Old 01-30-2012, 12:10 PM   #1
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Default Hard shifting when cold after ATF change.
Hey guys, quick question for you..
I did an automatic transmission fluid change a few days ago, basically replaced what came out after a few times, and now it seems as if when the car is put into gear from a cold overnight start it shifts a lot harder now that i changed it than it used to before i changed the atf in the car. I used the Subaru spec ATF-HP. Before I changed the fluid I never had an issue with a hard shift going from 1st to second and so on.
Any ideas as to what could be making the tranny shift harder? I read somewhere that after an atf change I should disconnect the battery overnight so that the engine ecu can reset itself and that could help the transmission since it is used to the older fluid being in it.
subiedude676 is offline   Reply With Quote
Old 02-08-2012, 10:46 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Low fluid would be my first guess if nothing else changed.
Old 02-10-2012, 01:26 PM   #3
Rally Monkey
Member#: 36310
03 WRX Sedan
Did you check the fluid level with the car running? I use a measuring funnel after taking out ATF. That way I know how much to put back.
Rally Monkey is offline   Reply With Quote
Old 02-12-2012, 03:24 PM   #4
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Thanks for the replies, after I drained fluid out I did measure what was taken out and I put the same amount of fresh fluid back into the transmission.
And yes, I have checked the fluid with the car running and even though its difficult to get an accurate measurement, it seems like it is the correct full level when hot and running.
Old 02-14-2012, 07:52 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
get better fluid
Old 02-14-2012, 08:29 PM   #6
Jerry_NJ
Member#: 233288
2004 Forester
Better than Subaru fluid?
I just did my first 30,000 mile ATF pan dump at 55,000 - I posted on this elsewhere and gave a few tips an noted how simple it is... but
I used Valvoline Max Life, claims to be helpful for tranys with more than 75,000 miles, more than I have.
I too measured how much came out, it was 4 quarts maybe an oz or two more. I put 1 gallon of Valvoline back in, yes using a long neck funnel (could Subaru put the check/fill tube in a more inconvenient location?).
As for using the dip stick to measure how full the trany is, I find it almost impossible to dip the level without "wetting" the whole dipstick. I have the same problem with the oil dip stick. What is the trick to get a "dip" line that is a clean line? Do I first have to run a "pipe cleaner" down the dip tube before putting the dip stick in?
Jerry_NJ is offline   Reply With Quote
Old 02-18-2012, 05:42 PM   #7
AZP Installs
Member#: 40160
My thoughts are that when it is cold the fluid may be a hair low causing the rough shifts. We have seen this in slightly low filled ATs. We use either Subaru AT-HP or Amsoil ATF or Redline High Temp ATF.
Did you change the filter when you did the drain/fill? We do a drain/fill as part of all of our 30k services on AT cars as it is a cheap insurance policy.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 02-20-2012, 12:44 AM   #8
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
I actually did not change the filter right away, I picked up a new filter that I am going to be putting on the transmission tomorrow morning. I also picked up an extra quart of the Subaur ATF-HP. I am guessing it might be a hair low since the fluid is cold and hasn't had a chance to expand when it warms up. I am going to put the new filter on and add some more of the ATF-HP to see if that helps or not.
Thanks for the reply!
02 Wrx Hard Start When Cold!!! killa996 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-01-2014 10:38 AM
hard steering when cold.... chips1 Brakes, Steering & Suspension 14 12-28-2010 02:26 PM
06 STi 1st and 2nd gears are hard to shift when cold? 06slvrsti Transmission (AT/MT) & Driveline 6 02-22-2007 01:13 AM
hard to shift into 1st and 2nd when cold orionh2215 Transmission (AT/MT) & Driveline 2 11-12-2006 09:05 PM
Small whine in 1-2 and 2-3 shift when cold jmaiken Transmission (AT/MT) & Driveline 3 10-28-2003 03:37 PM
