Old 01-26-2012, 08:31 PM   #1
05wrx89
Member#: 274159
06 sti
obp
Default Cobb ap ecu reset
Have a 06 sti
Mods are:
Turbo xs catted downpipe
Full turbo xs exhaust
Cobb sf intake
Aps 50/50 bov
Currently running Cobb stage 2 map
Problem:
One day I was checking to see if I had any codes just to make sure and accidentally hit reset ecu (just wasn't paying attention) and ever since that timing has been a issue such as....
Dynamic advance multiplier (.6)
And I believe it was knock feed back (-2.1)
Prior before resetting the ecu car was perfect
Dam (1.0)
Knock feedback (0)
No matter what gear it always read the same but I always focused on d.a.m
Could this just be the ecu relearning everything still or could I be having issues after the reset
All helpful input would be greatly appreciative
05wrx89 is offline   Reply With Quote
Old 01-26-2012, 11:17 PM   #2
Cobb Tuning
Member#: 4803
Originally Posted by 05wrx89 View Post
Have a 06 sti
Mods are:
Cobb sf intake
Aps 50/50 bov
Problem:
Dam (1.0)
Knock feedback (0)
There may be one of two possibilities here:
1. You had a different real-time map flashed than the base map and resetting the ECU cleared the real-time map and therefore the base map tune is now the "complete" tune and that tune is not working as well as the base + real-time you had before. This is an easy check. If this is a v2 AP, then simply go to Tune -> Show current map and make sure it is the correct map for your mods and octane of gas.
2. Resetting the ECU cleared the learned parameters which were accounting for a mechanical issue that your car had. An example would be the long-term fuel trims accounting for a lean issue.
If you have a v2 AP, the best thing you can do is to get a data log:
Bill
Old 01-26-2012, 11:39 PM   #3
05wrx89
Member#: 274159
06 sti
obp
I checked current map and I'm running the stage 2 map 93 oct same map as I've been running prior before the reset
Is it possible that the ecu adapted to my slow driving or what should u reset it again and throw it in 4th gear at 2500rpm and see what happens
Old 01-26-2012, 11:54 PM   #4
Cobb Tuning
Member#: 4803
No, the DAM should not drop regardless if you are driving like a grandma or going WOT every chance you get. The DAM will drop to an initial value after you reflash a map or reset the ECU. That initial value isn't an indication of knock, but for your car and that particular map, it should start out at 0.5 (same as the factory initial) and jump up in steps of 0.25 until it reaches 1.0 (assuming it doesn't see any knock when it is actively learning). So, a value of 0.6 indicates it dropped at some point.
A lot of the learning functions occur with moderate closed loop driving. This is the case with long term fuel trims and would be the most likely learning function that could cause problems if reset. For example, it may have learned to add 10% fuel due to a mechanical problem with your car that is causing a lean condition (intake leak, bad MAF, etc). So, when you reset the ECU, now your car is running lean again. Best way to check these is to drive for about a week (normal cruise-type driving) and then check your A/F Learning 1 A, B, C, D values via the AP live monitor function (or you can also log them). If any one is outside of +/- 5% you may have a problem and more likely if any one is outside of +/- 8%.
Bill
Old 01-27-2012, 01:11 AM   #5
05wrx89
Member#: 274159
06 sti
obp
https://docs.google.com/spreadsheet/...2tjc3UzemJ2c3c
heres my datalog i just did sorry for the long list didnt know how to chop it down but as you would notice the only change im getting is knock learn and a/f correction DAM is not changing what so ever
Old 01-27-2012, 09:26 AM   #6
Cobb Tuning
Member#: 4803
You'll want to reset your logging list to the default setting as just those 5 parameters aren't enough to determine anything. You also want to put the car under some heavy load (if you can do safely) while logging as per the logging video posted earlier. This will tell us how the car reacts under more extreme conditions.
Bill
Old 01-27-2012, 10:52 AM   #7
05wrx89
Member#: 274159
06 sti
obp
Well today I reflashed to stage 2 again and about a min of driving it went straight to 1 on dam a/f reading normal feedback knock reading 0 I am going to log it after work and pull it in my shop just to double check all vacuum hoses and soon to get rid of my bov ants buy the xle bpv from cobb
Cobb AP not resetting engine code 08 STI MagikMuzik AccessPort 9 04-02-2010 12:39 PM
Cobb AP ECU reset mostasz AccessPort 2 06-01-2008 10:45 PM
Bay Area: MY04 EcuTek WRX ECU trade for Cobb AP ECU mcdrama Private 'Wanted' Classifieds 1 11-21-2005 03:24 PM
FT: '04 STi Ecutek ECU for '04 STi Cobb AP + ECU ninjaboy76 Private 'For Sale' Classifieds 8 09-29-2005 01:25 AM
Question about Cobb Stage1 / ECU reset Triton05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-01-2005 12:37 PM
