Old 01-31-2012, 01:00 PM   #1
CaseDoc
Member#: 279370
Default Chattering sound at low speeds + torn timing belt
I have a 2005 STI with 60k miles. I recently started hearing a pretty loud chattering sound coming from the engine during certain instances. There sound does not appear until the car is warmed up. On cold day there will be no sound until it has been driven for a good 5-10 minutes. The sound then starts at around 10mph and continues to around 30mph. It goes away within 3 seconds of engaging the clutch regardless of the speed.
I was poking around to see if I could notice anything out of the ordinary and saw that my timing belt has a tare oriented along the long axis of the belt. The tare is about 4 inches long.
Anyone know if the timing belt is likely to be the source of the chattering?
CaseDoc is offline   Reply With Quote
Old 01-31-2012, 01:48 PM   #2
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
If your timing belt is torn I would not drive your car hard as if it breaks it can result in catastrophic damage. I would replace the belt immediatly and yes as its spinning it slaps around the gears and tensioner which should be a consistant noise though.
subaru_sti_steve is offline   Reply With Quote
Old 01-31-2012, 02:30 PM   #3
rick-l
Member#: 33868
2003 wrx
srp
describe this tear.
When you say engaging the clutch do you mean the pedal is in or out?
rick-l is offline   Reply With Quote
Old 01-31-2012, 03:27 PM   #4
CaseDoc
Member#: 279370
I mean pedal down. Also I think the torn belt in question is actually the drive belt and not the timing belt.
Old 01-31-2012, 03:43 PM   #5
rick-l
Member#: 33868
2003 wrx
srp
An AC or a Power Steering/Alt belt are not going to destroy your engine when they break but it probably would only take you 10 minutes to change it.
So when you push the clutch in and remove torque from the drive train the clicking goes away. It could be almost anything but I would look at your (front since it sounds like engine) CV joint boots first.
Brakes making low humming noise at low speeds aimetti Brakes, Steering & Suspension 7 10-23-2015 01:16 PM
Funky stuttering issues at low speed low RPM driving simon021 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-12-2008 10:06 AM
Differential Problems? Grinding sound when turning at low speeds 409Industries Transmission (AT/MT) & Driveline 4 05-06-2007 10:09 PM
Rubbing sound at low speeds newsman Brakes, Steering & Suspension 3 11-16-2003 07:48 PM
Weird sound when turning at low speed Ulf Wafflestein STi Forum Archive 3 08-16-2003 08:51 AM
