Old 01-31-2012, 10:48 AM   #1
flash02
Member#: 78916
Default 02 WRX slow throttle response/flat spot at low RPM
Seem to have devolved a flat spot during Low rpm/small throttle position. My car has been modded and pro tuned on a dyno for the below listed parts. The problem occurs when at low RPM when the throttle is barley open. I have monitored AFR and knock at all throttle position both are not showing issues, I'm starting to think it could be a TPS or perhaps IACV. What should my TPS and MAF sensors be reading, I'm really starting to think this is a TPS problem. ECU reset does not affect the issue.
Mods
2002 WRX 161k miles original owner
Hat 68
700cc injectors modded stock, they might bigger cant remember
STi TMIC
Turbo back exhaust
Perrin short ram intake
Walbro FP
Forge BPV
One step colder NGK plugs
Protuned at epic Motorsports
flash02 is offline   Reply With Quote
Old 01-31-2012, 10:50 AM   #2
flash02
Member#: 78916
Yeah that should be HTW 68 turbo
Old 01-31-2012, 10:50 AM   #3
flash02
Member#: 78916
That should be HTA 68 turbo
02 wrx - running lean and hesitating at higher rpms joe_black Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-14-2009 03:32 PM
help! utec stage 4 wrx stalls intermittantly at low rpms prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-31-2006 03:28 PM
02 wrx acts like it shuts down at 5000 rpms and stutters bad brettedmonds Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-16-2005 10:49 AM
Knock at low rpm and throttle PharmCo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-02-2004 10:28 PM
Flat spot after 5000 rpm? z3coupe STi Forum Archive 16 09-03-2003 12:20 AM
