Old 01-31-2012, 04:47 AM   #1
runboyrun
Member#: 287901
2003 WRX Wagon
Default Loud initial transmission noise
For about a week now I have noticed a loud noise from my transmission. Its hard to describe though. It only happens immediatly after I engage 1st gear with the clutch still mostly depressed while giving low revs for maybe a second until I rev higher then goes completely away until I stop and restart the car hours later. It also happens in the same situation only in reverse. Low revs (1-2k) clutch mostly depressed then goes away after (2.5-3k rpm)
Any thoughts? experiences?
runboyrun is offline   Reply With Quote
Old 09-22-2012, 09:06 PM   #2
AmaMechaPrez
Member#: 333004
2005 Impreza 2.5 RS
I have the same problem. Taking it to the dealer as I cannot figure out what it wrong.
AmaMechaPrez is offline   Reply With Quote
Old 04-08-2013, 11:26 AM   #3
AmaMechaPrez
Member#: 333004
2005 Impreza 2.5 RS
You may have already figured this out, but my problem was the heat shields needed replacing.
transmission noise? sycronizer noise? Aimprezar Newbies & FAQs 4 07-31-2009 10:06 AM
Loud High Pitched Noise from Front Brake TheShadowWRX Brakes, Steering & Suspension 2 01-12-2004 07:34 PM
Loud rearend/diff noise zakats Transmission (AT/MT) & Driveline 7 08-25-2003 10:36 PM
initial uppipe noise when car is cold. ellinopedo182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-17-2003 01:49 PM
Loud squeak/creaking noise coming from differentials? JDiMpreza Brakes, Steering & Suspension 0 08-29-2002 02:17 PM
