Welcome to the North American Subaru Impreza Owners Club Thursday July 24, 2014
Old 01-28-2012, 07:14 PM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default Just got an ej20g long block :)
i got this for a very good deal and im just doing research into this motor.
on the block itself it says
im guessing its from a 97 impreza or leg.
also curious what the 22333 stands for too
i know the ej20g is a 8.5:1
is it true the forester ej20g a 9:1?
simprezl25 is offline   Reply With Quote
Old 01-28-2012, 08:00 PM   #2
trinistyles
Member#: 71627
780 Wrx/Fozzy/Legee
Wbp/Dark gray/Bergundy
Auto or Stick motor?
trinistyles is offline   Reply With Quote
Old 01-28-2012, 08:23 PM   #3
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
Post a pic of the valve covers. If it's a 97 it's probably an EJ20K
Old 01-29-2012, 01:39 AM   #4
RallyColtTurbo
Member#: 16819
2002 MBP WRX,'06 LR3
Three Gen 1 Legacy Turbos
IIRC, the "22333" is the main bearing line bore clearances from the factory. It helped the assembly workers pick the proper bearing for assembly.
The "AB" and "AB" are the bore sizes from the OEM hone. Once again, it helped the assembly workers pick the proper piston size for proper piston-to-wall clearance.
Not sure what the "97"s are for.
RallyColtTurbo is online now   Reply With Quote
Old 01-29-2012, 02:33 AM   #5
simprezl25
Member#: 71647
2002 Bug iD
how do i differentiate?
will post tomorrow! doing a search in wiki it says :EJ20K
to identify an EJ20K
* Wasted spark coil pack on center of manifold
* Inlet under manifold
* Divorced idle air controller
Usage:
* Impreza WRX & STi 9/96~9/98
cool thanks for the needed info!
Old 01-29-2012, 08:04 AM   #6
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
If that's the intake manifold that came with the engine it definately is an EJ20G built before mid-96.
Is the white sticker on the front timing belt cover still intact? The complete engine code is on there.
Marnix is offline   Reply With Quote
Old 01-29-2012, 03:07 PM   #7
trinistyles
Member#: 71627
780 Wrx/Fozzy/Legee
Pics of my 96-97 Jdm EJ20G intake manifold, motor was automatic and coil pack on top.
Old 01-29-2012, 03:09 PM   #8
trinistyles
Member#: 71627
780 Wrx/Fozzy/Legee
Usage:
Coil on spark plug for sure.
And I found this thread.
September 1996 - August 1997
Chassis
Engine
Power
Torque
Weight
WRX
GC8D48D
EJ20K
280ps
242 lb/f
1250kg
WRX RA
GC8D47D
EJ20K
280ps
242 lb/f
1190kg
WRX STI
GC8D4ED
EJ20K
280ps
253 lb/f
1250kg
WRX STI V-Limited
GC8D4ED
EJ20K
280ps
253 lb/f
1250kg
WRX STI RA
GC8D4DD
EJ20K
280ps
253 lb/f
1190kg
WRX Coupe STI Type R
GC8D2DD
EJ20K
280ps
259 lb/f
1190kg
WRX Coupe STI Type R Signature
GC8D2DD
EJ20K
280ps
259 lb/f
1190kg
WRX Wagon
GC8D58D
EJ20G
240ps
224 lb/f
1290kg
WRX STI Wagon
GF8D4DD
EJ20K
280ps
253 lb/f
1290kg
WRX STI Wagon V-Limited
GF8D4DD
EJ20K
280ps
253 lb/f
1290kg
September 1997 - August 1998
Chassis
Engine
Power
Torque
Weight
WRX
GC8E48D
EJ20K
280ps
242 lb/f
1250kg
WRX RA
GC8E47D
EJ20K
280ps
242 lb/f
1190kg
WRX STI
GC8E4ED
EJ20K
280ps
259 lb/f
1250kg
WRX STI RA
GC8E4DD
EJ20K
280ps
259 lb/f
1190kg
WRX STI RA V-Limited
GC8E4DD
EJ20K
280ps
259 lb/f
1190kg
WRX Coupe Type-R
GC8E2DD
EJ20K
280ps
242 lb/f
1190kg
WRX Coupe Type-R V-Limited
GC8E2DD
EJ20K
280ps
242 lb/f
1190kg
STI Coupe Type-R
GC8E2DD
EJ20K
280ps
259 lb/f
1190kg
WRX STI Coupe Type-R V-Limited
GC8E2DD
EJ20K
280ps
259 lb/f
1190kg
WRX Wagon
GF8E58D
EJ20G
250ps
226 lb/f
1290kg
WRX Wagon (*auto)
GF8E58P
EJ20G
240ps
226 lb/f
1320kg
WRX STI Wagon
GF8E5ED
EJ20K
280ps
259 lb/f
1290kg
22B STI (March - August)
GC8E2SD
EJ20K
280ps
265 lb/f
1270kg
Old 01-30-2012, 12:45 AM   #9
simprezl25
Member#: 71647
2002 Bug iD
no unfortunately i dont have the cover
Old 01-30-2012, 10:15 AM   #10
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
OK but if the intake came with the engine and the valve covers have ribbons on them and 4CAM 16VALVE then it definately is a coil on plug EJ20G with 8.5 compression ratio.
Old 01-30-2012, 07:23 PM   #11
simprezl25
Member#: 71647
2002 Bug iD
marnix thanks alot! yeah havent taken pics yet of the heads, stock usdm wrx is 8;1 right?
WTB : EJ20G long block tylology Private 'Wanted' Classifieds 3 02-08-2012 01:57 PM
02 wrx swapped ej20g long block ncskier96 Built Motor Discussion 2 06-26-2009 12:49 PM
f/s EJ20G long block sense of nature Engine/Power/Exhaust 10 04-12-2009 09:06 PM
'02 wrx ecu drive an sti long block? Bx_ReX Subaru Conversions 7 01-04-2007 09:42 PM
Newest *Official* Nasioc member :) Just got the wrx...well basically :) Sc3pt0r Mid Atlantic Impreza Club -- MAIC 5 06-26-2004 12:57 PM
