Old 12-07-2012, 03:18 PM   #101
Dale2011WRX
Member#: 304299
2011 WRX Sedan
Originally Posted by IheartAWD View Post
two giant 50 foot rolls just for one header!? =./
Read.
He covered his up and downpipe with one 50' roll.
He hopes to cover his headers with another 50' roll.
Dale2011WRX is offline   Reply With Quote
Old 12-07-2012, 07:32 PM   #102
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Down side of wrap: I just had to cut all mine off a down pipe after a blown CV boot.
tazswing is offline   Reply With Quote
Old 12-07-2012, 07:48 PM   #103
Half Crazed
Member#: 321842
2008 STi
Why's that? (I'm not realizing something here!)
Half Crazed is offline   Reply With Quote
Old 12-07-2012, 08:19 PM   #104
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
id say it was covered in axle grease. exhaust and flammable grease are a bad combo last time i checked.
424wrx is online now   Reply With Quote
Old 01-28-2013, 03:22 PM   #105
ubeflyer
Member#: 333364
2002 WRX Sedan
What's left is blue
Thanks for the great write up, just did my up pipe and a 4th of my DP with a 2 inch x 25' roll.
My cheapo Chinese scissors worked fine after I ran a sharpening steel over them a few times.
ubeflyer is offline   Reply With Quote
Old 01-28-2013, 04:14 PM   #106
Varady360
Member#: 342336
2008 WRX
SSM
newb question but what will the wrap help with... you probably answered this in your write up but is it to keep the heat insulated around the pipes so you are not radiating heat to the rest of the engine. Thanks ill check back here shortly.
Varady360 is offline   Reply With Quote
Old 01-28-2013, 04:27 PM   #107
Half Crazed
Member#: 321842
2008 STi
It will help greatly with engine bay heat, yes. it also helps keep your turbo spooled up as well.
Old 01-28-2013, 04:34 PM   #108
Varady360
Member#: 342336
2008 WRX
SSM
nice but how often does oil drip on to these parts? i dont like the mention of fire in and around my engine
Old 01-28-2013, 04:35 PM   #109
Half Crazed
Member#: 321842
2008 STi
Good question: but you must first ask yourself: "is my shi- leaking right now?" If it is, you should probably fix it before wrapping. Otherwise, oil should not be dripping anywhere.
Old 01-28-2013, 04:40 PM   #110
Varady360
Member#: 342336
2008 WRX
SSM
have not noticed any leaking so it would be safe to say i can go ahead with this mod. now if i do the headers i should do the UP and the DP. is it safe to just do i.e. the DP by its self is that even worth it?
Old 01-28-2013, 04:44 PM   #111
Half Crazed
Member#: 321842
2008 STi
IMO: Do all 3 (headers, up, down pipes) or you're wasting your time. others may have something to say about this as well as i'm no expert.
Old 01-28-2013, 04:48 PM   #112
Varady360
Member#: 342336
2008 WRX
SSM
i ask this because i will be getting a DP in the next month then the Up and headers next so i was going to wrap the new parts and not waste time/money on wrapping the stock UP/Header
Old 01-28-2013, 04:58 PM   #113
Half Crazed
Member#: 321842
2008 STi
I think you'd have a problem wrapping the stock parts.. they have heat shields iirc. also don't forget to get a tune asap if you get a new up pipe and headers... else you'll be running very lean and throwing cel's
Old 01-28-2013, 04:59 PM   #114
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
short of a CV boot tearing and spraying axle grease (as correctly stated above by 424wrx) or picking up crap from the road, the UP and DP stay rather "oil free."
The headers can be a different story. If you heat wrap your header you will need to be very careful when you change your oil. I cover my wrapped headers with aluminium foil for each oil change. Easy to manipulate with the tight clearance between the oil pan and runner. You can just wipe-off oil from heat wrap.
Old 01-28-2013, 05:04 PM   #115
Varady360
Member#: 342336
2008 WRX
SSM
i plan on buying a Cobb AP before i get a DP/UP/header
i get free oil changes from local dealership. ill have to tell them to watch out for that or just wrap it in foil before the short drive over there and ask them to take it off after.
Old 01-28-2013, 05:13 PM   #116
Half Crazed
Member#: 321842
2008 STi
cobb ap won't tune your car and you should also get an AEM UEGO (or any other wideband afr gauge) with the downpipe.
Old 01-28-2013, 05:27 PM   #117
Varady360
Member#: 342336
2008 WRX
SSM
if i get maps for it wont it?
i was planning getting the AP first then getting the rest of the what nots on it. and i was going to get the maps on it before i went stg2 so that when i did i could just flash and add the map to the ecu?
how much does the AEM UEGO fun for
Old 01-28-2013, 05:40 PM   #118
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Please keep this thread on topic. There is ample information out there regarding what is needed/known for modifications and tuning. If in doubt and you are using a COBB product, ask them.
Thanks.
Old 01-28-2013, 05:42 PM   #119
Varady360
Member#: 342336
2008 WRX
SSM
Thanks.
my bad will do
Old 01-29-2013, 02:27 PM   #120
brendan04wrx
Member#: 167494
04 STi
psm
has anybody tried using cv boot clamp tools to clamp down the wrap instead of trying to get the SS ties tight by hand? I'm gonna wrap my new setup in the next cpl weeks and was planning on doing it that way
brendan04wrx is offline   Reply With Quote
Old 01-29-2013, 02:36 PM   #121
Half Crazed
Member#: 321842
2008 STi
i've seen several people use the clamps. as for the ss ties - you can get them tight. i actually posted a way on how to do this with a screwdriver and some muscle. http://forums.nasioc.com/forums/show...r#post38567080
look at the "PS" part
Old 01-29-2013, 02:55 PM   #122
brendan04wrx
Member#: 167494
04 STi
psm
ya I've done that on cv boot ties and still not quite how I'd like them cuz I'm very anal about doing things once and being done with it. I already have the tool for cv boot ties so ill let u know how it works on this
Old 01-29-2013, 03:40 PM   #123
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
That's a good method. I use the screwdriver in the slot, but then I grab the end of the steel tie and twist it around the end of the needle nose. Once it gets to the end you just keep twisting and it pulls it extremely tight.
xluben is offline   Reply With Quote
Old 01-29-2013, 06:21 PM   #124
Dale2011WRX
Member#: 304299
2011 WRX Sedan
Yes, that works really well.
Old 01-29-2013, 10:26 PM   #125
LUMBERZACK
Member#: 340009
2007 Impreza WRX STi
Crystal Gray Metallic
Very nice and well detailed how-to!
LUMBERZACK is offline   Reply With Quote
How to wrap your turbo Unabomber General Community 119 02-10-2013 01:23 AM
Why its a good idea to wrap your headers PolarisSnT Factory 2.0L Turbo Powertrain 14 10-30-2007 08:38 AM
How to wrap header? AWD>FWD Factory 2.5L Turbo Powertrain 33 05-22-2007 01:06 PM
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain 23 08-08-2006 05:04 PM
Is it possible to heat wrap your stock uppipe? blackie Factory 2.0L Turbo Powertrain 5 02-22-2005 07:52 PM
Message Board Statistics All times are GMT -4. The time now is 06:17 PM.
