Old 05-01-2014, 11:41 AM   #101
Keaton522
Member#: 279103
2002 WRX Hybrid
Thanks for posting that! Ill be going with thread sealant even though ive never read about teflon tape making it into a galley... I had also never heard of shims cracking in half in the cylinder head, but that happened on my last build (with proper clearence!) soooo
Keaton522 is offline   Reply With Quote
Old 05-01-2014, 11:44 AM   #102
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
generally speaking avoid teflon tape in fluids that cannot have any debris without possible failure. fuel lines are a big one.
Old 05-02-2014, 07:03 AM   #103
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
these....
http://www.permatex.com/products-2/p...hread-sealants
are WAY-WAY better than any old school teflon tape
Old 05-02-2014, 01:28 PM   #104
rocketperson7
Member#: 283968
2003 WRX
MBP
Originally Posted by rocketperson7 View Post
guys use this instead of teflon tape, works eleventy times better and won't ruin an engine if it somehow makes it into a galley:
http://www.permatex.com/products-2/p...sealant-detail
Originally Posted by Uncle Scotty View Post
these....
Yep
rocketperson7 is offline   Reply With Quote
Old 05-11-2014, 08:41 PM   #105
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Very cool mod!
Now is the thread sealant necessary on NPT threaded sensors? I'm worried about anything foreign working into the oiling system.
ShinjiML is online now   Reply With Quote
Old 06-16-2014, 02:59 PM   #106
Erdahl
Member#: 366915
2006 FXT
Royal
Lightbulb
Interesting thread. There is some good info here. Thanks a lot guys!
Piece of mind is important to me so I'll stick with automotive specific performance parts for things like the hose... especially when a kit is somewhere in the range of $40.
For those that have seen fluctuations in pressure (for example; high oil pressure during driving with a pressure drop at idle and/or low pressure at start up but the pressure raises once engine comes up to temperature); did you burp the oil pressure line to get rid of the air pocket? If so, how did you go about doing it?
Erdahl is offline   Reply With Quote
Old 06-16-2014, 03:02 PM   #107
turkeylord
Member#: 89016
2005 Legacy GT Wagon
ABP
I used the line to fill my engine so mine was filled that way...
http://legacygt.com/forums/showthrea...nk-214760.html
turkeylord is offline   Reply With Quote
Old 07-08-2014, 02:07 PM   #108
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
So far so good after 2+ years....
Old 07-17-2014, 12:18 AM   #109
mgreen39
Member#: 325668
2002 WRX Wagon
mgreen39 is offline   Reply With Quote
Old 07-17-2014, 02:49 PM   #110
damp_monkey
Member#: 335118
2002 WRX sedan
Originally Posted by mgreen39 View Post
Just picked up a 1/8th inch grease gun hose off amazon for $5.35. I'll let you all know how the install goes.
Amazon.com: Lumax LX-1201 Black 12" 1/8" NPT 4500 PSI Thermoplastic Grease Hose: Automotive
I've been using that same one for a couple months now and it's working great. Can't speak for how it will handle through the winter though
damp_monkey is offline   Reply With Quote
Old 07-17-2014, 11:56 PM   #111
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I did the DIY $10 Remote Oil Pressure Sender mod today.
Prior to that I was running two 90 deg fittings to allow the ProSport pressure sender to clear the alternator. This was OK, except it wasn't screwed in real tight due to the necessity to be able to "clock" it for proper alternator clearance. Eventually it developed a small leak and it didn't seem like it was going to get any better, so I went for the remote install mod.
Here's a shot of the "before" setup:
I bought the parts from Home Depot. Online they show a 12" hose for $5, but in the store they only had the 18" hose that costs $9.62. The 1/8" straight coupler was $2.65 so the total with tax came out to be just over $10. If you order parts online, or go to Harbor Freight, you could probably do this for close to $5. I would keep in mind where you want to mount the sender, I think 18" is actually just about perfect.
Here's a shot of the parts:
First step is to remove the grease gun adapter from the end. It appears to be held on with red Loctite, but I got it off with just normal wrenches and no heat.
