#76 |
Big Ron
Moderator Member#: 18062
Don't as there is nothing that us civilians can use in a spray can that will last longer than .000000023 seconds on a header. Baleeee dat.
#77 |
Member#: 296411
Vehicle:2005 STI, 135i WRB |
Bought some today and most of my headers. Tomorrow ill do my up pipe and the rest of the headers. So far its looking good!
#78 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
Wrap it all. If you are worried about the plastic under tray, get an aluminum one like by Primitive Racing. You don't need to wrap all of the down-pipe from what I have heard.
Though, I track my car so I get some heat going. ![]() from: http://forums.nasioc.com/forums/show....php?t=2163482 Last edited by tazswing; 05-24-2012 at 11:41 PM. |
#79 |
Member#: 63767
NWIC
All wrapped up. Used about 60' of 2" wrap for my Perrin EL headers. Likely you could get away with 50' which would allow you to only order one roll. I had a 100' roll that I got rather cheap via Amazon. The bends eat up the most wrap.
Thanks again for the write-up! |
#80 |
Member#: 314419
Vehicle:2004 WRX Blue |
Two questions on using heat wrap. My DP has a cast iron bellmouth. Is it ok to wrap cast? I was going to bolt the bellmouth to the rest of the DP and wrap about 18" worth. Second, it is ok to wrap over ceramic coating? My up pipe is coated but I don't know if it'll be enough. I'm also wrapping my turbo. Florida summers don't mix well with these cars.
#81 |
Big Ron
You can wrap any metal.
You can wrap over coating though it may void any coating warranty depending on the coating maker. |
#82 | |
Member#: 63767
NWIC
I bought a used set of Perrin headers b/c I knew I was going to wrap them and this would void any warranty of theirs so saw no point in new. |
#83 |
Member#: 177880
South East
#84 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
I know It's not necessary but would wetting it make It easier to apply? Can we still use the silicone paint for additional heat resistance? I will be using hose clamps or just wire twisted together. I got 2 inch 25 feet for my dp for now.
Would wrapping it twice add more heat retention aswell? |
#85 | |
Member#: 63767
NWIC
Why not wrap half the pipe with wet wrap and the other with dry and report back? |
#86 |
Member#: 323008
Vehicle:2003 WRX Waagon WRB |
Noob question: Is wrapping headers good or bad if I deal with snow/salt in winter?? Nice job btw
#87 |
Member#: 283815
TXIC
Vehicle:2003 psm wrx wagon Built Fuji Tough |
Y no sticky?
#88 | |
Member#: 63767
NWIC
Other thoughts? Have you asked around the local forums of salty winter states? |
#89 |
Big Ron
We have an undertray. If you get salty snowy water on your wrapped headers, you are doing it wrong as they say.
#90 |
Member#: 323008
Okay well good thing I didn't. Thank ya
#91 | |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
#92 |
Member#: 243992
another question i forgot to ask.
wrapping my DP, my EWG dumps right onto/close to the dp. can i still wrap past there or will the gasses from the ewg pounding on it be bad for the wrap? |
#93 |
Member#: 212923
Vehicle:2004 JrTuned@P&L FXT 384whp/361wtq - Stock 5MT |
#94 | ||
Member#: 219717
South East
Vehicle:05 FXT Dom2.5R 4EAT FTW!!!! |
#95 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
How long of a roll do I need for just an uppipe? I was thinking about just getting a 1in x 15ft roll but with you guys talking about 50ft rolls im getting a little worried.
just a grimmspeed uppipe, no ewg or anything special |
#96 |
Big Ron
Depends on you bro. If you wrap like the typical dude, which is to say it will look like it was wrapped by honey badger while being stung by 10,000 wasps, then get a 50' roll. If you wrap like me, then 15' should do it.
#97 | |
Member#: 200288
BAIC
Thanks man ![]() Do you recommend any specific vendors? |
#98 |
Big Ron
As long as you buy the titanium wrap stuff, the vendor don't matter as the price will be within $2 or so. If your local auto store has it, get it there, if not check eBay or summit racing.
#99 |
Member#: 321842
South East
Vehicle:2008 STi Blue |
Hey guys, just used this guide to wrap my Invidia up and down pipes for my 08. Used the titanium 50' - 2" wrap and it covered the up pipe and the downpipe with about 8" left over (whew!). I followed the overlap by 1/4-1/2" (based on the slight angles). It looks great.. but it will get itchy.. A little tip: if you grip around the wrap and twist (like an Indian burn on someones arm), you can get this stuff nicely tight and it won't move.
![]() I have one more 50' roll of this that I hope will cover the headers, though I may end up having to overlap by very little. PS: I have figured out a way to get these steel zip ties TIGHT...: Basically, while your part is on the ground (and your feet, with shoes on it), have the outlet of the tie holder facing up (and already taught by hand). Get a phillips screwdriver and put it in the rear of the tie (where the slack comes out) with one hand. With the other hand grasping pliers, get a grip and pull the tie towards you, tighter while holding the mouth in one place (so push with screwdriver, pull with pliers). even with a little muscle you should be able to get these pretty tight. I also put a piece of the wrap folded up in the tie before tightening so that the tie would have something to "bite" into. You can see an example of this in the up pipe.. I haven't trimmed the slack of the ties yet because I didn't have cutters in my living room Hope this helps |
#100 |
Member#: 329962
Vehicle:2004 WRX Flat Silver |
two giant 50 foot rolls just for one header!? =./
| Thread Tools | |
| Display Modes | |
| How to wrap your turbo | Unabomber | General Community | 119 | 02-10-2013 01:23 AM |
| Why its a good idea to wrap your headers | PolarisSnT | Factory 2.0L Turbo Powertrain | 14 | 10-30-2007 08:38 AM |
| How to wrap header? | AWD>FWD | Factory 2.5L Turbo Powertrain | 33 | 05-22-2007 01:06 PM |
| To wrap or not to wrap borla header?? | scoobysnack69 | Factory 2.0L Turbo Powertrain | 23 | 08-08-2006 05:04 PM |
| Is it possible to heat wrap your stock uppipe? | blackie | Factory 2.0L Turbo Powertrain | 5 | 02-22-2005 07:52 PM |
