Old 04-15-2012, 09:40 AM   #51
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
My autometer remote install is holding up solid as well.
Hangs around 80 lbs when driving and bumps down to 25 lbs at stop lights.
My sender is about 1.25" in diameter & 2.25 in length. It definitely would require a remote line. Not sure if autometer makes a smaller oil pressure sender.
ckswanecamp is offline   Reply With Quote
Old 04-15-2012, 04:57 PM   #52
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
The one I'm going to install is the 2446 sensor, tiny. The one I currently use is the huge gold type with two terminals, and it fits in the rear oem location although very snug.
2slofouru is offline   Reply With Quote
Old 06-08-2012, 12:39 AM   #53
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Update on the sender kit... so far everything's holding up great.
Old 07-30-2012, 10:51 PM   #54
sol_tegra
Member#: 259406
02 WRB WRX
thanks on the infor txl146, keep on updating us?
btw, great write up!!! how many miles have you put on since?
sol_tegra is offline   Reply With Quote
Old 09-28-2012, 03:10 PM   #55
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
So far no issues whatsoever...
Probably 5k+ miles?
Old 09-29-2012, 10:47 PM   #56
FG2toGDF
Member#: 292537
2004 STi
This is awesome. Used this for my sender relocation last night and man was $10 well better than the OTS offered for $50-$60. Thanks for this.
FG2toGDF is offline   Reply With Quote
Old 10-11-2012, 12:11 AM   #57
raabguy
Member#: 265021
I know this thread is kinda old, but maybe someone will answer me. I just got a grease gun hose and the female-female fitting. about to order the gallery plug. But when i take the end piece off the hose (not sure what the piece is called but it obv wont fit with it on) there is a little bearing kinda ball in there, do i take that ball out or leave it in??
raabguy is offline   Reply With Quote
Old 10-11-2012, 05:42 AM   #58
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Is the bearing located inside the grease fitting (center of picture) or inside the hose? If its inside the hose, i would get a different hose. If its not in the hose, and located inside the grease fitting, why would you take out the bearing?
Old 10-11-2012, 01:14 PM   #59
raabguy
Member#: 265021
The bearing is between the hose and grease fitting, but kind of sits in the end of the hose. (it'll fall right out if i tilt the hose), and there is a spring sticking out of the grease fitting that holds it tight in place when the fitting is screwed onto the hose.
And its the only grease gun hose they had in home depot lol -_-
Old 10-11-2012, 01:33 PM   #60
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Ya get rid of that bearing, spring, and everything else minus the hose + threads. A bearing could block the pressure from the sender. You don't want that.
Old 10-11-2012, 01:36 PM   #61
SubiSteveGD
Member#: 256552
2004 impreza wrx sti
java black pearl
thats a really cool idea. thanks for sharing. getting ready to install some gauges i just picked up. Might give this a try
SubiSteveGD is offline   Reply With Quote
Old 10-11-2012, 01:39 PM   #62
raabguy
Member#: 265021
Okay that's what i thought i just wanted to make sure, thanks alot.
Old 10-14-2012, 01:40 AM   #63
raabguy
Member#: 265021
Oh yea, this is a noob question, but when i install the sender with the hose, should the oil pressure sensor be lower than the gallery plug? Like so the oil can flow downhill to the sender? Or does that not matter lol.
Old 10-14-2012, 09:39 AM   #64
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
No it doesn't matter. Pressure is pressure.
Old 10-14-2012, 11:17 AM   #65
raabguy
Member#: 265021
gotcha thank you!
Old 10-20-2012, 12:24 AM   #66
raabguy
Member#: 265021
Ok so im getting a little frustrated, apparently the ball bearing was inside the grease fitting cause i guess i unscrewed the grease fitting in half. Now this nut is stuck on the end of the hose..
This is supposed to come off right? I have been trying to get it off with 2 wrenches and it will not budge, my dad wasnt able to get it apart either. wtf, has anyone else had this problem??