Here's a photo with it off:
Then just screw all the parts together. This is a mock up. I ended up deciding to put the strain relief spring on the end that goes into the galley plug and into the block. I figured there was more chance for stress there since it was hard mounted. I don't think it really matters though.
Here's a shot of it going into the block:
I ran it behind the alternator and zip tied it to the alternator wire's loom.
So far so good. Seems to be a great solution and much cheaper than the kits they sell. And waaay better than the two 90 deg fittings that I was using before.
xluben is online now   Reply With Quote
Old 10-10-2014, 08:01 AM   #112
no694terry
Member#: 220816
98 Forester S/t
heart breaker
Doing this soon, after my second sending unit failed being screwed into block. I used a 24" grease gun hose years ago on my land rover and it worked fine. I always thought it may have read a couple pounds low being mounted so far away but it was probably just the gauge. At idle it read 0, but it was a flat tappet rover that got 20psi on a good day.
no694terry is offline   Reply With Quote
Old 02-19-2015, 08:46 PM   #113
lookylookitzadam
Member#: 348254
2013 WRX
Just ordered the parts today and will be installing this weekend. Thanks OP, this is a very creative solution.
How is everyone's holding up?
lookylookitzadam is offline   Reply With Quote
Old 02-19-2015, 11:32 PM   #114
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mine is holding up great. Good luck.
Old 04-06-2015, 11:35 PM   #115
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Where are you guys zip tying this to? Think I am gonna do this on the rally car.
sackytar is offline   Reply With Quote
Old 04-23-2015, 10:23 AM   #116
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Just checking in. I've had mine for about 2 years with no problems.
codesoccer is offline   Reply With Quote
Old 04-23-2015, 10:39 AM   #117
ShinjiML
Member#: 257231
Just added this to my built motor, working great!
Old 04-25-2015, 09:49 AM   #118
dan0492
Member#: 410519
thats sweet
dan0492 is offline   Reply With Quote
Old 05-18-2015, 11:01 PM   #119
Curves4days
Member#: 421525
great write up! i just finished installing this in my car and works flawlessly!
Curves4days is offline   Reply With Quote
Old 05-19-2015, 09:20 AM   #120
drewmob
Member#: 214192
2003 WRX
It's worth mentioning again that if your sending unit doesn't have a ground terminal it is depending on a body ground that this method doesn't provide. A ground wire from the body of the sender to a body ground is sufficient for a 1-terminal sender.
drewmob is offline   Reply With Quote
Old 07-07-2015, 06:29 PM   #121
guacamole
Member#: 354523
2014 WRX Hatch
Anyone able to keep the stock sensor with this method? Is the rear galley plug under the intercooler, and will it work with this method so I can keep the stock sensor under the alternator? I somehow doubt a BSPT tee and BSPT-NPT adapter would fit under the alternator...
guacamole is offline   Reply With Quote
Old 07-07-2015, 06:51 PM   #122
ShinjiML
Member#: 257231
Yes, I'm using the one under the tmic.
Old 07-07-2015, 10:47 PM   #123
turkeylord
Member#: 89016
ABP
Yup, +1.
Stock sensor is kind of worthless IMO though, I replaced mine with an oil pressure gauge. AEM sender just clears my alt.
Old 07-09-2015, 02:08 PM   #124
my name is joe
Member#: 171412
Stock light comes on too late. Not even worth keeping it
my name is joe is offline   Reply With Quote
Old 07-30-2015, 10:58 AM   #125
takeadirtnap
Member#: 344507
2010 WRX
hate to bump an old thread but anyone know what size deep socket you need to remove or install the plug into the block?
takeadirtnap is offline   Reply With Quote
WTB : Remote Oil Pressure Sender Installation Kit EROCS04SBRUSTI Private 'Wanted' Classifieds 0 12-23-2011 05:10 PM
WTB : Remote Oil Pressure Sending Kit Dborne Private 'Wanted' Classifieds 0 07-21-2011 02:49 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: Oil pressure sender relocation kit. bisonjr MAIC Private Classifieds 0 03-07-2009 06:04 PM
WRXtra Oil Pressure Sender Installation Kit drees Car Part Reviews 1 06-21-2004 08:09 PM
