Old 01-29-2012, 01:32 AM   #1
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Default 105k service, taker her in for valve clearence check or diy valve job
I have all the proper tools for the job including an engine hoist to pull the engine, but I've never put new valves in a head before, other than an old chevy 350 engine. At the moment my valves make a lot of the standard subaru clicking noise and im wondering what you guys think I should do in this situation. Car has 106k miles and Im wondering if I should take her to a dealership to get the valve clearence check (if anyone knows the price of this, that would be awesome!) Or should I just get new valves, springs and retainers and do the job myself with a buddy ?
I also lack the measuring tool to do the valve clearence check.
04wrxhart is offline   Reply With Quote
Old 01-29-2012, 01:41 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
they will assrape you all to hell and back on just checking the lash at the dealer.....just ask them how much........you wont wanna spend it, I promise
Old 01-29-2012, 12:40 PM   #3
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
2 to 3 hour job at about 100 bucks an hour. Maybe more
subaru_sti_steve is offline   Reply With Quote
Old 01-29-2012, 06:16 PM   #4
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Ok so with 106k miles on my engine and lots of valve noise do you guys think it would be a better investment to just do a diy valve replacement job ? I did a little research and found bc valves, retainers and springs for a total of around $650. I know I would need new seals but those are cheap, anything im missing ?
Old 01-29-2012, 07:46 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
you are missing the fact that the valves almost certainly dont need to be replaced
why do you insist that the valves be replaced????
many of these motors are(well) past 200k miles with the heads never been off the engine
adjust them and see what happens
if you do a leak down and they are out of spec after you adjust them...THEN start thinking about pulling the heads
Old 01-29-2012, 07:58 PM   #6
KryptoNyte
Member#: 190959
Just out of curiosity, when I took my 2005 WRX in for it's 105k maintanence "package," I don't recall seeing the valve adjustment anywhere in the "to do" list. Uncle Scotty, am I missing something?
KryptoNyte is offline   Reply With Quote
Old 01-29-2012, 10:22 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
well...there are issues with these cars having the valves 'get tight' over time
sometimes this causes valves to burn because they dont seal up when they get older
these engines just make a lot of noise...lots more than many are used to and they think there is something wrong when there isnt anything wrong
Old 01-29-2012, 10:51 PM   #8
silver03bugeye
Member#: 225570
03 wrx
79 trans am 462stroker
Go to a local meet and just listen to the valves ticking!! Its just the subaru way
silver03bugeye is offline   Reply With Quote
Old 01-30-2012, 12:35 AM   #9
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Ya I know the clicking is normal on Subaru's. I guess im just being a little to cautious, I tend to do that a lot. Car still runs like it did the day I flashed stage 2 so I'm not worried that the valves are causing any real problems. A leak down tester and air compressor are two tools im missing from my aresenal, but my buddy has a compressor I can use and, since I have a compression tester, might as well pick up a leak down tester.
Is it possible to adjust the valves with the engine in the car or does it need to be removed ?
Old 01-30-2012, 03:25 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
what oil are you using????
these cars seem to shear 5w30 to 0wPiss in about 1500 miles....and using a better NON 5w30 oil helps the noise issue for many of us
Old 01-30-2012, 07:27 AM   #11
mikeythejew
Member#: 141672
I have over 100K on my WRX and don't hear any valve ticking. Using thick oil can lead to cold start wear and engine noise imo. I'd rather use "0wpiss" in cold weather and prevent start up wear.
mikeythejew is offline   Reply With Quote
Old 01-30-2012, 10:57 PM   #12
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Im using rotella T6 atm, I was using thicker oil when I first got this car but did a lot of research and T6 seems to be the oil that most swear by on this fourm, and I have had good experience with it so far. I was thinking about sending my oil in for an oil diagnoses, I have the kit at my house just need to fill it up and send it in.
Old 02-03-2012, 08:53 PM   #13
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
I use rotella t6, car still ticks as usual and my uoa is perfect at 84k. So no real worries.
Ernest is offline   Reply With Quote
I put in for a background check. Prod Off-Topic 33 09-12-2008 04:18 PM
Attn: Anyone in OT who doesn't check or clear their PMs rogue Off-Topic 53 12-30-2005 12:39 PM
Some pics before I tuck her in for the night codered North West Impreza Club Forum -- NWIC 14 12-25-2004 02:14 AM
Stock WRX bypass valve elbow - or whole valve maestro Private 'Wanted' Classifieds 1 09-29-2004 11:45 AM
