Old 12-17-2012, 09:56 AM   #101
Vlad
Member#: 46135
02 WRX
Powered by Sti V9 Spec C
So, two things continued to bother me with the 2004 USDM Sti cluster:
-The speed error, which starts around 20 MPH with an optimistic 3 extra MPH shown and goes to 80 MPH to an extra 6 MPH shown
-The early low fuel light.
I have swapped back the WRX cluster and confirmed that with current conditions on the car, the speed is dead-on match with my GPS unit and the low fuel light means that I have to add 13.5 gals of fuel. This means that about 2.4 gals were left, which is considered normal.
Now with the Sti, I have to add only about 1 gal less, the light is early by 1 gal, which can be seen on the level gauge as well.
So I tried to swap the Sti fuel pump assembly (I wanted the spec C fuel pickup box anyway) and this did not change anything.
There is however also a sublevel sensor and the cluster calculates the level at which to turn on the low light out of both the signals from the level and sublevel senders.
The sublevel sender may not be accessible.
As far as the speed signal:
My research sows that although the Vehicle Speed Sensors are of a different part number with Subaru, for WRX and Sti, aftermarket ones are the same, so they are most likely interchangeable, signal-wise.
As far as signal ratio:
The signal pickup is with a pinion which is located upstream of the center differential. It picks up off of the main driven shaft.
So the ratio of the center differential does not directly affect this.
With this knowledge, I went to compare distance measurement, between GPS and cluster.
This morning, with 23 miles travelled, at an average of 29MPH (where error is with cluster showing an extra 3 MPH), there is no difference between what the GPS counted, distance-wise and what the cluster counted, down to the decimal point.
This got me to think about how the cluster calculates the speed:
Probably, for a known circumference of the tire, one revolution generates a number of revolutions of the VSS and therefore a known number of distance impulses.
Then a formula in the cluster transforms the impulses in miles and displays them.
This process does not involve time as a coefficient.
Then (maybe), there is a time signal generator in the cluster and it uses a formula to calculate the speed, by comparing the pulses from the VSS with the elapsed time from the clock signal.
So, if this was right, it is possible to have an accurate odometer signal and inacurate speed signal, due to a poor clock signal.
Old 12-21-2012, 01:38 PM   #102
Vlad
Member#: 46135
02 WRX
I'm going to check the tach readings and see if they're off by the same percentage as the speed.
That would support some kind of time signal discrepancy.
Old 01-28-2013, 10:53 AM   #103
malinwrx
Member#: 241819
2004 WRX Wagon
Hi guys I was trying to read eeprom from my v7 and v8 clusters I'm using wlpro and sp200se programmer, when I read and then was trying to edit eeprom I get only ffff all over.
malinwrx is offline   Reply With Quote
Old 01-28-2013, 11:02 AM   #104
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
That means your not reading the chip right.
Did you set wlpro to read a 93c56?
AFBeefcake is offline   Reply With Quote
Old 01-28-2013, 11:09 AM   #105
malinwrx
Member#: 241819
2004 WRX Wagon
Yes I setup to 93c56 but I'm not sure on which one exactly atmel, microchip or st. Nothing happened on all of them. I have some other eeprom 93c66 which one I can read
Old 01-28-2013, 11:15 AM   #106
dangerousatom
Visiting NASIOC Timeout
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I used one of the Healtech converters for my V8 WRX and V8 STi Prodrive Cluster. Its a one wire splice in and then just set the little box to conversion mode and your done. You can also raise and lower the MPH reading with some minor programing if needed, but my cluster is only one mph off of the i-phone GPS when its converted.
dangerousatom is offline   Reply With Quote
Old 01-28-2013, 11:15 AM   #107
malinwrx
Member#: 241819
2004 WRX Wagon
everything I do on the printed circuit board without desoldering, via clip 3m and cable
Old 01-28-2013, 12:38 PM   #108
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
O, did you disable the osilator on the cluster?
Also reading the chip on the board can wipe the chip. So be very carfull. I have had it hapen 2 times sofar, lucky i save back ups of every custer I program.
