Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-30-2012, 03:35 PM   #1
gwilliamson
Member#: 298637
WHITE
Default help JDM ENGINE IN US CAR HELP!!
Blew engine in 1999 legacy gt been looking for a new engine and the best deal i found was a engine shipped from japan it says:
***NOTE: THESE ENGINES DO NOT RUN AN EGR SYSTEM THEREFORE PLEASE CHECK WITH YOUR MECHANIC ON HOW TO BYPASS IT. YOU MAY OR MAY NOT NEED TO SWAP OUT YOUR EXISTING INTAKE MANIFOLD. PLEASE VERIFY THIS WITH YOUR MECHANIC PRIOR TO PLACING YOUR ORDER. ***
IS THIS A BIG DEAL? THANKS EVERYONE!
gwilliamson is offline   Reply With Quote
Old 01-30-2012, 03:51 PM   #2
Cervantes
Member#: 219252
2000 STi w/S203 swap
which engine specifically are you trying to get?
Cervantes is offline   Reply With Quote
Old 01-30-2012, 06:03 PM   #3
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Yes the Jdm Ej25 dont have EGR so you will have to do it yourself or have a machinist do it and Yes I did passed inspection also with not P,Good luck.
http://forums.nasioc.com/forums/show....php?t=1726807
trinistyles is offline   Reply With Quote
Old 01-31-2012, 10:38 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
WHY ARE WE YELLING?!?! AAAAGGGGHHHHH!!!
I've had 2 JDM EJ25Ds. One came with EGR, one didn't.
There are are number of threads about this in the Subaru Conversions forum and the Normally Aspirated Powertrain forum. Since I believe you have to deal with CT emissions, you'll need to get the EGR connected on the JDM engine, otherwise you'll throw a CEL for the EGR not functioning and you won't be able to pass emissions.
The driver side cylinder head has a spot on the back of it that needs to be drilled and tapped (as I recall, the threads are 16mm-1.5). Transfer your USDM intake manifold (and all the associated sensors, fuel injectors, fuel rails, etc) onto the JDM engine. With the USDM intake manifold (which has the EGR valve and EGR port on it) and the drilled port in the back of the driver side head, you'll be able to hook the EGR up just like it is on the USDM engine.
Details? How did you do it on your car?
... and Yes I did passed inspection also with not P
Unfortunately, that's not the most informative thread. I asked in that thread how you got the EGR to work, and you responded by posting a picture of an engine.
Old 01-31-2012, 12:28 PM   #5
gwilliamson
Member#: 298637
WHITE
thanks guys so you think its worth it? not too much work?
Old 01-31-2012, 06:53 PM   #6
integra_drk
Member#: 117907
95 Legacy Wago
I put a JDM EJ25D in my wifes 99 legacy and it looked just like the old engine and didn't have any issues.
integra_drk is offline   Reply With Quote
Old 01-31-2012, 07:36 PM   #7
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Sorry if I did not get back to you on this Patrick but here is now its done,if the link dont work let me know.
http://legacygt.com/forums/showthrea...98-151598.html
JDM Engines In Stock EJ257 STi $3500-EJ255 FXT $2500-EJ205 $2000- VF48 In Stock Gruppe-S Engine/Power/Exhaust 37 11-11-2008 07:36 PM
Jdm legacy gauges in us car? serious Legacy Forum 1 04-18-2004 05:41 PM
JDM radios in US Soon2Bgreat Car Audio, Video & Security 19 01-26-2004 04:10 PM
JDM tranny in US car? Scoobyslack1 Transmission (AT/MT) & Driveline 13 06-10-2002 10:12 AM
