Old 01-29-2012, 12:35 AM   #1
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
Default Alternator belt kicking my a$$ - i feel stupid
06 WRX wagon minimal mods, Stg 2 - 56k miles
so i'm replacing both of my accessory belts...the AC belt was looking rough and the alternator belt was shredded very bad (very bad!)
sooo...i hit the parts store, grab some Gates Micro V AT belts and cross reference the part numbers myself to make sure the counter jockey is correct
The AC belt goes on easy, but the alternator belt seems like it's a 1/2" short - it is Gates K050345 / 5PK880
i have completely loosened the alternator adjuster, and pushed it down so it would be completely slack and the belt won't even go on - this is a dumb 20 minute job...i'm at my wit's end. What am i missing?!
rubrduk is offline   Reply With Quote
Old 01-29-2012, 01:06 AM   #2
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Maybe you've mixed the two belts up ? I've taken them both off at the same time only once and that was a while ago, i recall one being a little smaller.
04wrxhart is offline   Reply With Quote
Old 01-29-2012, 01:10 AM   #3
rubrduk
Member#: 126587
06 wagback...now
yeah, i checked that...the AC is 4-rib and the alternator is 5-rib
Old 01-29-2012, 03:23 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
sometimes ya gotta roll the belt on...turn the crank pulley as you push the belt on
or you got the wrong belt
i did mine not too long ago and they went right on pretty easy
Old 01-30-2012, 03:49 AM   #5
bamf3000
Member#: 298021
I had this issue when I replaced mine not too long ago. I swear the belt is too small. I had to REALLY force the belt on while it was loose. It shouldn't happen unless tightened.
bamf3000 is offline   Reply With Quote
Old 01-30-2012, 09:12 AM   #6
SHOfast
Member#: 99083
02 impreza
If it is taht hard to do you likely have the wrong belt. Compare it to the old one to make sure it is very close.
SHOfast is online now   Reply With Quote
Old 01-30-2012, 02:34 PM   #7
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
First belt was shredded.
OP - What shredded it in the first place?
geronimo81 is offline   Reply With Quote
Old 01-30-2012, 04:51 PM   #8
rubrduk
Member#: 126587
06 wagback...now
age, time?
i've never seen anything like it...56k miles, never touched before - it had literally fallen apart
i'm getting my 60k done here in a couple days so i'm gonna have the mechanic go through everything and sort it all out...a proper fix, fill, flush, repair, replace...all the worn and breakable crap
Old 01-31-2012, 08:26 AM   #9
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The 345 is the correct belt and it is 'short'.
As Uncle Scotty said, and to paraphrase, you have to 'walk' the belt over the pulleys. You do not use any type of prying device (e.g. screwdriver; prybar; etc.) to force the belt over the pulley(s).
Old 01-31-2012, 07:26 PM   #10
rubrduk
Member#: 126587
06 wagback...now
i dumped the 345 and went for an FHI factory belt, still tight but it was able to walk on...took 2 of use and was a bitch, but it worked
Old 01-31-2012, 08:02 PM   #11
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
See if they dont have a 5pk890 or 895, it should go on easier.
CosmoTheCat is offline   Reply With Quote
Old 02-08-2012, 01:39 AM   #12
Rally Monkey
Member#: 36310
03 WRX Sedan
I had this issue a while back, the first belt the dealer gave me was just to tight. I took it back and they had another part number that came up, that one went on easy, no crazy move needed to get it on the pulley.
Rally Monkey is offline   Reply With Quote
Old 11-25-2012, 07:25 PM   #13
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
I just 'walked' my belt on after reading this thread... it was very tight when walking it on but once it slipped into place it had a bit of slack which I was able to adjust out... pain in the butt but at least it shouldn't be a frequent annoyance.
This was with the Gates K050345 on an 07 STi by the way. The original belt did seem a hair longer in comparison, not sure if thats because it has 60k miles on it or because it was actually designed to be longer though. The AC belt went on fine and was also a Gates belt, part number K04...something, don't know off hand.
TROLL is offline   Reply With Quote
Old 08-27-2013, 05:52 PM   #14
thenextdon13
Member#: 308640
Have a 2005 forester xt and having the same issue with the gates k050345 - alternator all the way loose banging against the lower bracket and belt doesn't slip on the way i'd like.
I'd rather have a belt easy to add/remove, and the alternator has a _long_ adjustment. Probably step up one size in the belt...
thenextdon13 is offline   Reply With Quote
Old 08-27-2013, 10:05 PM   #15
Vrooom_Psh
Member#: 311923
04 STi
This.
Vrooom_Psh is online now   Reply With Quote
Old 08-29-2013, 02:31 AM   #16
thenextdon13
Member#: 308640
Thanks for the note-
I ended up grabbing the OEM belt, which _just_ fits.
Took it to the store for giggles and we compared it with the k050345. Indeed, a bit shorter even thought the lengths listed on the belt info were longer.
It was much closer to the 5pk891 that he had in stock, but as i'd already gotten the OEM belt just stuck with that. Made in Indonesia, which is a bit of a letdown.
Thanks for the notes, guys!
Old 08-29-2013, 09:48 AM   #17
rkramer
Member#: 118209
2015 WRX Limitec
'walking' belts on... That's for noobs. Let the engine do the work for you!
(disclaimer, I take no responsibility for missing digits if you try this)
Old 09-08-2013, 09:17 AM   #18
kabz
Member#: 351744
2016 STI
CWP
"Thanks Kelso ... RIP"
kabz is offline   Reply With Quote
Old 09-29-2013, 07:08 PM   #19
ian.maines
Member#: 369633
2007 Impreza 2.5i
Default Tensioner
Not to insult you, sometimes the obvious is overlooked as too obvious - Is the tensioner adjusted properly?
ian.maines is offline   Reply With Quote
Old 09-29-2013, 11:31 PM   #20
thenextdon13
Member#: 308640
Not sure who you are talking to, or about what particular bit of this thread-
but it is commonly reported that the gates belt simply isn't long enough to slip over the pulleys even with the alternator loosened all the way and pushed down to be banging against it's bracket. Some additional 'convicing' is needed, or the purchase of the OEM belt... or a longer gates belt.
Old 09-30-2013, 10:11 PM   #21
DONx3
Member#: 214050
2007 WRX
World Rally Blue
Ya the alternator belt was a PITA. I had to roll the belt on and it finally got on there.
DONx3 is offline   Reply With Quote
how do I change my alternator belt? h.a.r.t. ej20wrx Service & Maintenance 1 05-22-2007 08:09 PM
Need 26 or 27" 5 rib belt for my alternator, where to get? 2slofouru Subaru Conversions 5 03-05-2007 05:03 PM
Alternator belt - replaced and squeaking Steven Romero Service & Maintenance 2 12-07-2005 01:03 PM
My Alternator Belt Ate Itself! WagonMonster Off-Topic 70 12-14-2004 02:51 PM
how tight should my alternator belt be? thejimlab Legacy Forum 3 06-25-2004 10:54 PM
