Old 01-31-2012, 09:25 PM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default Unibody Deformation Due to Long Term Use of Jack Stands During Clutch Replacement
I have had my '07 Forester XT on jack stands for over a month while installing a new clutch, I am concerned about unibody deformation due to the small foot print of the jacks supporting 3,300lbs (825lbs per corner), are my worries unfounded?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 01-31-2012, 09:37 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if they are properly placed....forgetaboutit
Old 01-31-2012, 09:40 PM   #3
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
yes they are mounted at the factory locations where the OEM scissor jack is intended to go.
Pinched weld savers:
Old 01-31-2012, 09:42 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
just dont go havin any wild frat parties in it while it is up on stands and it wont even know it was ever off the ground
Old 01-31-2012, 09:47 PM   #5
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^nice to have an Uncle to guide and look after us.
Old 02-01-2012, 12:12 AM   #6
billyboy999
Member#: 292919
2007 STi
I have a question about those jack stands - do the rubber things help? I bought those jack stands but after looking at the (I'm going to refer to the part that meets the vehicle as the fork) fork, and positioning it under the jack spots I was afraid the indent was too deep and the sides of the fork would cut into side skirt. I was seriously debating sawing off the sides a little.
I have an STi not a forester but maybe it's similar.
billyboy999 is offline   Reply With Quote
Old 02-01-2012, 01:03 AM   #7
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I sawed the rubber jack stand protectors for my RIP '06 STi, just the skirt side, look closely at the pic, the ourboard side next to the side skirt has a sawed off step.
Old 02-01-2012, 02:07 AM   #8
billyboy999
Member#: 292919
2007 STi
Alright cool, I'll buy those red rubber things and see how things fit for myself. I was mainly afraid the red rubber things wouldn't solve the problem.
Old 02-01-2012, 05:40 PM   #9
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
added one more pic of the Harbor Freight jack stand cushions showing the cutoff to protect the side skirt. And the enlarged semicircle to clear the pinch weld.
Old 02-06-2012, 01:31 PM   #10
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
My bugeye has been on stands for over a year and although it hasn't come down yet (next couple days!) I don't notice any deformation as it sits.
car_freak85 is offline   Reply With Quote
Old 02-06-2012, 02:49 PM   #11
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^It would be impossible to notice deformation at first glance, are you using pinch weld locations? Just seems 825lbs a corner is a lot, mine has been on stands for a month and I feel very uncomfortable, get the feel I am doing a diservice to the unibody taking on so long to swap the clutch, I have run into several snags that prevent me to finish the job within a reasonable time.
I will probably put everything back to give the unibody a break.
Old 02-06-2012, 06:10 PM   #12
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
/\ I don't think its impossible, on the contrary, if it isn't straight I would immediatly recognize, I mean, I'm under there pretty much every afternoon...
The car IS resting on the pinch welded seam. I can imagine this being a problem if you set it up on jacks on an uneven, non-level surface, otherwise I think you are overreacting...
On another note, I've let my '84 subaru wagon sit on stands for an equal, if not longer period of time with zero ill effects. I think you're ok...
Old 02-09-2012, 08:46 PM   #13
Jerry_NJ
Member#: 233288
2004 Forester
Speaking just of the Forester (mine is an older model, 2004), isn't there a "frame" or an "axle" location(s) where one can use a floor jack and jack stands rather than lifting on the body? It seems okay that one would need some easy to get to place to support emergency tire changes by the side of the road, but when in the garage over flat concrete can't we place a floor jack under the car somewhere else?
Jerry_NJ is offline   Reply With Quote
Old 04-22-2012, 01:33 PM   #14
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
I had my car up on jack stands for over 12 months. Out of country.
Car is fine so are the pinch welds.
runner19 is offline   Reply With Quote
Old 04-22-2012, 02:13 PM   #15
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Front by subframe there is a jacking plate 4x4.
Rear place jack on rear differential.
Old 04-22-2012, 02:19 PM   #16
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Impossible to detect by the human eye, unibodies are welded with resins and with time under stress/strain eventually the bond will be compromised, I am now using ramps or supporting the car at the location where dealers place the hydraulic lift forks using 4x6 to spread the load.
Old 04-23-2012, 05:27 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
you are quite completely out of your mind
Old 04-24-2012, 10:58 PM   #18
scarney1988
Member#: 317760
You will be fine. I wouldnt lean on that thing to hard, but you'll be fine.
scarney1988 is offline   Reply With Quote
Old 04-25-2012, 11:01 AM   #19
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Why are you worried about deformation anyway? Even if it does deform it a little, who cares? Are you going to be pulling 1.5g's with r-compound tires on a race track? No? Then fuhgettaboutit.
If you are anal, buy yourself some racing scales, and measure the cornerweights before and after it sits on the jack stands. This will tell you if the car is tweaked. Also, you can then buy some coilovers so you can set the corner weights. While you are at it, you should seam weld the unibody for increased torsional rigidity. Of course, you should get a jig for the car that is set to manufacturers recommendations so you know the body is straight. Finally, put an 8 point roll cage so the car will never be out of whack again.
Or just drive the car.
Bacon117 is offline   Reply With Quote
Best place to get a inexpensive jack and a set of jack stands that won't kill me? Turk Off-Topic 31 03-06-2008 10:05 PM
Long Term Effects of Marijuana Use Soontobe Texas Impreza Club Forum -- TXIC 151 06-13-2005 09:47 PM
Long term outlook of upgrading turbo / going to a Stage 3 JM530 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 03-03-2005 06:13 PM
Long term use of Redline MT-90 in transaxle. 96 Flat Four Transmission (AT/MT) & Driveline 4 11-06-2004 04:53 AM
need to borrow a jack and a set of jack stands please. V6TurboTA New England Impreza Club Forum -- NESIC 22 04-29-2004 04:03 PM
