Old 01-31-2012, 12:06 PM   #1
fpshked
Member#: 289492
Default Squeaking near front air vents
I own a 2011 Impreza 2.5i Sedan. When winter started or when it's cold, the left and right sides near the front vents are squeaking. It sounds like plastic rubbing on plastic. Anybody have this issue? It's annoying the crap out of me.
fpshked is offline   Reply With Quote
Old 01-31-2012, 12:55 PM   #2
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
I have so many squeaks and cracks inside the car I cant even tell where they are coming from. Apparently its a subaru thing....
DurtyB is offline   Reply With Quote
Old 01-31-2012, 12:59 PM   #3
fpshked
Member#: 289492
O??? haha damn
Old 01-31-2012, 02:21 PM   #4
NoGraffix
Member#: 276209
I am Rub
Function>Form
This pretty much nailed it on the head. At first I was annoied, but they quickly faded to background noise.
NoGraffix is offline   Reply With Quote
Old 01-31-2012, 03:41 PM   #5
Atomic Rooster
Member#: 204224
2010 STI
Obsidian Black Pearl
Do the squeeks lessen when you press on your dash?
Atomic Rooster is offline   Reply With Quote
Old 01-31-2012, 04:17 PM   #6
Scubalou
Member#: 302858
2008 Legacy
Pearl White
dynamat!!!
Scubalou is offline   Reply With Quote
Old 01-31-2012, 04:55 PM   #7
Tack762
Member#: 261845
2011 WRX
Silver EFI logics stg 2
I had the same thing going on with my 2011 WRX and it was driving me nuts. Its not the vents from what I can tell. It seems to be coming from where the dash meets the A pillar. I cut a rubber o-ring and pressed it down between the side of the dash and A pillar. Its been almost a week and no squeak.
Tack762 is offline   Reply With Quote
Old 01-31-2012, 05:52 PM   #8
kabob.master
Member#: 258791
2011 wrx 5dr lmtd.
299awhp / 322tq @ 17.6psi
The squeaks were put in there by major audio companies to encourage you to buy more audio equipment thus manipulating profit margins in hopes to drown out the squeaks.
This is not a conspiracy......or is it....not?
PS - Dynamat, RamMat or any other sound deadener should do the trick. Also take your car to the dealer since it should still be under warranty.
kabob.master is offline   Reply With Quote
Old 02-01-2012, 06:17 AM   #9
Tack762
Member#: 261845
2011 WRX
I would definitly NOT take my car to the dealer for some dash squeaks. I wouldn"t want some Subaru wrench monkey dismanteling my dash just for a "squeak". Doing that you"ll probably have more squeaks and rattling after they put it back together. JMO
Old 02-01-2012, 04:29 PM   #10
XsoberX
Member#: 289656
2011 Impreza WRX
Fixed mine. Pop off SRS cover, remove 10mm bolt, pull A pillar trim toward centre of windshield. Wrap the front plastic tang with foam tape or electrical tape, so it's about the thickness of a penny. Reinstall. 10mm bolt is just past snug, and does not affect the side curtain airbag.
XsoberX is offline   Reply With Quote
Cobb Air Intake Filter For Center Console Air Vent Trueday MAIC Private Classifieds 2 08-03-2010 02:31 PM
Looking to buy front air vents for rex..02-03' NewShockerGuy Private 'Wanted' Classifieds 2 10-04-2004 08:54 PM
Cooling Air Vents for front brakes mick_the_ginge Brakes, Steering & Suspension 9 06-02-2003 01:43 PM
Tweets in the air vents? wcbjr Car Audio, Video & Security 12 04-19-2001 10:36 PM
New style air vents! ImprezedRS Interior & Exterior Modification 49 04-02-2001 06:58 AM
