Old 01-30-2013, 08:16 AM   #126
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Just wrapped my Grimmspeed PnP header and crosspipe with a 1"x50' roll of DEI Titanium. Installing it tomorrow along with the stock heatsheilds
Oh and PS, those steel ties are a bizotch to get tight. Use clamps instead.
Mr Wrex is offline   Reply With Quote
Old 01-30-2013, 06:10 PM   #127
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
those steel zipties are useless. i bought a box of worm gear hose clamps off ebay. they worked alot better. the dei titanium is nice and easy to work with. thats what i used on my tomei headers and uppipe.
424wrx is offline   Reply With Quote
Old 01-31-2013, 09:55 AM   #128
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Well, I got mine tight somehow. I might try to put worm clamps on, but I'm not too sure how the clearance under the stock heat sheilds would be. Should I even worry about the SS ties coming loose?
Old 01-31-2013, 10:05 AM   #129
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Mine have been on for right at 1 year and I was under the car last weekend and everything looks like it did the day I bolted the pipe in. And they were just pulled as tight as I could get them. I figured I'd go to clamps if anything loosened up, but so far so good.
Dale2011WRX is offline   Reply With Quote
Old 01-31-2013, 10:09 AM   #130
Dale2011WRX
Member#: 304299
2011 WRX, white
I think maybe your zip-tie sauce is weak.
Old 01-31-2013, 01:02 PM   #131
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Can normal worm clamps with stand so much heat? Or are there a special type that can with stand the head these pipes omit?
Daddy_Digital is offline   Reply With Quote
Old 01-31-2013, 01:10 PM   #132
Half Crazed
Member#: 321842
2008 STi
if they're ss, why not.
Half Crazed is offline   Reply With Quote
Old 01-31-2013, 02:11 PM   #133
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Plus, doesn't the wrap help to keep some of the heat off the clamps/ties?
Old 01-31-2013, 02:17 PM   #134
Daddy_Digital
Member#: 274205
World Rally Blue
Let me get this straight because I plan on wrapping my up pipe and down pipe in the very near future. As long as they are stainless steel, they are g2g?
Very good point! The whole point of the wrap is keep out heat. So I guess that answers my question.
Old 01-31-2013, 02:31 PM   #135
Half Crazed
Member#: 321842
2008 STi
The zip ties are SS, so why wouldn't the clamps work? Under normal running conditions, you can touch the heat wrap and it's warm but not enough to burn.. though I'd think if you track it, that's when it'll really heat up and stress the ties/clamps.
Old 02-01-2013, 10:01 AM   #136
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
FWIW I installed the header last night. I couldn't use the stock heatsheild, so the crosspipe was exposed in the engine bay between the engine and radiator. I reached down after doing a LOT of WOT driving and touched the wrap. Probably could've placed my family jewels on it safely, that's how well the wrap worked So glad I decided to wrap the GS exhaust mani.
Old 02-01-2013, 10:27 AM   #137
Half Crazed
Member#: 321842
2008 STi
haha. the only heat shield i still have is on my turbo.. hoping to get it wrapped soon anyways.
Old 02-01-2013, 04:22 PM   #138
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
you didn't use the WHOLE 50-footer for the collectors and x-pipe, didya?
DEI's calculator on their site says I could do what you did, plus UP with a few ft. leftover.
thanks
oaklandish_WRX is offline   Reply With Quote
Old 02-01-2013, 04:28 PM   #139
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I used the whole 50' roll on just my header/crosspipe because it was the only thing I had to wrap. Just letting you know now that the stock mani is a little tricky to wrap... if you plan on doing it, keep re-wrapping the collectors until you find a way that uses the least amount of wrap. I didn't care about having extra when I wrapped mine, so I went over spots that looked a little bare
Old 02-01-2013, 04:57 PM   #140
oaklandish_WRX
Member#: 267339
MBP LongRoof
Cool, thanks.
I'm gonna cut off my heat shield mounts and grind em down flat, so wrapping should be easier. Plan to PnP and wrap+foil tape, like Ken Ride5000 G. did, with replication of UP shields instead of tape there to really keep out any oil/grease. I have an extra complete pre-turbo exh. set, so can work at my leisure...will post pics to some thread or another for PnP exhaust items when done.
Any special shears/scissors needed for the titanium wrap? Unabomber used kevlar shears, but I don't wanna drop half a roll of wrap's cost just to cut the damned stuff! others in this thread or related got away with new, decent scissors.
Old 02-01-2013, 06:08 PM   #141
bign
Member#: 107740
05 STI - WRB
01 GSX-R 750
You can use practically any scissors. It isn't that difficult to cut.
bign is offline   Reply With Quote
Old 02-01-2013, 06:10 PM   #142
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I used those orange scissors (see my pics) and they're more for cutting paper. They work, but you gotta cut kinda slow. Use something better if you want cleaner ends.
Old 02-26-2013, 02:35 AM   #143
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
Just to prove Unibombers point about the 1" wrap. I did this two years ago with 2" wrap. Notice how terrible it looks. Also, I can definitively say that it has completely removed itself from the header. Gruppe-S UEL headers there
Works GREAT for downpipes though =)
To conclude: Doing a complete rebuild of my suspension and will be re-wrapping soon with 1" I'l try and remember to post before and afters.
Krang is offline   Reply With Quote
Old 03-04-2013, 10:37 PM   #144
Coldflame6
Member#: 216639
2011 WRX Sedan
Thanks unabomber for some good info.
Coldflame6 is offline   Reply With Quote
Old 03-05-2013, 03:05 AM   #145
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
I don't have a source for the 1", but I can get 2" wrap for about .50c a foot if anyone is interested.
p951951951t is offline   Reply With Quote
Old 04-17-2013, 10:16 PM   #146
wantsti
Member#: 134764
04 sti
java black pearl
Just did mine.
beautiful Killer b header
Getting ready to get all wrapped up.
one runner done
wrapped her pretty tight should keep her nice and warm
Runners were to close to wrap so this was my solution.
almost done
all done now
I used all of 2 rolls on just the header.
I bought another roll to do the up pipe. I'll post pics of that later
wantsti is offline   Reply With Quote
Old 04-17-2013, 10:24 PM   #147
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You copied my header, my wrap, and my technique. You bastard!!!
Old 04-17-2013, 10:45 PM   #148
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Just FYI, if you track the car you should wrap your down pipe to work with the air flow or else it's like stroking a cat the wrong way at 135mph.
tazswing is offline   Reply With Quote
Old 04-19-2013, 03:28 PM   #149
wantsti
Member#: 134764
04 sti
java black pearl
We'll if wasn't the ultimate set up I wouldn't have too. Wait for my turbo blanket
Old 04-21-2013, 07:53 PM   #150
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Just did my Killer B header too ...
http://www.iwsti.com/forums/3819366-post904.html
t
WolfPlayer is offline   Reply With Quote
How to wrap your turbo Unabomber General Community 143 03-20-2016 11:59 PM
Why its a good idea to wrap your headers PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-30-2007 08:38 AM
How to wrap header? AWD>FWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 05-22-2007 01:06 PM
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-08-2006 05:04 PM
Is it possible to heat wrap your stock uppipe? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-22-2005 07:52 PM