Old 01-08-2013, 11:15 PM   #67
aod12
Member#: 282701
2008 FXT
Bump because I had this problem. Lightly, very lightly heat it up then go at it with the wrenches again
aod12 is offline   Reply With Quote
Old 01-16-2013, 05:50 PM   #68
Jfive575
Member#: 263613
2009 WRX
So from reading this tread I am slightly confused, I have the performace series prosport oil pressure gauge. Will the OEM galley plug work with this DIY kit?
Jfive575 is offline   Reply With Quote
Old 01-16-2013, 09:12 PM   #69
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
No you need the adapter
Old 02-14-2013, 04:39 PM   #70
two_point_5RS
Member#: 343220
2005 WRX
white and green!
just out of curiosity and because i have the stuff lying around here, couldnt i use the copper lines and fittings used for the mechanical oil gauge to make this instead of the grease gu n hose?
two_point_5RS is offline   Reply With Quote
Old 02-14-2013, 05:16 PM   #71
Paidfor
Member#: 267815
Be in awe
dont hate .)
Why would you want a mech/electrical sensor of any kind? You have a 100% accuracy with a mechanical sensor........why would you want to send direct pressure from a foolproof oil supply line to a electronic sensor that manipulates the pressure reading into a digital readout? I mean if your connection is faulty at the mech gauge inside the cabin...i see where that would be a prob( oil leaking into cabin possibly). Thats like sayin " im not comfortable with fuel lines running under my backseat because of a potential leak". If its connected correctly....its not gonna leak. What i see is accuracy issues with the interpretaion of the anolog to digital signal. Just not as reliable as a TRUE mechanical connection. Nothing is more accurate than that.
Paidfor is offline   Reply With Quote
Old 02-14-2013, 05:22 PM   #72
two_point_5RS
Member#: 343220
2005 WRX
white and green!
ok yourr not getting what i mean i guess... i have electric gauge, now, i want do same method as this only i would use the copper line to go from oil galley adapter to the sending unit... i know itll work but just wanted to see what ppl thought... same process as the grease gun hose except its a copper line...
Old 02-21-2013, 08:14 PM   #73
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Originally Posted by Unabomber View Post
That's gangsta! Be sure to follow up and let us know how it is holding up!
Working great after >1 year without any sign of issue.
Old 04-05-2013, 08:17 AM   #74
itr1416
Member#: 285347
2005 WRX STi
Originally Posted by txl146 View Post
Didn't want to spend almost $50 shipped for a remote kit from Prosport. Instead I bought 12" grease gun hose (rated for 4500 psi) with 1/8" NPT size and 1/8" NPT fitting to build my own remote oil pressure sender kit.
Pictured below:
1. Prosport oil pressure sender.
2. Prosport oil gallery plug
3. Grease gun hose purchased from Home depot (~$7)
4. 1/8" NPT fitting from Home depot (~$1.50)
Thanks to Vision.dynamix for the idea.
Installed pictures from today (used heat reflective tape on oil pressure sender and applied a lot of dielectric grease)
Most important:
Cold idle (Prosport EVO digital gauge)
http://youtu.be/1nvh2RWbVyE
Removing the stock OEM oil pressure sensor does not cause your oil light on the dash to come on or the ECM to throw a CEL?
itr1416 is offline   Reply With Quote
Old 04-05-2013, 08:31 AM   #75
aod12
Member#: 282701
2008 FXT
^ no it doesn't
WTB : Remote Oil Pressure Sender Installation Kit EROCS04SBRUSTI Private 'Wanted' Classifieds 0 12-23-2011 05:10 PM
WTB : Remote Oil Pressure Sending Kit Dborne Private 'Wanted' Classifieds 0 07-21-2011 02:49 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: Oil pressure sender relocation kit. bisonjr MAIC Private Classifieds 0 03-07-2009 06:04 PM
WRXtra Oil Pressure Sender Installation Kit drees Car Part Reviews 1 06-21-2004 08:09 PM
