7712
Specs:
OD: 63mm
Length: 65mm
Thread: M20x1.5, Roll-formed
Spring type: Coil
Bypass Valve: 23 PSID, Upfront.
Anti Drain Back Valve: Yes, Silicone
Media type: Cellulose
Media Surface area: 303.4cm2
Beta Ratio: 2/20=6/20
Flow Rate: 9 - 11 gpm
Gasket style: Square ring
Oil inlet hole/s area: Eight 6.25mm holes. 245.44mm2.
End caps: Metal
Can side thickness: .33mm
For those curious, The outlet hole in the oil filter mounting stud measures 12.25mm via a gage pin, an area of 117.85881189482959mm2 or ~1.17859cm2.
Old 01-31-2012, 08:50 PM   #20
nashcarr
Member#: 131897
2010 STi 05 FXT
SSM
Will these work on the GR STi as well?
nashcarr is offline   Reply With Quote
Old 01-31-2012, 10:55 PM   #21
ndtechie_rx8
Member#: 118011
2011 WRX Limited
World rally blue
That I'm not sure about but I'm sure uncle scotty can answer
Old 02-01-2012, 02:25 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
dunno.......ya gonna hafta see if it will physically fit....i dont think the threads are different or anything else that matters other than the physical size being different
Old 02-01-2012, 08:29 PM   #23
nashcarr
Member#: 131897
2010 STi 05 FXT
SSM
I will pick one up at the dealer and give it a go for my next oil change.
Old 02-04-2012, 07:26 PM   #24
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
what about the 15208aa130 filters?? they are for the new fb25 in the 2011- na foresters. i have a case of them for my wifes forester. the treads and o-ring seating surface are identical to my 15208aa100 i use on my wrx. when i use my last 2 of those black roki filters can i use the forester filters on my wrx.? i know i have to run 0w20 in her forester. does anyone know if the bypass pressure would be the same?? i can post a picture if needed. thanks for any input.
424wrx is online now   Reply With Quote
Old 03-31-2012, 12:20 PM   #25
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
so has anyone used the wix filter?
BigRob74 is offline   Reply With Quote
FS : ((SOLD)) 2 WIX filters - 1 Fram N.I.B. WRX dntouch MWSOC Private Classifieds 0 07-04-2011 01:04 PM
FS/FT : See updates! K&N air filter - 02-07 WRX - NEW fivestringslinger Engine/Power/Exhaust 5 12-27-2010 09:42 PM
Import Face-off: New England Dragway - 5/23/10 GSRcaucAZN78 New England Impreza Club Forum -- NESIC 24 05-25-2010 09:29 AM
10/2008 - - Subaru announces new oil filter Subie Gal Service & Maintenance 287 01-05-2010 03:57 PM
Calling all Rally fans! Rally New York - September 22 - 23 gleinz New England Impreza Club Forum -- NESIC 5 09-12-2006 09:23 AM