Old 01-28-2013, 12:56 PM   #109
malinwrx
Member#: 241819
2004 WRX Wagon
I got it I found out I need to unplug USB cable from my laptop and read chip right after reconnect USB cable
Old 01-28-2013, 12:57 PM   #110
malinwrx
Member#: 241819
2004 WRX Wagon
What is that osilator
Old 02-13-2013, 01:13 AM   #111
Mario_pic
Member#: 346512
Default help
need some help got 04 wrx cluster in km has 200000km on it need it corrected to match my car with usa wrx cluster currently has 71000miles on it so need the canadian wrx cluster to have 115873km prodrive sti cluster im willing to try i if u got a good pic of the prodrive board
Mario_pic is offline   Reply With Quote
Old 02-25-2013, 02:12 AM   #112
malinwrx
Member#: 241819
2004 WRX Wagon
Did anyone knows why I'm getting brake light on on v8 dccd prodrive cluster in 04 WRX ????
Old 02-25-2013, 09:02 AM   #113
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
An oscillator is like a clock. It is needed to run any processor. Its a crystal that resonates at a specific frequency.
Old 02-25-2013, 09:03 AM   #114
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
This mite be a dumb question but is your parking brake off and is your brake fluid tank full?
Old 02-25-2013, 09:10 AM   #115
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
I am confused as to what your asking.
If you have a KPH cluster and need the KMs changed I can do that.
If you have a MPH cluster and need the miles change I can do that.
I cann't make a MPH cluster read in KPH. there is a chip you can get that will make a KPH cluster read in MPH, but not the other way around.
Old 02-25-2013, 10:20 AM   #116
malinwrx
Member#: 241819
2004 WRX Wagon
It is I just installed v8 dccd cluster and this happen on non-dccd version brake light work fine
Old 02-25-2013, 10:30 AM   #117
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
weird i have have both dccd and non dccd prodrive clusters in my 02 and never had the happen.
Old 02-25-2013, 10:54 AM   #118
malinwrx
Member#: 241819
2004 WRX Wagon
My friend was using this cluster in 03 and also without problem
Old 03-04-2013, 10:01 PM   #119
Xissix
Member#: 85985
Not sure if this is the right spot to ask, but is related to this thread. I have a black faced non-dccd UKDM (pretty sure) STI cluster that has a POWER light, any idea what it is? I've been searching with no luck. This isn't the battery light (has one of those as well).
Xissix is offline   Reply With Quote
Old 03-04-2013, 10:15 PM   #120
drischnie
Member#: 54278
its for the automatic transmisson non-sti models.
the light has no function on the sti cluster.
drischnie is offline   Reply With Quote
Old 03-04-2013, 10:20 PM   #121
Xissix
Member#: 85985
Oh ok, thanks!
Old 03-27-2013, 07:38 PM   #122
malinwrx
Member#: 241819
2004 WRX Wagon
Did anyone know how to do mileage correction on usdm STI cluster ????
Old 04-21-2013, 03:08 PM   #123
Mario_pic
Member#: 346512
I need a file to program my 03 Canadian Wrx cluster so it shows 115000km on odometer u able to help me out
Old 04-21-2013, 03:12 PM   #124
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
If you can get me the hex file from your cluster chip using wlpro. I can make the edits.
FS : v8 Type UK Prodrive STi Cluster with DCCD RedMonkey999 NWIC Private Classifieds 22 09-26-2011 09:31 PM
FS : (WA) v8 Type UK Prodrive STi Cluster with DCCD RedMonkey999 Interior/Dressup/Audio & Security 25 09-26-2011 09:30 PM
FS : (WA) v7 Type UK (Prodrive) STi Cluster RedMonkey999 Interior/Dressup/Audio & Security 16 06-15-2011 04:56 PM
Prodrive Type UK Spoiler axis Interior & Exterior Modification 3 05-28-2002 07:45 PM
Message Board Statistics All times are GMT -4. The time now is 01:48 AM.
