Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 01-30-2012, 03:38 AM   #1
retrabution11
Member#: 308470
Default EJ20 Wont make timing with ecu
swapped 99 rs The heads of the EJ20 motor won't make timing with the newer stock ECU of the Version 7 Harness? Would the only option be changing the heads to match?
retrabution11 is offline   Reply With Quote
Old 01-30-2012, 11:33 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
try to be specific
car- 98rs
engine-ej20x?
ecu- v7?
wiring-v7?
Old 01-30-2012, 01:56 PM   #3
retrabution11
Member#: 308470
sorry its a 99 impreza rs coupe its got version 7 wiring installed to be able to run ver 7 wrx components gauge cluster etc. had a V7 intake fabricated for the EJ20G problem is the V7 ECU doesn't make timing with the EJ20G heads. I was told EJ207 heads will work? or an external ECU?
Old 01-31-2012, 08:30 PM   #4
retrabution11
Member#: 308470
anyone??
Old 01-31-2012, 08:43 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
you need to modify some v7 cam gears to work with the g cams
jdm forester ej20 turbo engine for sale with ecu rocky2 Engine/Power/Exhaust 1 01-23-2010 08:53 PM
NEED help with ecu trouble codes please... wont rev over 1500rpm Bcoolsti Service & Maintenance 14 08-16-2009 08:55 PM
wtb: ej20 with ecu, cf trunk, cf hood Myway Private 'Wanted' Classifieds 0 05-20-2009 01:56 PM
RS with 02 ej20 1/4 times redline29 Proven Power Bragging 1 01-07-2003 08:58 PM
DOHC EJ20 heads on RS with stock ecu? kaos200 Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-28-2002 08:05 PM
