Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 01-31-2012, 12:53 PM   #1
fullCircling
Member#: 290547
Default BD Legacy - What's the cheapest way to get an 18mm Outback bar to work?
I want to upgrade my '97 L-GT rear sway with an 18mm outback bar, and would like to just be able to mix and match stock parts from a junkyard to make it work. Can I use the outback bushings and endlinks?
I read I can also use 04+ impreza mounts that are a bit beefier, that use a newer style bushing, but is there any subaru that uses the newer style bushing that is 18mm?
-Besides going aftermarket, is there a newer style bushing, that will fit the 18mm outback bar?
-Also, What stock endlinks will work?
Healpp plz.
fullCircling is offline   Reply With Quote
Old 01-31-2012, 01:10 PM   #2
98legwag
Member#: 160325
09 Legacy 3.0R
Make sure to get the bushings and brackets. Stock endlinks will work. It takes around 10 mins to take your stock one off and put the OB bar on. I see you posted on SLI too. Follow that DIY and you'll be golden.
98legwag is offline   Reply With Quote
Old 01-31-2012, 01:42 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I know you said you wanted to use OEM parts, but if you want a slight upgrade, you could pick up some universal poly bushings from Energy Suspension or Prothane. Summit Racing carries both brands, just look up the 18mm version and you'll be good to go. You might also see if there's anybody local to you that carries either brand and just order them that way, save yourself Summit's minimum $9.99 S&H.
I'm partial to the Prothane greasable type, because they come with a grease zerk already on the bushing bracket for ease of greasing in the future.
An 18mm bar was the first mod I did to my '99 (back before I totalled it and ended up with the '97 as a replacement). I was very happy with the improvement in handling, and as 98legwag said, it's painfully easy to swap the sway bar.
Old 01-31-2012, 02:29 PM   #4
fullCircling
Member#: 290547
Ok, cool I'm new to owning a car that's lived up north, and to subys. some things are engineered so well, even compared to honda b series (thats what i came from). i don't have to drain the trans fluid to swap a front axle? or even seperate the ball joint from the arm?! awesome! im not suprised that this sounds really easy, too.
thanks guys,
-jon
Old 01-31-2012, 06:51 PM   #5
jamal
Member#: 71875
98 2.5GT
my wheels fit
WRXs are all 13, 17, or 20mm AFAIK. But the 17mm bushings from an 04-07 wrx will probably work (20464FE070). The whiteline part number would be W0406-18, but it doesn't seem to exist.
jamal is offline   Reply With Quote
What's the Cheapest Way? DarkknessD General Community 23 02-19-2010 11:49 PM
What's the cheapest way... CoopsCustomz Off-Topic 23 06-10-2007 09:01 AM
what's the cheapest way to make my black wagon look better? stormn Vancouver Impreza Club Forum -- VIC 37 05-31-2007 12:04 PM
OT: What's the cheapest way to ship an exhaust? e11ys Off-Topic 34 08-30-2005 01:02 PM
What's the cheapest I can get solid, plain (no STi logo), silver fog covers? Schleppy Interior & Exterior Modification 18 10-20-2002 05:36 PM
